Can't "click" the uConsole (fresh build)
I can move the mouse around on the uConsole but when I press on the dome - no click.
Steps I have taken so far:
  • Removed and reinstalled the roller mouse, trying different orientations - no joy.
  • Device will work with an external mouse installed (assume it not a driver issue)
Any ideas?
Thanks for your assistance.
Erik
have you tried xev or wev to confirm there is no click?
it should produce “middle mouse click”, like open link in new tab
for left/right clicks there are dedicated buttons.
(if you will update keyboard firmware you will be able to use fn + ball for scroll)
(or QMK firmware does scroll on select + ball)
Turns out the clearly marked L and R buttons are the clicks !
Thanks!
