Mouse needs too much pressure and runs slowly
Hi,
I just mounted my uConsole and after booting the mouse is almost useless. It needs too much pressure and runs very slowly. Is it a know problem? The direction of the movement is OK.
Thanks for any possible help.
Best
what does it mean? when you move ball left – cursor goes left?
no, it should be relatively smooth. try to clean it with alcohol.
also people on the forum have tendency to buy a replacement on ebay/ali. modules are cheap and the legend is some better then others.
useful (not related to trackball) links:
Yes, when I move the finger to the left, the cursor goes to left. Up and Down is also correct. But most of the times, when I move the finger there is no movement. I will try a replacement and also will clean to see if it improves.
Thanks.
looks like a bad unit. mine is not ideally smooth, but it works fine.
