Graphical demos for the PicoCalc
I figured it would be good to have a dedicated thread for graphical demos in any language for the PicoCalc.
(Also, I wanted to post this to the FORTH on the PicoCalc thread, but the board would not allow me to make another post there as I had made the three last posts, but when I tried to modify an existing post to include this it did not show the thread as having new content.)
A while back I wrote a raytracing demo for the Tufty 2040, which I have now ported to the PicoCalc with the RP2350 using hardware single-precision floating point (the original program used S15.16 fixed point, which was non-ideal for a number of reasons). The code can be gotten from zeptoforth/test/rp2350/picocalc_raytracing_ground_light.fs at master · tabemann/zeptoforth · GitHub.
Here is a screenshot:
And here is the full source code:
\ Copyright (c) 2023-2025 Travis Bemann
\ Permission is hereby granted, free of charge, to any person obtaining a copy
\ of this software and associated documentation files (the "Software"), to deal
\ in the Software without restriction, including without limitation the rights
\ to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
\ copies of the Software, and to permit persons to whom the Software is
\ furnished to do so, subject to the following conditions:
\ The above copyright notice and this permission notice shall be included in
\ all copies or substantial portions of the Software.
\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
\ IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
\ FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
\ AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
\ LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
\ OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
\ SOFTWARE.
begin-module raytracing
  oo import
  pixmap8 import
  st7365p-8-common import
  float32 import
  picocalc-term import
  \ Columns
  320 constant my-cols
  \ Rows
  320 constant my-rows
  \ Three-element constant
  : 3constant ( a b c "name" -- )
    : rot lit, swap lit, lit, postpone ;
  \ Background color
  0.5e0 0e0 0e0 3constant background-color
  \ Shadow color
  0e0 0e0 0e0 3constant shadow-color
  \ Eye coordinate
  0e0 0e0 3.20e0 3constant eye-coord
  \ Light coordinate
  -50e0 value light-x
  50e0 value light-y
  25e0 value light-z
  : light-coord light-x light-y light-z ;
\  -50e0 50e0 0e0 3constant light-coord
  \ Find an entity along a line
  defer find-entity ( sx sy sz vx vy vz exclude -- entity distance hit? )
  \ Entity class
  <object> begin-class <entity>
    \ Is there a hit?
    method point-hit? ( sx sy sz vx vy vz self -- distance hit? )
    \ Get point color
    method point-color ( hx hy hz vx vy vz self -- r g b )
  end-class
  \ Implement entity class
  <entity> begin-implement
  end-implement
  \ Sphere class
  <entity> begin-class <sphere>
    cell member sphere-radius
    cell member sphere-x
    cell member sphere-y
    cell member sphere-z
  end-class
  \ Add two vectors
  : vect+ { ax ay az bx by bz -- cx cy cz } ax bx v+ ay by v+ az bz v+ ;
  \ Subtract two vectors
  : vect- { ax ay az bx by bz -- cx cy cz } ax bx v- ay by v- az bz v- ;
  \ Multiply a vector by a scalar
  : vect* { ax ay az n -- bx by bz } ax n v* ay n v* az n v* ;
  \ Get the dot product of two vectors
  : dot { ax ay az bx by bz -- dot } ax bx v* ay by v* az bz v* v+ v+ ;
  \ Get the cross product of two vectors
  : cross { ax ay az bx by bz -- cx cy cz }
    ay bz v* az by v* v- az bx v* ax bz v* v- ax by v* ay bx v* v-
  \ Get the magnitude of a vector
  : mag { x y z -- magnitude } x x v* y y v* z z v* v+ v+ vsqrt ;
  \ Get the unit vector of a vector
  : unit { x y z -- ux uy uz }
    x y z mag { dist } x dist v/ y dist v/ z dist v/
  \ Get the distance between two points
  : dist ( ax ay az bx by bz -- distance ) vect- mag ;
  \ Get the minimum root of an ax^2 + bx + c equation
  : minroot { a b c -- x found? }
    a v0= if
      c vnegate b v/ true
    else
      b b v* 4e0 a v* c v* v- { disc }
      disc v0>= if
        disc vsqrt { disc' }
        2e0 a v* { 2a }
        b vnegate disc' v+ b vnegate disc' v- vmin 2a v/ true
      else
        0e0 false
      then
    then
  \ Implement sphere class
  <sphere> begin-implement
    \ Constructor
    :noname { radius x y z self -- }
      self <entity>->new
      radius self sphere-radius !
      x self sphere-x !
      y self sphere-y !
      z self sphere-z !
