AIO2 guide to which aerial connects to which. And does the AIO2 cand need different software?
Hello,
My AIO2 arrived today and my AC2100.
I count 9 pigtail connector in total.
Does any one have a guid as to which one to use and which one do which.
Some are clearly marked.
GPS / LoR / SDR
but the 4 on the AC2100 well two are BT0 and BT1. I guessing the other two are WiFi0 and WiFi1.
So I am guessing pick one from each?
CM5 has one.
New Hackers Gadgets has one
uconsole card has one.
Any help would be great. Thanks.
2 wifi and 2 bt to the ac1200, not just 1, transmitters without an antenna connected can break when they try to transmit
your third wifi antenna goes to the cm5
mainboard wifi is for non raspi cm4/5 cores so you can leave that one unconnected
RPI TX on the HG adapter is if you want to transmit from the cm4 with raspi-tx. Because the CM5 GPIO changed a lot compared to the previous pi generations that no longer works so you should leave that one unconnected too
anyone got pictures. i think i get what you are saying. not sure i have eought of the pigtails to get 4 from the AC2100??? have to try.
This YouTube video is a good starting point, it’s the early board, for your AC1200, I connected as follows
ant1 β†’ AC2100 BT0
ant2 β†’ AC2100 BT1
ant3 β†’ AC2100 WiFi0
ant4 β†’ AC2100 Wifi1
ant5 β†’ CM4 Wifi
ant6 β†’ GPS
ant7 β†’ LoRa
side mounted β†’ SDR, comes with a MHF4 to SMA cable
8 in total
ClockworkPi AIO V2 Complete Walkthrough: Assembly and Configuration
perfect thanks, Next time i open it to install a power switch i will change it over
