Im trying to upgrade my uConsole from CM4 to CM5 and I think I’m running into the documented issue where an upgrade done using “sudo rpi-eeprom-config -e to change whatever this is.
I’ve tried so many different methods but so far its just still not working.
My basic question right nosw is “is this info in a file in the OS image once the RPi write to SD installtion thing is done? After “installing” the image file the SD now has a lot of files on it. Is one of those something where I can edit and save these changes?
I had ordered a Waveshare Mini base -b which arrived today. And I guess I have a dead CM5 because nothing’s happening when trying to boot known good sd cards. I can find very little actual documentation on this whole setup but it seems somewhat simple, as long as everything is working. But as I get nothing out of the hdmi port.
I think I’ll stop wasting any more time, be happy with the CM4 and see who much of this other stuff can be returned.
