AIO Antenna upgrades?
Any successful antenna upgrade stories ?. Which model, why, how much improvement did you see ?. AIOv1 or v2 ?
Is there a great all round SDR antenna or is there no choice but to have a set to suit the band you’re scanning at the time ?.
AIOv2 experience on various bands ?, any that are simply unusable ?
Supplied with my AIOv2…
If that was mine, I’d move the gps antenna to the spot on the far right. It has the most distance to the next connector.
I placed it there to give easier power switch and SD card access. The SDR aerial was going on the side but I didnt get the socket in my kit (ordered from Hackergadgets and out of stock parts from Aliexpress). Socket that arrived today from Amazon has a too big back nut :enraged_face:
That brass is super soft. File down 2 opposing sides and run it….
Still getting full speed yet noticed today, back corner of the house wi-fi -70dbm. Removed the Hackergadget wifi aerial, -70dbm. Surely something is amiss here !
SDR antennas are going to depend on what you are trying to do. The one that came with the kit seems great for fm so far.
I upgraded the lora antenna to a 900mhz whip antenna that I use for most of my meshtastic gear.
I am upgrading the Wi-Fi and Bluetooth antenna but that’s just for visuals honestly.
If you want to get fancy you can buy a nano vna and test antennas at the frequency you care about.
Dumb question, is your antenna rp sma? I connected an rp sma wifi antenna to mine without noticing and it mostly worked for wifi but Bluetooth choked. A real sma antenna fixed it right away.
If you remove the original wifi antenna while stood in a weak spot do you see a difference in the dbm value ?
The cm5 wifi or th aiov2 wifi?
CM5 wifi routed to the Hackergadgets aerial and mount…
Classic. For some reason the boot config.txt had reverted to ant1, now ant2 again.
Ant1 = -86dbm
Ant2 = -68dbm
A slight improvement as expected, will try a larger wifi5 antenna asap.
How are you checking dbi? I’ll check in a bit. Wifi is bad at the end of my house so it could be a good test
In the terminal…
iwconfig wlan0
first one is my antenna attached, second is no antenna
chris@clockworkpi:~ $ iw dev wlan0 link
Connected to 3c:7c:3f:55:58:dc (on wlan0)
	SSID: Sir_Charles
	freq: 5805.0
	RX: 636814 bytes (849 packets)
	TX: 80797 bytes (1101 packets)
	signal: -46 dBm
	rx bitrate: 6.0 MBit/s
	tx bitrate: 24.0 MBit/s
	bss flags:
	dtim period: 1
	beacon int: 100
	SSID: Sir_Charles
	freq: 5805.0
	RX: 641175 bytes (861 packets)
	signal: -70 dBm
	bss flags:
	dtim period: 1
	beacon int: 100
Just tried removing the antenna again, zero difference. Even put the telescopic on and again zero difference. Config.txt still shows ant2. Will check/replace the cable and try another antenna.
UPDATE
Just tried again. -79db, remove the antenna -86 !. Tried the second wifi antenna supplied with my board -58 !. Removed again -68, put back -69 !?!?. Now stuck around -69/-70 whatever I do. Mental.
Anyone else care to try removing their wifi antenna and report the effect ?. Model number please if not supplied with the Hackergadgets…
are you using a cm5?
or the other knd of board?
CM5
Post must be at least 20 characters
running the wifi adapter without an antenna may damage it.
I too see -70dB whether or not I have an antenna attached. It is mildly annoying but I get good enough signal that it doesn’t bug me too much. I haven’t managed to do better than -70dB; that’s with/out the antenna and on either config.txt setting.
iwconfig wlan0…
5.54Ghz, 300Mb/s, power limit off.
In same room as router 31dbm (same on top of router).
iw dev wlan0 link…
Freq 5540 -45dbm
Rx 390Mbit/s
Tx 433.3 Mbit/s