    ; define new
    \ Is there a hit?
    :noname { sx sy sz vx vy vz self -- distance hit? }
      sx sy sz self sphere-x @ self sphere-y @ self sphere-z @ vect-
      { osx osy osz }
      1e0 \ vx vy vz vx vy vz dot
      osx osy osz vx vy vz dot 2e0 v*
      osx osy osz osx osy osz dot abs self sphere-radius @ dup v* v-
      minroot
    ; define point-hit?
  end-implement
  \ The colored sphere class
  <sphere> begin-class <colored-sphere>
    cell member sphere-g
    cell member sphere-b
  end-class
  \ Implement the colored sphere class
  <colored-sphere> begin-implement
    \ Constructor
    :noname { radius x y z r g b self -- }
      radius x y z self <sphere>->new
      r self sphere-r !
      g self sphere-g !
      b self sphere-b !
    ; define new
    \ Get point color
    :noname { hx hy hz vx vy vz self -- r g b }
      self sphere-x @ self sphere-y @ self sphere-z @ hx hy hz vect- unit
      { nx ny nz }
      hx hy hz light-coord vect- unit { lx ly lz }
      hx hy hz lx ly lz -1e0 vect* 0 find-entity nip nip not if
        nx ny nz lx ly lz dot 0e0 vmax 1e0 vmin { lambert }
        self sphere-r @ self sphere-g @ self sphere-b @ lambert vect*
      else
        shadow-color
      then
    ; define point-color
  end-implement
  \ The mirror sphere class
  <sphere> begin-class <mirror-sphere>
    cell member mirror-sphere-r
    cell member mirror-sphere-g
    cell member mirror-sphere-b
    cell member mirror-sphere-a
  end-class
  \ Implement the mirror sphere class
  <mirror-sphere> begin-implement
    \ Constructor
    :noname { radius x y z r g b a self -- }
      r a v* self mirror-sphere-r !
      g a v* self mirror-sphere-g !
      b a v* self mirror-sphere-b !
      a self mirror-sphere-a !
    ; define new
    \ Get point color
      { nx ny nz }
      vx vy vz nx ny nz nx ny nz vx vy vz dot vect* 2e0 vect* vect-
      unit { rx ry rz }
      hx hy hz rx ry rz self find-entity if { entity distance }
        rx ry rz distance vect* hx hy hz vect+ rx ry rz entity point-color
      else
        2drop background-color
      then
      { r g b }
        self mirror-sphere-r @
        self mirror-sphere-g @
        self mirror-sphere-b @ lambert vect*
      else
        shadow-color
      then
      { mr mg mb }
      self mirror-sphere-a @ { a } 1e0 a v- { a' }
      r a' v* mr v+ g a' v* mg v+ b a' v* mb v+
  end-implement
  \ Plane class
  <entity> begin-class <plane>
    cell member plane-x
    cell member plane-y
    cell member plane-z
    cell member plane-nx
    cell member plane-ny
    cell member plane-nz
  end-class
  \ Implement plane class
  <plane> begin-implement
    \ Constructor
    :noname { x y z nx ny nz self -- }
      self <entity>->new
      nx ny nz unit to nz to ny to nx
      x self plane-x !
      y self plane-y !
      z self plane-z !
      nx self plane-nx !
      ny self plane-ny !
      nz self plane-nz !
    ; define new
    \ Is there a hit?
      self plane-nx @ self plane-ny @ self plane-nz @ { nx ny nz }
      nx ny nz vx vy vz dot { denom }
      denom v0<> if
        self plane-x @ self plane-y @ self plane-z @ sx sy sz vect- nx ny nz dot
        denom v/ { n }
        n v0>= n 16384e0 v< and if n true else 0e0 false then
      else
        0 false
      then
    ; define point-hit?
