HackGadgets AIOv2 AC1200 not seen in Watchdog go?
I recently picked up the AC1200 for my AIOv2 board. I installed it, and Trixie seems to see it ok (using Rex’s Trixie build) However when I try to run WatchDogGo it doesnt seem to see the wireless card? just says no ESP32. Is there a trick or anything I need to do to get it working?
tried reinstalled, USB seems to be seen (USB: On) just doesnt seem to want to see the wifi (just says no ESP32 serial)
Thank you
I don’t think it’s trying to use the AC1200 card because it’s trying to use something like a XIAO C5.
From the Watch Dogs Go site.
Been reading about this but do not want to get another module atm. But I did notice the post in Issues speaking about as solution which does not require ESP32 and should work with AC1200.
Apparently they have added a bridge to the official repo under extras but it will not be merged with the original install script as I understand.
After re-reading the latest 378-line version (with start_sniffer + start_handshake added), the calculus tilts toward keeping it as a community-maintained tool rather than a maintained part of the core, for these reasons:
  • The handshake capture path (airodump-ng + hcxpcapngtool polling) duplicates what the ESP32 firmware does over serial. If both run at once they fight for the radio. The bridge is correct for ESP32-less setups, but inside the main repo it would need explicit ESP32-or-bridge mode selection in the game itself.
  • Adding airodump-ng + hcxpcapngtool to setup.sh changes the dependency footprint for every user, including the 95% who use a real ESP32 and don’t need them.
  • The bridge is the right shape for community-maintained: tracks the projectZero serial protocol, lives next to the user’s hardware quirks (which interface, AIO v1 vs v2, MT7612U vs RTL88xx), and gets iterated faster outside our release cycle.
Hey Rex,
I saw this and thought you may be interested in the ac1200 holder/support HackerGadgets AC1200 holder for the Clockwork Pi uConsole by g7ufo | Download free STL model | Printables.com
As well as the xiao internal mount XIAO ESP32 Internal Mount for uConsole by kerbybit | Download free STL model | Printables.com
Thank you for all the funky stuff you do!!
I have the Xiao one save and I plan to use it. Although I don’t plan on using it with watchdogs go.
