Okay. After updating to the new image and restoring everything… I can’t play a game for 10 minutes without the GS just shutting off. (Almost like the battery is dead) so I turn it back on immediately and the battery says it’s full.
Anyone else have this issue? I was playing on GamBatte emulator if that make a difference.
Edit: left it on the launcher to see if it would shut down. No errors
Booted up a GB game with GamBatte… shit down in <5 minutes.
Trying with a GBA rom now
EDIT 2: tried with gPSP and it shut down. Never had this issue before… it’s basically unplayable.
Hasn’t happened again tho since I turned off Bluetooth. (Airplane mode, then I pushed Y to save the wifi) how do I check OS version so I can give you correct info lol
No errors so far… BT is on. GSNotify has been killed. So educated guess is it’s something to do with how BT and Notifications clash when they are ran at the same time. I dunno if that made any sense.
EDIT: I have also noticed sometimes it won’t boot up… I turn the unit on. And right before it loads the “CPI HAPPY HACKING” the unit will turn off. After a try or two it turns on, and I don’t have an issue.
It’s weird tho because it only happens now and again.
Once it boots into the OS… and I turn off Bluetooth (or kill GSNotify) it runs like a top until I turn it off myself
Edit: for instance I just started it up after 6 misfires and it fired up into the OS… everything is fine now. GSNotify works great (I turn off BT instead since I don’t use it)