  end-implement
  \ Tiled plane
  <plane> begin-class <tiled-plane>
    cell member plane-ax
    cell member plane-ay
    cell member plane-az
    cell member plane-bx
    cell member plane-by
    cell member plane-bz
    cell member plane-r0
    cell member plane-g0
    cell member plane-b0
    cell member plane-r1
    cell member plane-g1
    cell member plane-b1
    cell member plane-tile-size
  end-class
  \ Implement tiled plane
  <tiled-plane> begin-implement
    \ Constructor
    :noname { x y z nx ny nz ax ay az r0 g0 b0 r1 g1 b1 tile-size self -- }
      x y z nx ny nz self <plane>->new
      ax ay az unit to az to ay to ax
      ax self plane-ax !
      ay self plane-ay !
      az self plane-az !
      self plane-nx @ self plane-ny @ self plane-nz @ ax ay az cross
      self plane-bz ! self plane-by ! self plane-bx !
      r0 self plane-r0 !
      g0 self plane-g0 !
      b0 self plane-b0 !
      r1 self plane-r1 !
      g1 self plane-g1 !
      b1 self plane-b1 !
      tile-size self plane-tile-size !
    ; define new
    \ Get point color
      light-coord { lx' ly' lz' }
      lx' hx v- dup v*
      ly' hy v- dup v* v+
      lz' hz v- dup v* v+ vsqrt 180e0 v>= if
        shadow-color exit
      then
      hx hy hz self plane-x @ self plane-y @ self plane-z @ vect- { cx cy cz }
      self plane-ax @ self plane-ay @ self plane-az @ cx cy cz dot { dx }
      self plane-bx @ self plane-by @ self plane-bz @ cx cy cz dot { dy }
      dx self plane-tile-size @ v/ v>f64 floor { dx' }
      dy self plane-tile-size @ v/ v>f64 floor { dy' }
      dx' 2 mod 0= dy' 2 mod 0= xor if
        self plane-r0 @ self plane-g0 @ self plane-b0 @
      else
        self plane-r1 @ self plane-g1 @ self plane-b1 @
      then
      { r g b }
      hx hy hz lx' ly' lz'  vect- unit { lx ly lz }
        r g b lambert vect*
      else
        shadow-color
      then
  end-implement
  <colored-sphere> class-size buffer: my-sphere-0
  <colored-sphere> class-size buffer: my-sphere-1
  <colored-sphere> class-size buffer: my-sphere-2
  <colored-sphere> class-size buffer: my-sphere-3
  <mirror-sphere> class-size buffer: my-sphere-4
  <tiled-plane> class-size buffer: my-plane
  create my-entities
  my-sphere-0 ,
  my-sphere-1 ,
  my-sphere-2 ,
  my-sphere-3 ,
  my-sphere-4 ,
  my-plane ,
  6 constant entity-count
  \ Find the closest, if any, entity
  :noname { sx sy sz vx vy vz exclude -- entity distance hit? }
    0 0 false { found-entity distance hit? }
    entity-count 0 ?do
      my-entities i cells + @ { entity }
      entity exclude <> if
        sx sy sz vx vy vz entity point-hit? if { entity-distance }
          hit? not entity-distance distance v< or entity-distance v0> and if
            entity to found-entity
            entity-distance to distance
            true to hit?
          then
        else
          drop
        then
      then
    loop
  ; is find-entity
  \ Send a ray
  : send-ray { sx sy sz vx vy vz -- r g b }
    sx sy sz vx vy vz 0 find-entity if { entity distance }
      vx vy vz distance vect* sx sy sz vect+ vx vy vz entity point-color
    else
      drop drop background-color
    then
