How to force off a uConsole without removing the batteries? (Power button doesn't do it)
For whatever reason, my uConsole CM5 corrupted its SD card, and is now bootlooping. (Which is only visible on an external monitor. The LCD is dark.)
How do you power it off without opening it up and removing the batteries? Holding down the power button does nothing.
the only way I found, just wait… I clicked out the SD card once, and it seemed to go faster, but honestly not sure if that might have been just been a cooincidence.
The new boards by @vileer have an option to install a hard switch though, see here: https://forum.clockworkpi.com/t/hackergadgets-uconsole-upgrade-kit-adding-nvme-ssd-pcie-rj45-ethernet-and-usb-3-0-to-your-uconsole/
on a cm5 removing the battery is the only option
raspberry pi made some changes to the power control pins between the cm4 and cm5 so the powerbutton only works when the kernel is still responding on the cm5
Well, at least I know it’s not a hardware problem. My battery ran out and eventually solved the problem. Thanks.
it’s a hardware problem!
Wait so will my upcoming cm5 build eat up battery even while “off”?
no, they just meant that its a hardware issue that you can only take off the batteries for force shutdown a uconsole.
no, raspberry pi changed how some of the pins work between the cm4 and cm5
so the pin that handled forced shutdown got moved. The uconsole can fully shot down when everything works normally, but when the kernel crashes or doesn’t load properly the button doesn’t work
Was there some reason you were unable to remove the battery?
it’s just annoying having to open up the back with a hex driver
Hi,
Next time your device hangs up, could you please check if holding pressed the power button during 10 seconds does turn off the uConsole?
I’m just curious because this way to force shutdown should work anytime, no matter why.
It’s like a basic safety measure :expressionless:
the issue is that raspberry pi changed how one of the power pins works, so what worked for a cm4 behaves slightly different on a cm5
That is the whole point of this thread. That works with the CM4 but not the CM5. If the CM5 hangs, you have to unscrew the back to power it off, or wait for the battery to run out.
sorry for pinging on an old thread, did you find a solution for not unscrew the uConsole to do a power off ? KR
I recommend the nvme board anyways, but soldering the hard power switch isn’t too bad. Took me 4 tries to get it soldered properly and removing the resistor was nerve racking, but I’m very happy with the hard reset switch
thanks a lot for the images but I do miss the one of the back of the battery holder…. is this Install HackerGadgets Battery Board Manual Power Switch | Jing ? TIA
I got one already ordered thanks for the tip, does the board contain something that makes things easier ? KR I see now
Yeah! Basically desolder r14 and shove wires into the holes for j6 attached to a switch.
This guide is what I followed Install HackerGadgets Battery Board Manual Power Switch | Jing
Got it, thanks
Thank you mate, I will sharpen the solder, get good paste and pray :smiley:
