Tried to use a 32GB SD Card by SanDisk, showing the A1 logo.
I’ve tried various methods on linux to clone the existing working 16GB SanDisk card.
- Cloning the partition and extending to 32GB.
- Cloning the partition and not extending (remains 16GB).
- Cloning the drive and not extending (leaving 16GB unallocated). eg.
sudo dd if=/dev/sdf of=/dev/sdi bs=16M status=progress
None of these methods are producing a bootable disk.
And, I don’t get any boot messages on the screen to see where things are hanging up. So I can’t tell whether its a disk issue, a format issue, or a security (UUID) issue. Where are the preliminary console messages going?
I see the post related to GameShell, but is the DevTerm the same? I only see one partition on the original disk, so I guess not.
Any thoughts?
EDIT Another attempt. Tried this method.
lsblk
sudo dd if=/dev/sdf of=/dev/sdi bs=4M status=progress
sync
sudo growpart /dev/sdi 1
sudo resize2fs /dev/sdi1
sync
EDIT Adding the sync commands to above fixes the issue. Simply “Eject”-ing the drive from the desktop seems insufficient. There must be a lot of unwritten cached data in the system.
