initramfs-tools was updated and replaced a change I have made to make my custom kernel be able to build a initramfs. to fix you can reinstall the kernel clockworkpi-kernel or issue this command below and then finish the apt upgrade.
sudo sed -i '/^MODULES=dep/c\MODULES=most' "/etc/initramfs-tools/initramfs.conf"
@mattconn24 Are you running a CM4 or 5? I compiled all the dependencies fine but the main program kept locking up my system on the CM5. I’ll try with the CM4 tomorrow.
@Brandon_Gomand Not that I’m aware of, most 32GB cards will work. At least enough to change the EEPROM config to work will all SD cards.
I assumed you’re using this repo. I cloned the repo, and the build script BuildLinux.sh didn’t work at first. It looks like they only had it set to work with x86, so I added this to the check.
Running ./BuildLinux.sh -d built all the dependencies fine but when I would compile the main program with ./BuildLinux.sh -s my machine would lockup between 45-60 mins each time, tried 3 times. Not sure why, temps were warm at 62°c but I get higher compiling the kernel.
Is that the same superslicer you were building and how were you compiling it?
same as you i modified the linux build.sh to aarch64. also changed the min ram to 2GB due to it saying i didn’t have enough free. i have a 4GB model. only thing i haven’t tried yet to to look at the make command the raspberry pi section of the build docs state to use -j4 or less to limit processes.
using same repo. also tried to use the -b 2.7.61.2 which is the one i want.
Forgive my naivety, I was trying a 64GB thinking that was small enough. 32GB worked to change eeprom settings and now working with a 128GB card on bookworm with CM5 Lite
It compiled and I placed the app in the packages folder in the mega link. I get an error and it crashes but the app does start. Let me know if it works for you or you find a work around.
I just ran ./BuildLinux.sh -dsi on the CM4 and it took a few hours but it just went all the way though. Not sure why the CM5 was locking up, it wasn’t at the same place any of the 3 times I did it with the CM5. I can do it again with a different options if you want?
nah i was experiencing the same behavior. i was getting an error on building the deps when it got to cgal though. i was able to get around that by pointing the cgal cmake file to the 5.6.2 version. i have the cm5 4gb eccm. i don’t know what has changed since the first time i was able to build and compile it on my original post but i know at least 1 other person was able to do it following my original post. i will give your appimage a try. thinks for spending some time on this. i am really new to linux and just wanted to make sure it wasn’t a me issue.
Ya I’m not sure why it failed and it hard locked my CM5 system 3x so I didn’t have any logs to figure out why. The CM4 built it with no errors, but I get an error opening the app. I didn’t upload the appimage of it just the zip of the app, the appimage would just failed with cannot execute: required file not found
