i was trying to move a file to a specific folder via ssh and i kept getting “permission denied”
after a bit of googling i tried a method which involved this “sudo chown -R www-data:www-data /”
soon after i wasnt able to do much on the device , i restarted it and the usual boot up screen showed up then instead of happy hacking it gave me a permission error (iirc)
i took out the SD card so i could flash a new image on it but later i found out that the clock work pi wont boot up at all , no led lights (without the SD card) etc
In those cases, use sudo to execute the command as root. If you’re doing a large amount of work in protected areas, use the command sudo bash first to do all of the work in root mode.
i was transferring the files via command prompt because ssh felt too slow . now im using winSCP and its all good .
thank you !
one more question . i installed the PSX emulator core from Micro007 in retro arch (and used all the settings in the retroarch megathread) but the Audio quality is not that good . maybe its just how ps1 sounded like but imnot so sure.
