My gameshell has just been freezing every 3sec for 4sec after installing v0.4
Anyone else have the same issue or fix?
thx Damien
Solution for freezing: switch to golauncher and then you can swap back to the default and the freezing should stop
thx Damien
installling v0.4 you mean flash the os image to sdcard?
and could you ssh into gameshell run a command
cat /tmp/x.log
paste the result here
Wifi doesn’t seem to be working,
when scanning nothing appears.
I’m also currently using v0.3 but same problem occurs
switched to golauncher, problem solved but still no wifi?
so v0.3 has no wifi??
that’s wired
that should be a big problem
Check if your network is 5Ghz Gameshell doesn’t “see” those networks as it only supports 2.4Ghz
I have 2 2.4ghz networks and 1 5ghz and have connected to them before but now when i go to scan for wifi, the scanning box appears and quickly disappears and i cant use usb-ethernet because i need wifi in the first place.
I’m using v0.4 again because the freezing has stopped
I heard you can do a manual reset on the main board but cant find out how?
x.log
X.Org X Server 1.19.2
Release Date: 2017-03-02
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.9.0-8-armmp-lpae armv7l Debian
Current Operating System: Linux clockworkpi 5.2.0-rc4-clockworkpi-cpi3-00001-gac0d4e8 #1 SMP Mon Jun 17 18:02:55 CST 2019 armv7l
Kernel command line: console=ttyS0,115200n8 earlyprintk no_console_suspend root=/dev/mmcblk0p2 rootfstype=ext4 rootwait init=/sbin/init noinitrd panic=10
Build Date: 03 November 2018 05:53:43AM
xorg-server 2:1.19.2-1+deb9u5 (https:/ /www.debian.org/support)
Current version of pixman: 0.34.0
Before reporting problems, check http:// wiki .x.org
to make sure that you have the latest version.
Markers: (–) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/home/cpi/.local/share/xorg/Xorg.0.log”, Time: Thu Jul 4 12:07:44 2019
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
/home/cpi/launcher/sys.py/gsnotify
…/skin/default/truetype/VarelaRound-Regular.ttf
Discharging 3
(‘CheckBluetooth:no bluetooth’, (0, ‘’))
state
dbus.UInt32(0L)
Trash:
libpng warning: iCCP: known incorrect sRGB profile
1280
4
21
x11info: 12582920
BleAgent /gameshell/bleagent registered
1028912
(’/home/cpi/skins/OP1’, ‘OP1’)
Discharging 3
IconClick API: 0
Discharging 3
start Rescan
dbus says start scan…
state
dbus.UInt32(0L)
Trash:
RTNETLINK answers: No such process
dbus says scan finished
Discharging 3
Discharging 3
usb0
Discharging 3
Discharging 3
Discharging 3
IconClick API: 12
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Charging 3
Charging 3
Charging 3
Charging 3
Charging 3
Charging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
timeout, dim screen 40
Discharging 3
IconClick API: 12
Discharging 3
Discharging 3
IconClick API: 0
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 3
Discharging 2
Discharging 2
Discharging 2
Discharging 2
Discharging 2
Discharging 2
Discharging 2
Discharging 2
Discharging 2
Discharging 2
Discharging 2
Discharging 2
Discharging 2
Discharging 2
Discharging 2
IconClick: /home/cpi/apps/Menu/60_Utils/01_DinguxCommander/DinguxCommander.sh 0
cd /home/cpi/apps/Menu/6xinit: connection to X server lost
waiting for X server to shut down .(II) Server terminated successfully (0). Closing log file.
xinit: unexpected signal 15
Couldn’t get a file descriptor referring to the console
seems there is no bluetooth
run these commands
hciconfig -a
sudo rfkill list
ps aux | grep brcm
cat /proc/driver/brcmf_fw
paste all results please
how would i go about running these commands i can’t ssh into the gs
could it maybe be related airplane mode not fully activating wireless connections?
not sure, are you in airplane mode ?
can u ssh into gs with usb network?
even there is no wifi, the usb network should work
and the ip is
192.168.10.1
ssh cpi@192.168.10.1
its just hangs, keeps looking for a connection.
might be doing it wrong but ethernet is plugged into my laptop, do i need a driver for linux?
root@clockworkpi:/# hciconfig -a
root@clockworkpi:/# sudo rfkill list
0: rfkill_gpio: Bluetooth
Soft blocked: no
Hard blocked: no
root@clockworkpi:/# ps aux | grep brcm
root 847 0.0 0.0 1220 344 ? S 04:07 0:00 brcm_patchram_plus --patchram /lib/firmware/brcm/bcm43438a1.hcd --enable_hci --bd_addr B0:F1:EC:2D:07:5B --no2bytes --tosleep 5000 /dev/ttyS1
root 1844 0.0 0.0 3744 516 pts/0 S+ 04:17 0:00 grep brcm
root@clockworkpi:/# cat /proc/driver/brcmf_fw
cat: /proc/driver/brcmf_fw: No such file or directory
sorry for the long wait
depends on the results of rfkill, there is no wifi anymore, I dont know why
mine is
cpi@clockworkpi:~$ sudo rfkill list
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
I assume your os image is too old?
paste the result of uname -a ,please
Soft blocked: no
Hard blocked: no
cpi@clockworkpi:~$ uname -a
Linux clockworkpi 4.20.0-clockworkpi-cpi3-00001-gd06ec27 #5 SMP Wed Feb 27 16:33:25 CST 2019 armv7l GNU/Linux
cpi@clockworkpi:~$
wifi is gone for sure
and the kernel also did not produce the /proc/driver/brcmf_fw
It’s hard to say what is the problem, maybe the wifi chip is really down
if you in one-year warranty,send an email to help@clockworkpi.com ?
