Hello everyone,
Is there a way to wake up the Uconsole with USB, GPIO or something else ?
Thanks
Hello everyone,
Thanks
You could solder directly into the button to stimulate a press. Otherwise im not aware you’d need someone with more expertise than me i haven’t had time to look through the designs and schematics to know if there is another method.
USB isn’t powered until the kernel is loaded, so it could only work from fake sleep
also because the PI doesn’t really have low power modes afaik
Thanks for the replies.
Makes sense for USB and I was thinking about wiring the on/off button. I’m just looking for a cleaner solution.
Does WAKE_ON_GPIO works with CM5 ?
I found the answer… It doesn’t work with cm5