  \ Convert a coordinate
  : convert-coord { x y -- x' y' }
    x [ my-cols 2 / ] literal - n>v 100e0 v/
    y negate [ my-rows 2 / ] literal + n>v 100e0 v/
  \ Color dithering table
  create color-table
  0.8e0 , 1e0 , 1.2e0 , 1e0 , 0.8e0 , 1e0 , 1.2e0 , 1e0 ,
  1e0 , 1.1e0 , 1e0 , 0.9e0 , 1e0 , 1.1e0 , 1e0 , 0.9e0 ,
  1.2e0 , 1e0 , 0.8e0 , 1e0 , 1.2e0 , 1e0 , 0.8e0 , 1e0 ,
  1e0 , 0.9e0 , 1e0 , 1.1e0 , 1e0 , 0.9e0 , 1e0 , 1.1e0 ,
  \ Convert a color
  : convert-color { r g b x y -- color }
    x 3 and y 3 and 8 * + cells color-table + @ { factor }
    r 255e0 v* factor v* vround-zero v>n 0 max 255 min
    g 255e0 v* factor v* vround-zero v>n 0 max 255 min
    b 255e0 v* factor v* vround-zero v>n 0 max 255 min rgb8
  \ Draw world
  : draw-world ( -- )
    page
    [: { display }
      display clear-pixmap
      display update-display
    ;] with-term-display
    1e0 2.5e0 2.5e0 -6.4e0 0e0 1e0 0e0 <colored-sphere> my-sphere-0 init-object
    1.5e0 0e0 -1e0 -4.8e0 1e0 0e0 0e0 <colored-sphere> my-sphere-1 init-object
    2e0 -2.5e0 3e0 -10e0 0e0 0e0 1e0 <colored-sphere> my-sphere-2 init-object
    0.75e0 -2e0 1e0 -3.6e0 0e0 1e0 1e0 <colored-sphere> my-sphere-3 init-object
    1.5e0 0e0 2.5e0 -7.5e0 1e0 0e0 1e0 0.25e0 <mirror-sphere> my-sphere-4 init-object
    0e0 -20e0 0e0 0e0 -1e0 0e0 1e0 0e0 0e0 0.75e0 0e0 0e0 0e0 0.75e0 0e0 10e0
    <tiled-plane> my-plane init-object
    my-rows 0 ?do
      i [: { y display }
        my-cols 0 ?do
          i y convert-coord 0e0 eye-coord vect- unit { vx vy vz }
          eye-coord vx vy vz send-ray i y convert-color
          i y display draw-pixel-const
        loop
    loop
    begin key? until
    key drop
end-module
That’s a great idea!
That’s a really neat demo. If I didn’t know otherwise I wouldn’t have guessed it was done in MMBasic.
Here’s a relatively (for basic) high performance blocks game:
i would love to see a video!
I get a “if without then” error on line 522
The if continues at line 523 but my mmbasic does not compute it.
Is there an option to enable that? Do need another version of picomite?
I had the same problem. I edited that line continuation back to one line. Here’s the corrected version:
' PicoCalc Blocks Game (with FRAMEBUFFER)
' - True double buffering using FRAMEBUFFER + LAYER
' - Static background on F, dynamic sprites on L
' - FRAMEBUFFER MERGE for flicker-free display
OPTION EXPLICIT
' ---- Tunables ----
CONST PAD_ACCEL = 2.0
CONST PAD_DECAY = 0.88
CONST PAD_MAX   = 24
CONST BRADIUS   = 6
CONST BALL_SPEED_INIT = 3.0
CONST BALL_SPEED_ACCEL_PER_SEC = 0.03
CONST PADDLE_KICK = 0.2
CONST TICK_MS   = 38
' ---- Screen & colors ----
CONST W% = MM.HRES
CONST H% = MM.VRES
CONST HUDH% = 18
CONST COL_BG%     = RGB(BLACK)
CONST COL_TXT%    = RGB(WHITE)
CONST COL_BORDER% = RGB(MYRTLE)
CONST COL_PAD%    = RGB(GREEN)
CONST COL_BALL%   = RGB(RED)
' ---- Block layout ----
CONST LEVELS% = 10
CONST BLOCK_ROWS% = 5
CONST BLOCK_COLS% = 8
CONST BLOCK_W% = 35
CONST BLOCK_H% = 12
CONST BLOCK_GAP% = 4
CONST BLOCK_TOP% = 40
' ---- Block types ----
CONST BLOCK_RED% = 30        ' 30 points, 1 hit
CONST BLOCK_ORANGE% = 20     ' 20 points, 1 hit
