Hello
Can I plug in compute model 4 with 8GB of ram to uConsole?
Hello
I would assume you could swap out the cores at your discretion, but idk. Maybe when/if the Raspberry Pi CM5 drops, you could swap that in too. An upgrade path like that would make it that much better… now if only the uConsule I/O reflected the power of the CM4. An upgrade path too the carrier board and more expansion module options would be really cool.
that’s one nice thing about FOSS hardware, even when clockworkpi stops supporting the uConsole and/or DevTerm, third parties could develop new core modules, cell upgrades, or even a new compatible screen, for, say, 1080p or even 4k
This is what I’m planning on doing. But you need the CM I/O board to be able to flash the eMMC if you don’t get a Lite.
Nothing official from Clockwork so I could be wrong…
Alex told me I can use the 8Gb, no emmc. I ordered the R01 and adapter and separatly the CM4 8G. the uconsole should arrive today, so i will confirm the 8Gb soon!
I used to understand that I could use one with emmc but pre-install the OS with extra hardware.
To use the eMMC you need a developer board for the CM4 unit. That is a bit of a pain, but the disk speed access will be way faster than the SD card.
It’s there… But a pain I’m sure… that is the jumper for flashing…
Yeah, I wised it can USB boot like the Pi but need to flash the ROM to enable that, and I believe the uConsole has no ROM no BIOS so can’t do that.
YES!
If you get a model with eMMC, you cannot use the SD card slot, though.
It doesn’t even show up on the system at all.
CM4+8GB RAM: Yes, no issues
CM4+eMMC: Yes, it works, but you have to flash the eMMC boot drive with another system (dev/breakout board)
I’m using a CM4+32GB+8GBRAM with 0 issues.
I am also using the same CM4 with eMMC, it does work well.
I just bought a new CM4 I
8gb Lite, does anyone know if I have to reflash or anything once I install the new core?
Nope just fire it up.
