I decided to create this tutorial because I facing a problem when I connected my GameShell in a Wireless that use the same network as usb-eth – 192.168.10.0/24 – thus generating problems such as IP conflict.
Connect on your GameShell
To do it is necessary to connect on GameShell via ssh, you can disconnect the wifi on GameShell and use just the interface usb-eth if you are on the wifi with this problem while you solve this issue.
~$ ssh cpi@192.168.1.169(your GameShell IP)
Change the interface IP
Edit the /etc/network/interfaces file on the line usb0 address , In this case I used a class A IP network rarely used 11.11.11.0/24.
cpi@DEOT:~$ sudo vim /etc/network/interfaces
allow-hotplug usb0 auto usb0 iface usb0 inet static address 192.168.10.1 netmask 255.255.255.0
to:
allow-hotplug usb0 auto usb0 iface usb0 inet static address 11.11.11.11 netmask 255.255.255.0
Change DHCP range
The GameShell use the dhcp-server to make the connection easy, so its necessary to edit the file /etc/dhcp/dhcpd.conf and change the range of IP that will be distributed, I chose a short range of IP .100 to .105, that is more than enough.
cpi@DEOT:~$ sudo vim /etc/dhcp/dhcpd.conf
subnet 192.168.10.0 netmask 255.255.255.0 { range 192.168.10.10 192.168.10.250; }
to:
subnet 11.11.11.0 netmask 255.255.255.0 { range 11.11.11.100 11.11.11.105;
Change CONNECT script
The CONNET app shows the USB-Ethernet interface IP as text, so it is necessary to make the change on the script manually. Edit the file __init__.py:
cpi@DEOT:~$ sudo vim /home/cpi/launcher/Menu/GameShell/60_CONNECT/
__init__.py
[“usb-eth-addr”,“192.168.10.1”, self._ListFontObj, self._URLColor]]
to:
[“usb-eth-addr”,“11.11.11.11”, self._ListFontObj, self._URLColor]]
— Restart you GameShell and test it!
cpi@DEOT:~$ sudo reboot
Check the UI on GameShell:
MENU > CONNECT
Connect a USB cable to test DHCP
Connect a USB cable on the GameShell and check the usb-eth connection on your computer:
:~$ sudo ifconfig enp0s26u1u2 Link encap:Ethernet HWaddr ▀:▀:▀:▀:▀:▀ inet addr:11.11.11.103 Bcast:11.11.11.255 Mask:255.255.255.0 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:77 errors:1 dropped:0 overruns:0 frame:0 TX packets:192 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:10796 (10.7 KB) TX bytes:24160 (24.1 KB)
Connect on GameShell to test the connection:
:~$ ssh cpi@11.11.11.11
cpi@DEOT:~$ sudo ifconfig usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 inet 11.11.11.11 netmask 255.255.255.0 broadcast 11.11.11.255 ether ▀:▀:▀:▀:▀:▀ txqueuelen 1000 (Ethernet) RX packets 196 bytes 16380 (15.9 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 168 bytes 31292 (30.5 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Helpful link: GitHub - clockworkpi/USB-Ethernet: Setup USB Ethernet