CONST BLOCK_YELLOW_FULL% = 12   ' 10 points, 2 hits (full health)
CONST BLOCK_YELLOW_DMG% = 11    ' 10 points, 1 hit left (damaged)
CONST BLOCK_BLUE% = 99       ' Indestructible, no points
' ---- Editable board layout (R=Red, O=Orange, Y=Yellow, B=Blue/Indestructible, 0=Empty) ----
' Level 1 - Easy warmup
DATA "0","0","0","0","0","0","0","0"
DATA "0","0","R","R","R","R","0","0"
DATA "0","R","R","Y","Y","R","R","0"
DATA "R","R","R","R","R","R","R","R"
' Level 2 - Getting harder
DATA "0","O","O","O","O","O","O","0"
DATA "Y","Y","Y","Y","Y","Y","Y","Y"
' Level 3 - Mixed blocks
DATA "R","R","O","O","O","O","R","R"
DATA "R","O","Y","Y","Y","Y","O","R"
DATA "O","Y","Y","Y","Y","Y","Y","O"
' Level 4 - Pyramid
DATA "0","0","0","R","R","0","0","0"
DATA "0","0","O","O","O","O","0","0"
DATA "0","Y","Y","Y","Y","Y","Y","0"
DATA "0","0","0","B","B","0","0","0"
' Level 5 - Box
DATA "R","0","0","0","0","0","0","R"
DATA "R","0","B","B","B","B","0","R"
' Level 6 - Corners
DATA "R","R","0","0","0","0","O","O"
DATA "R","Y","0","Y","Y","0","Y","O"
DATA "0","0","B","Y","Y","B","0","0"
DATA "Y","Y","0","B","B","0","Y","Y"
DATA "O","O","0","0","0","0","R","R"
' Level 7 - Wings
DATA "R","0","0","Y","Y","0","0","R"
DATA "O","O","B","Y","Y","B","O","O"
DATA "Y","Y","Y","B","B","Y","Y","Y"
DATA "Y","Y","B","O","O","B","Y","Y"
' Level 8 - Checkers
DATA "R","O","R","O","R","O","R","O"
DATA "Y","B","Y","B","Y","B","Y","B"
DATA "O","Y","O","Y","O","Y","O","Y"
DATA "B","Y","B","Y","B","Y","B","Y"
' Level 9 - Cross
DATA "0","0","O","B","B","O","0","0"
' Level 10 - Final Challenge
DATA "R","B","O","B","O","B","O","R"
DATA "B","Y","Y","0","0","Y","Y","B"
DATA "O","Y","B","Y","Y","B","Y","O"
' ---- State ----
DIM INTEGER currentLevel%=1
DIM FLOAT bx!, by!
DIM INTEGER br%
DIM FLOAT vx!, vy!
DIM INTEGER lastAccelTime%
DIM px!, py!, pw%, ph%, pvx!
DIM INTEGER score%, lives%
DIM INTEGER ballLaunched%
DIM INTEGER frames%, t0%
DIM fps$
DIM k$
DIM INTEGER blocks%(BLOCK_ROWS%-1, BLOCK_COLS%-1)
DIM INTEGER totalBlocks%, blocksLeft%
DIM FLOAT hitPos!, angle!
DIM INTEGER explosionActive%, explosionX%, explosionY%, explosionFrame%, explosionColor%
DIM INTEGER oldScore%, oldLives%
DIM INTEGER lastHitRow%, lastHitCol%, hitTimeout%
DIM INTEGER screenshotNum%
' ---- Beeps ----
SUB BeepServe(): PLAY TONE 700,700 : PAUSE 40 : PLAY STOP : END SUB
SUB BeepPaddle(): PLAY TONE 800,800 : PAUSE 20 : PLAY STOP : END SUB
SUB BeepWall(): PLAY TONE 600,600 : PAUSE 20 : PLAY STOP : END SUB
SUB BeepBlock(): PLAY TONE 1200,1200 : PAUSE 25 : PLAY STOP : END SUB
SUB BeepMiss(): PLAY TONE 200,200 : PAUSE 80 : PLAY STOP : END SUB
SUB ResetBall()
  ' Reset ball to paddle position (not launched)
  ballLaunched% = 0
  bx! = px! + pw%/2 - br%
  by! = py! - 2*br% - 2
  IF RND > 0.5 THEN vx! = BALL_SPEED_INIT ELSE vx! = -BALL_SPEED_INIT
  vy! = -BALL_SPEED_INIT
  lastAccelTime% = TIMER
  hitTimeout% = 0
END SUB
SUB DestroyBlock(r%, c%, points%)
  ' Destroy a block with explosion and award points
  LOCAL bx%, by%
  bx% = GetBlockX(c%)
  by% = GetBlockY(r%)
  TriggerExplosion bx%, by%, BLOCK_W%, BLOCK_H%, GetBlockColor(blocks%(r%, c%))
  blocks%(r%, c%) = 0
  blocksLeft% = blocksLeft% - 1
