After playing Retro Game in NESTOPIA, GameShell stung in Loading…
Please help me!
from the x.log I guess it’s a font problem?
**cpi@clockworkpi** : **~** $ cat /tmp/x.log
X.Org X Server 1.19.2
Release Date: 2017-03-02
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.9.0-8-armmp-lpae armv7l Debian
Current Operating System: Linux clockworkpi 4.20.0-clockworkpi-cpi3-00001-ga2b7682c5366 #2 SMP Wed Jan 2 05:56:21 UTC 2019 armv7l
Kernel command line: console=ttyS0,115200n8 earlyprintk no_console_suspend root=/dev/mmcblk0p2 rootfstype=ext4 rootwait init=/sbin/init noinitrd panic=10
Build Date: 03 November 2018 05:53:43AM
xorg-server 2:1.19.2-1+deb9u5 (https://www.debian.org/support)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/home/cpi/.local/share/xorg/Xorg.0.log", Time: Fri May 10 23:11:50 2019
(++) Using config file: "/home/cpi/launcher/.xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/modules/4.20.0-clockworkpi-cpi3-00001-ga2b7682c5366/modules.dep.bin'
modprobe: FATAL: Module g2d_23 not found in directory /lib/modules/4.20.0-clockworkpi-cpi3-00001-ga2b7682c5366
/home/cpi/launcher/sys.py/gsnotify
../skin/default/truetype/VarelaRound-Regular.ttf
Traceback (most recent call last):
File "run.py", line 45, in <module>
from UI.main_screen import MainScreen
File "/home/cpi/launcher/sys.py/UI/main_screen.py", line 34, in <module>
from counter_screen import CounterScreen
File "/home/cpi/launcher/sys.py/UI/counter_screen.py", line 16, in <module>
class CounterScreen(FullScreen):
File "/home/cpi/launcher/sys.py/UI/counter_screen.py", line 18, in CounterScreen
_CounterFont = MyLangManager.TrFont("varela120")
File "/home/cpi/launcher/sys.py/UI/lang_manager.py", line 103, in TrFont
raise Exception('cjk font string format error '+ str(font_size_number))
Exception: cjk font string format error 120
1280
4
21
x11info: 8388615
