Right. I think I misread your previous post, thinking you meant that one SD card you flashed the custom image to worked wonders. Could you clarify and confirm this?
I’ll start work on an emergency image update after work today, as well as provide a simple script to apply the fix.
It looks like it’s just the kernel that’s the problem, which is a relief troubleshooting wise.
Can I confirm whether or not this ended up fixing the screen flashing problems?
- It fixed the flashing.
- It didn’t fix the flashing.
- There are other problems.
- I don’t know how to follow the instructions.
0
voters
