default position of antenna is awful and too deep in metal case. try to get close to wifi point and try again or run hotspot on mobile and try connect to it.
if you will see anything – put some foam like 2-3mm between antenna and case (like 2 sides tape),
or try some other external antenna: Replacement wifi antenna - #118 by mex
