Utilizing the internal USB 4 header with the 4G card
I was able to successfully utilize the USB 4 connection that is abandoned on the 4g card. (Tapped pins 13/15 on the main connector and tapped onto 5v and GND for power)
It is doable if you take your time and use plenty of flux.
NOTE The data line connection to the wifi card in the picture was reversed. I swapped the pins in the connectors rather than re-soldering to make it work.