  score% = score% + points%
  EraseBlock r%, c%
END SUB
SUB Draw3DHighlight(x%, y%, w%, h%)
  ' Draw white highlight on top and left edges for 3D effect
  LINE x%, y%, x%+w%-1, y%, , RGB(WHITE)  ' Top edge
  LINE x%, y%, x%, y%+h%-1, , RGB(WHITE)  ' Left edge
END SUB
' ---- Drawing helpers ----
SUB DrawHUD()
  LOCAL s$
  s$ = "L" + STR$(currentLevel%) + " Score " + STR$(score%) + " Lives " + STR$(lives%)
  TEXT 6, 3, s$, "LT", , , COL_TXT%, COL_BG%
  IF fps$ <> "" THEN
    TEXT W%-4, 3, fps$, "RT", , , COL_TXT%, COL_BG%
  END IF
END SUB
SUB DrawPaddleAt(x%, y%)
  ' Draw main paddle
  BOX x%, y%, pw%, ph%, 0, , COL_PAD%
  Draw3DHighlight x%, y%, pw%, ph%
END SUB
SUB DrawBallAt(x%, y%)
  LOCAL cx%, cy%
  cx% = x% + br%
  cy% = y% + br%
  ' Draw main ball
  CIRCLE cx%, cy%, br%, 0, 1.0, , COL_BALL%
  ' Draw small white highlight on top-left for 3D effect
  CIRCLE cx%-2, cy%-2, 1, 0, 1.0, , RGB(WHITE)
END SUB
SUB TriggerExplosion(x%, y%, w%, h%, blockColor%)
  ' Set explosion state - will be drawn in main loop
  explosionActive% = 1
  explosionX% = x% + w%/2
  explosionY% = y% + h%/2
  explosionFrame% = 0
  explosionColor% = blockColor%
END SUB
SUB DrawExplosion()
  LOCAL size%
  IF explosionActive% = 0 THEN EXIT SUB
  ' Draw explosion animation on layer
  size% = (explosionFrame% + 1) * 4
  ' Expanding circle
  CIRCLE explosionX%, explosionY%, size%, 0, 1.0, , explosionColor%
  ' Star burst lines that grow with frame
  LINE explosionX%-size%, explosionY%, explosionX%+size%, explosionY%, , explosionColor%
  LINE explosionX%, explosionY%-size%, explosionX%, explosionY%+size%, , explosionColor%
  IF explosionFrame% > 0 THEN
    LOCAL offset%
    offset% = size% * 0.7
    LINE explosionX%-offset%, explosionY%-offset%, explosionX%+offset%, explosionY%+offset%, , explosionColor%
    LINE explosionX%-offset%, explosionY%+offset%, explosionX%+offset%, explosionY%-offset%, , explosionColor%
  END IF
  ' Advance animation
  explosionFrame% = explosionFrame% + 1
  IF explosionFrame% > 2 THEN
    explosionActive% = 0  ' Animation done
  END IF
END SUB
SUB InitBlocks()
  LOCAL r%, c%, blockChar$, skipRows%, i%
  totalBlocks% = 0
  RESTORE  ' Reset DATA pointer to start
  ' Skip to current level's data
  skipRows% = (currentLevel% - 1) * BLOCK_ROWS% * BLOCK_COLS%
  FOR i% = 1 TO skipRows%
    READ blockChar$
  NEXT
  ' Read current level
  FOR r% = 0 TO BLOCK_ROWS%-1
    FOR c% = 0 TO BLOCK_COLS%-1
      READ blockChar$
      ' Convert character to block type
      SELECT CASE blockChar$
        CASE "R"
          blocks%(r%, c%) = BLOCK_RED%
          totalBlocks% = totalBlocks% + 1
        CASE "O"
          blocks%(r%, c%) = BLOCK_ORANGE%
        CASE "Y"
          blocks%(r%, c%) = BLOCK_YELLOW_FULL%
        CASE "B"
          blocks%(r%, c%) = BLOCK_BLUE%
          ' Don't count indestructible blocks in total
        CASE ELSE
          blocks%(r%, c%) = 0  ' Empty space
      END SELECT
    NEXT
  NEXT
  blocksLeft% = totalBlocks%
END SUB
FUNCTION GetBlockX(c%) AS INTEGER
  GetBlockX = c% * (BLOCK_W% + BLOCK_GAP%) + BLOCK_GAP%
END FUNCTION
FUNCTION GetBlockY(r%) AS INTEGER
  GetBlockY = BLOCK_TOP% + r% * (BLOCK_H% + BLOCK_GAP% + 3)
