Can we 3D print our own housings?
Is this truly an open hardware design? Where can I find the CAD files for the plastic housing??
Thanks in advance!
I asked recently, they are working on the files to be shared into the Github channel.
On November 6, I got a response:
“Our R&D will upload the STL files in a few days.”
It should be coming soon.
That’s amazing, thank you!
I’ll stick to the stock shell, but it will be awesome to have the option to 3D print the shell in a different color or to make modified shells for unique looking cyberdecks.
I mostly want an alternative shell to make swapping modules/batteries easier. Using a cheap cm4 heatsink should make it more than cool enough without the aluminum backplate.
Not aluminum anymore, it is a casting Magnesium case now.
