Bluetooth device on gameshell
cpi@clockworkpi:~$ systemctl status rc-local
● rc-local.service - /etc/rc.local Compatibility
   Loaded: loaded (/lib/systemd/system/rc-local.service; static; vendor preset: enabled)
  Drop-In: /lib/systemd/system/rc-local.service.d
           └─debian.conf
   Active: active (running) since Sun 2018-10-21 06:26:17 UTC; 22h ago
   CGroup: /system.slice/rc-local.service
           └─753 brcm_patchram_plus --patchram /lib/firmware/brcm/bcm43438a0.hcd --enable_hci --bd_addr B0:F1:EC:2D:07:5B --no
lines 1-7/7 (END)
thx U. I am not a linux expert, but will the rc.local.service config like below:
[Unit]
Description=/etc/rc.local Compatibility
ConditionPathExists=/etc/rc.local
[Service]
Type=forking
ExecStart=/etc/rc.local start
TimeoutSec=0
StandardOutput=tty
RemainAfterExit=yes
SysVStartPriority=99
[Install]
WantedBy=multi-user.target
I am not a linux expert,either :slight_smile:
why you look into rc.local.service, I think rc.loal.service is fine with default content
just run systemctl start rc-local will enable rc.local.service at boot so that /etc/rc.local will be invoked at boot,too,
in ssh ,just run the scripts below, maybe copy and paste all into ssh
cat <<EOF >/etc/rc.local
#!/bin/sh -e
sleep 15
brcm_patchram_plus --patchram /lib/firmware/brcm/bcm43438a0.hcd --enable_hci --bd_addr B0:F1:EC:2D:07:5B --no2bytes --tosleep 5000 /dev/ttyS1 &
EOF
chmod +x /etc/rc.local
systemctl daemon-reload
systemctl enable bluetooth
reboot
and just in case
if you did not see the launcher up but only a loading…
into ssh
cd ~/launcher ← or cd ~/apps/launcher
DISPLAY=:0 ./load.sh
see if there are other problems
it seems that after running systemctl start rc-local, it doesn’t enable rc.local.service. at boot. but probably I need to figure it out. do we need to run the bluetoothctl to connect device everytime we start the clockworkpi?
The launcher can connect bluetooth devices now ,but without pair code
it seems bluetooth > 2.1 can pair without code
But every time you connect to a Bluetooth device, you need to connect it again with launcher or bluetoothctl
right now I don’t know how to make a bluetooth device auto-reconnect efficiently
hi sir,
“bluetooth in launcher alpha now” i cant find the code inside the 1.22 launcher update.
please help.
thanks
what you mean cant find the code inside the 1.22 launcher ?
you mean the source code or bluetooth pair code?
you said “check out the newest code of launcher then you will see it”. are you saying there is a bluetooth.sh able to scan bluetooth device and connect them? right now i can only use putty to scan and connect my bluetooth controllers. just want to make sure if everyone is doing to same?
thanks
the code is python
In launcher under settings
there is a new item named “bluetooth” now
do the same job as cli scan and connect bluetooth
yes sir, i manage to see the bluetooth folder and manage to make it work. its awesome. thanks!
hi Nabee,
How do you add the joystick config in retroarch. i finally managed to get the joystick connected via bluetooth, thx to guu and your guidance. but the joystick didn;t response any input.
Regards,
Ed
work it out after a few retries on tinkering…thx Nabee with all the instruction on adding joystick on Bluetooth.
it works alright after having the Bluetooth UI added in launcher. would have been nice to auto connect :slight_smile:. I notice after adding the Bluetooth, the navigation within the CPI UI can freeze up occasionally. does it happen to the other as well?
more detail about the freeze up occasionally ,please
I might have used the wrong term on freeze, it’s slow down the UI for 5-10 sec, especially when scrolling game list or navigating the CPI OS settings. but afterwards they are ok. not really a big issue.
so now with clockworkpiOS 0.3 bt is working out of the box. But how can I connect the 8 Bitdo Zero GamePad to get it working I managed to use the OS-X mode (keyboard) and when I bind it, the keys are recognised well. But I can’t get it in games e.g. on snes
Hello! PocketPC.ch.
Sorry for the late reply.
I also tried it with OS v0.3, and it worked fine.
Maybe you do not need to turn 8 Bitdo Zero GamePad into Keyboard Mode.
Do you recognize GamePad properly in Retroarch?
If you recognize it, at Retroarch launch, you will see a message like “8bit do Zero Gamepad not configured” with yellow letters at the bottom left of the screen.
If it is not recognized, copy retroarch.cfg somewhere,(←Strongly recommended.)
execute the following on the command line,
sudo usermod -a -G input cpi
Please try starting Retroarch again.
Assign the button with BindAll.
thanks but unfortunately that did not help. there is no user whoami. I now did all the steps (except from enable bluetooth) on a fresh install of cpiOS 0.3. I added the user cpi to the group input. I created the 10-local.rules file as you suggested and reloaded the udev rules.
When I look ad dmesg, I get
Bluetooth: hci0: last event is not cmd complete (0x0f) just after I connected in Windows-Mode.
I also tried to use the hid
In regular Android mode, I get
[ 1296.395205] hid-generic 0005:05A0:3232.0007: unknown main item tag 0x0 [ 1296.402337] input: 8Bitdo Zero GamePad as /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:12/0005:05A0:3232.0007/input/input15 [ 1296.415953] hid-generic 0005:05A0:3232.0007: input: BLUETOOTH HID v1.09 Gamepad [8Bitdo Zero GamePad] on b0:f1:ec:2d:07:5b
and udevadm monitor, I get
yS1/hci0/hci0:11 (bluetooth)
KERNEL[1280.664788] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:11 (bluetooth)
UDEV [1280.671252] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:11 (bluetooth)
KERNEL[1281.010348] remove /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:11 (bluetooth)
UDEV [1281.013944] remove /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:11 (bluetooth)
KERNEL[1289.501887] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:11 (bluetooth)
UDEV [1289.508097] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:11 (bluetooth)
KERNEL[1289.810360] remove /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:11 (bluetooth)
UDEV [1289.813808] remove /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:11 (bluetooth)
KERNEL[1291.519303] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:12 (bluetooth)
UDEV [1291.525526] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:12 (bluetooth)
KERNEL[1296.398004] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:12/0005:05A0:3232.0007 (hid)
KERNEL[1296.417584] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:12/0005:05A0:3232.0007/input/input15 (input)
UDEV [1296.417865] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:12/0005:05A0:3232.0007 (hid)
UDEV [1296.418180] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:12/0005:05A0:3232.0007/input/input15 (input)
KERNEL[1296.419151] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:12/0005:05A0:3232.0007/input/input15/event2 (input)
UDEV [1296.623789] add /devices/platform/soc@1c00000/1c28400.serial/tty/ttyS1/hci0/hci0:12/0005:05A0:3232.0007/input/input15/event2 (input)
and even though RetroArch is set to udev as type for Joypads, it does not see the device at all and the Device Index stays Disabled
I also tried to use the Driver hid for Joypads in RetroArch as udevadm persists on looking at it as hid-generic device. no luck. so neither udev nor linuxraw nor hid are usefull.
But if I use sdl2 as driver, it shows me the 8Bitdo Zero would not be configured! Only binding doesn’t work.
dang I got it! sdl2 as driver works correctly! but RA grabbed the gamepad and assigned it to Input 1. that’s why it was disabled for Input 2 :expressionless:
IO removed the udev rule now and I am looking forward to happy gaming with my kids :joy:
