DevTerm keyboard construction and connectors
Ok guys I am starting to advanced on how to start to build one of these guys from scratch but I have a few doubts.
  1. The keyboard; I do not mean the pcb but the actual physical keys-module. I am assuming getting one from an already made DevTerm will be the best and then ask someone to fabricate some as a prototype. I do not know how is assembled apart from what I can see in the pics and dxf files. I suppose it would need some plastic manufacturing for that. Does anyone has any idea before I can start t scratch here and there to see what can be done about this?
  2. Cables and screen; I found a screen that is used for raspberry pi projects with the same size but I do not know if it will work. I suppose the also depends on the connection from the screen to the board which is another thing I need to review. Does anyone knows which type of sacral is this one?
  3. The other cables just as the wifi antenna; same as with the connection between the screen and the board. I might need someone to fabricate these two or find them but this might be some extra work.
  4. I am assuming that building one will lead me to the obvious choice of using the CM4 adapter which then might lead to be able to use the CM5 or the Radxa boadr, but that is another subject.
Thanks to all btw! Was reading all the subjects in the forum and they were very helpful :slight_smile:
