I did system update on the Settings.
After update, It shows LOADING… screen.
How can I fix this?
Please help me.
How can I fix this?
Please help me.
same here, all infos are welcome.
ssh into GS
cd apps/launcher
git pull
If he doesnt have usb eth or wifi doesnt connect that would be hard
yes
I hope the wicd still working
Fortunately, Wifi is available !
I’ll try this.
Nice! then pull the launcher files and should be fixed.
mine doesn’t seem to be getting the wifi adress.
So - wait, there’s an update that bricks some devices? How there’s no more posts about it? Am I missing something?
so after a few reboots got the wifi up and running, did git pull, which update the launcher, but still get stuck with a “loading” screen.
do
ls -l
and check if the owner is cpi of the launcher files and folders.
If its root change it with
chown cpi file
I had my launcher stuck because of a simple thing like that a couple of times
will check them all to find a culprit
permission look good but sys.py has a directory permision which I think its weird, I dont have my cpi here to check, lets see if someone else can check that.
Did you add emulators to the launcher before updating it?
Edit: its a dir my bad, got confused by the .py
the only thing I changed was, adding a Menu Icon for Pico-8 and for the SNES Emulator.
I break very often my launcher (gets stuck on loading) by adding menu icons for the launcher.
Check those icons also
removed those 2 options, and now it works
Nice!
Check their owner, they might have been root instead of cpi. (when adding them again)
it was cpi, that’s why i was surprised. also, the launcher worked fine till the last 2 updates.
also experiencing some menu slowdowns here and there.
