EEPROM config and the CM5 lite
does shutdown and boot then works? not reboot, but full power cycle
Yes, instead if reboot I shut it down from the menu or sudo shutdown now in terminal. Starting it with the startup button and running in seconds.
Only thing I didn’t do is what Rex mentioned: “kernel=kernel8.img” in the boot file.
I’m not giving up; waited almost 10 months to get the uConsole and my HackerGadgets AIO1 was sitting for like 9 months on the shelf. I hope the AIO card is not malfunctioning with this Lora chip…
Can you try a different NVME? I had that same problem with my CM5 in a IO board. It would reboot fine with SD but it wouldn’t reboot with an nvme. I switched out the nvme to a different one and then it worked fine
Maybe try uncommenting the following [pi5] boot config.txt line and reducing nvme speed to gen2 as below, working perfectly on my 16Gb CM5 lite and 256Gb nvme. Apparently increases reliability (long traces on the Hackergadgets battery board) and reduces power draw. My nvme read speed is 474MB/s, vs 90MB/s of a Sandisk extreme Pro micro-sd card…
dtparam=pciex1_gen=2
The thing is, I haven’t received my battery board with NVME yet. I’m still on SDcard and set pciex-speed x3 off. I also set kernel=kernel8.img in the boot file, but rebooting means still crashing. For now I only shut it of and start with the start button on top.
I don’t know if my Lora-chip is not working as part of my HackerGadgets AIO v1 card and that this is the reason there is a affecting problem in the overall working of the uConsole. I’ll remove the extension board and see if that helps.
Hi guys, I’m super new to uConsole but not the CLI. I have got a preassembled uConsole with CM5 Lite 16GB.
I flashed a 128GB Samsung card I had lying around for my Switch etc with ClockworkPi-Bookworm-6.12.67.img.xz.
When I try to boot up the uC, nothing happens on the screen. Short press/long press, the only thing that has a sign of life is that the power on/off button glows a bit green in its left. Help, I am stranded!
switch 1 or 2? a express sd card won’t work.
It’s a “SAMSUNG EVO Select Micro SD-Memory-Card + Adapter, 128GB microSDXC 130MB/s”.
I don’t know what I did, but the thing finally booted but it’s still a bit janky, not consistent. I ordered a slower card just to test.
Thanks!
When it did boot did you edit the eeprom as outlined in the first port? That should fix your problems with unreliable boots with the CM5.
After I had some initial trouble updating the EEPROM and had to download the latest binaries from GitHub, I made a script to fully automate the update and apply the suggested config from @Rex
I hope this can help anyone that is struggling:
Quick update; I got the NVME battery board and CM5 upgrade kit: I can now reboot, update etc.
Only thing not working is Meshtastic,but that is a config-thing I guess: Meshtastic can be started but gives “no signal” so no nodes to see. I have configured as stated in the guide and set region on EU868 (living in the Netherlands), but don’t know which channel/slot is being used.
All in all I think my first problems were caused by the SD cards I used and now I can install all distributions on my SSD and also on SD card without problems with reboot etc. I use the eeprom from December 8th and that is working for me.
Thank you all for all comments and ideas to guide me into the uConsole and I hope to enjoy this machine a lot!.
I managed to successfully the flash the eeprom in my new uConsole with CM5 lite 8GB using the instructions in this video.
I want to say that I’m having issues with NVME boot with my second uConsole, and it’s starting to feel like maybe there’s an issue with Trixie because I’ve done everything else. This brand SSD works on my first uConsole. EEPROM is updated. Config txt is updated. The only thing I haven’t done is cap to gen2 but I never did that on my first unit.
It can’t seem to boot without an SD. Both the SD and SSD were flashed, it booted from the SSD. It seems to reboot once fine, stays on SSD. Then all of a sudden the next reboot, either it boots off the SD if I’ve left that in, or if I take it out, black screen with no kb and nothing else, just the green light.
Getting really tired of opening the case to pop the batteries every time, help desperately needed before I corrupt this SSD.
You’ll need to do this to your CM5 lite for it to work correctly.
Hi,
I am not sure why but my Uconsole cm5 lite do not have the rpi-eeprom.
Presuming you mean the software?
You should be able to setup RaspberryPI’s own repository and install relevant software/tools from apt install.
Got the link/command from Install raspi-config in Ubuntu on Raspberry Pi
The Repository:
echo "deb http://archive.raspberrypi.org/debian/ trixie main" | sudo tee -a /etc/apt/sources.list
and the key:
wget -qO - https://archive.raspberrypi.org/debian/raspberrypi.gpg.key | sudo tee /etc/apt/trusted.gpg.d/raspberrypi.asc
then you need to install desired applications. For eeprom I guess its:
sudo apt install raspi-utils-eeprom
hi I tried to add the sources.list and it reported that it has missing keys. have did search online but all seems not to be working
Use Debian Trixie to edit the eeprom then switch to another distro if you want
if you read the rest of the link @t8923n posted that has instructions for adding the key too
yea, I did miss to add that. Good thing i linked the og source :smiley:
@deathg0d As Snipeytje wrote, you need to add the gpg key for the repository which I missed to add the command for.
But also as Rex writes, my assumption was that you are using debian Trixie?
But what image are you running..
