In a few hours I’ll be receiving my uConsole.
I have some questions about the SD card supported by this device.
I understand that I should look for the fastest and largest-capacity card I can afford… as long as it works properly with the uConsole.
I’m relying on your wisdom and experience to see if any of the following cards will work, and if possible, to recommend which one would be best.
I’ve listed these models because they’re the ones I can easily get in my country:
Lexar SD Memory Card 512GB SDXC 205MB/s U3 V30 4K Silver Plus Pro
Micro SDXC Xiaomi Pro Plus 1TB V10 U3 SDXC
Micro SD 256GB SanDisk Extreme Pro U3 V30 A2 200MB/s
If you’re not familiar with these specific models, what specifications or designations should I look for in an SD card to make the most of the CM4 module included in the uConsole?
The Raspberry Pi 4 supports microSD cards with a maximum speed class of UHS-1, which can achieve speeds up to 104 MB/s. For optimal performance, it’s recommended to use Class 10 or UHS-1 rated microSD cards.
