I found cheap MT7821 dongle with monitor mode on aliexpress. My adapter aliexpress link is broken ![]()
Is there an existing driver for it?
I used this board for quite a while with an USB adapter. Trixie detects it without any issues because it uses the same chipset, although it only has two antennas. Even so, it works really well.
请问,有蓝牙功能可用么,我最近购买了一个基于MT7921AUN的模块,在AI工具的帮助下绑定了ID和驱动。
当前Wi-Fi可用,但是蓝牙一直提示:
Can’t init device hci1: Connection timed out (110)
hci1: Type: Primary Bus: USB
BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0
DOWN
RX bytes:0 acl:0 sco:0 events:0 errors:0
TX bytes:6 acl:0 sco:0 commands:2 errors:0
Features: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Packet type: DM1 DH1 HV1
Link policy:
Link mode: PERIPHERAL ACCEPT
而且另外不解的是:我更换了21700电池组后,原本CM5自带的 Wi-Fi+蓝牙 信号微弱的问题有了很大改善,基本上达到了正常可用的状态,在隔壁房间都有效。(之前Wi-Fi信号弱,蓝牙有效连接距离短,不在同一房间基本不可用)。
我购买MT7921AUN的模块和21700电池组几乎同时,当前MT7921AUN的蓝牙我还不知道怎么驱动。
老兄,蓝牙可用么
我总是遇到蓝牙驱动超时
Lanthar, everything seems fine on my end, but I don’t use Bluetooth much. I’ll pay closer attention to it. Try checking your power profile, though—there might be a power-saving setting affecting it. That’s one possibility. I haven’t had any Bluetooth issues, but again, I rarely use it. I’ll keep an eye on it.
你是使用的HackerGadgets的AC1200么?
我不只是在uconsole上面测试,我在其他arm linux设备上也遇到蓝牙重制失败的问题,还可能导致整个usb卡死。我不知道是我选错了硬件还是说驱动问题,这方面我不是太懂,不过在AI的指导了,折腾了挺多时间 ![]()
Today I use the HG AC1200, but I also used this MT7821 for quite a while without any issues. I’ve never had any problems with Bluetooth. I’ll test it, my friend, and try to pay more attention to this.
谢谢,不过这个应该是MT7921AUN吧