END FUNCTION
FUNCTION GetBlockColor(blockType%) AS INTEGER
  SELECT CASE blockType%
    CASE BLOCK_RED%
      GetBlockColor = RGB(RED)
    CASE BLOCK_ORANGE%
      GetBlockColor = RGB(RUST)
    CASE BLOCK_YELLOW_FULL%
      GetBlockColor = RGB(YELLOW)
    CASE BLOCK_YELLOW_DMG%
      GetBlockColor = RGB(BROWN)  ' Darker yellow for damaged
    CASE BLOCK_BLUE%
      GetBlockColor = RGB(BLUE)
    CASE ELSE
      GetBlockColor = RGB(CYAN)
  END SELECT
END FUNCTION
SUB DrawBlocks()
  LOCAL r%, c%, bx%, by%, blockType%
      blockType% = blocks%(r%, c%)
      IF blockType% > 0 THEN
        bx% = GetBlockX(c%)
        by% = GetBlockY(r%)
        BOX bx%, by%, BLOCK_W%, BLOCK_H%, 0, , GetBlockColor(blockType%)
        BOX bx%, by%, BLOCK_W%, BLOCK_H%, 1, COL_BORDER%
        Draw3DHighlight bx%+1, by%+1, BLOCK_W%-2, BLOCK_H%-1
      END IF
    NEXT
  NEXT
END SUB
SUB EraseBlock(r%, c%)
  LOCAL bx%, by%
  bx% = GetBlockX(c%)
  by% = GetBlockY(r%)
  FRAMEBUFFER WRITE F
  BOX bx%, by%, BLOCK_W%, BLOCK_H%, 0, , COL_BG%
  FRAMEBUFFER WRITE L  ' Restore to layer
END SUB
FUNCTION CheckBlockCollision(ballX%, ballY%, ballR%) AS INTEGER
  LOCAL r%, c%, bx%, by%, bx2%, by2%, blockType%
  LOCAL ballLeft%, ballRight%, ballTop%, ballBot%
  ballLeft% = ballX%
  ballRight% = ballX% + 2*ballR%
  ballTop% = ballY%
  ballBot% = ballY% + 2*ballR%
  ' Decrement hit timeout
  IF hitTimeout% > 0 THEN hitTimeout% = hitTimeout% - 1
        bx% = GetBlockX(c%)
        by% = GetBlockY(r%)
        bx2% = bx% + BLOCK_W%
        by2% = by% + BLOCK_H%
        ' AABB collision test
        IF ballRight% >= bx% AND ballLeft% <= bx2% AND ballBot% >= by% AND ballTop% <= by2% THEN
          ' Check if this is the same block hit recently
          IF hitTimeout% > 0 AND r% = lastHitRow% AND c% = lastHitCol% THEN
            ' Still in timeout - ignore this block completely, check others
            ' Don't return, just continue to next block
          ELSE
            ' Record this hit for timeout
            lastHitRow% = r%
            lastHitCol% = c%
            hitTimeout% = 15
          ' Handle different block types
          IF blockType% = BLOCK_BLUE% THEN
            ' Blue block - indestructible, just bounce
            CheckBlockCollision = 1
            EXIT FUNCTION
          ELSE IF blockType% = BLOCK_YELLOW_FULL% THEN
            ' Yellow block at full health - damage it, no points yet
            blocks%(r%, c%) = BLOCK_YELLOW_DMG%
            FRAMEBUFFER WRITE F
            BOX bx%, by%, BLOCK_W%, BLOCK_H%, 0, , GetBlockColor(BLOCK_YELLOW_DMG%)
            FRAMEBUFFER WRITE L
          ELSE IF blockType% = BLOCK_YELLOW_DMG% THEN
            ' Yellow block damaged - destroy it, award 10 points
            DestroyBlock r%, c%, 10
          ELSE IF blockType% = BLOCK_ORANGE% THEN
            ' Orange block - destroy, award 20 points
            DestroyBlock r%, c%, 20
          ELSE IF blockType% = BLOCK_RED% THEN
            ' Red block - destroy, award 30 points
            DestroyBlock r%, c%, 30
          END IF
          EXIT FUNCTION
          END IF
        END IF
      END IF
    NEXT
  NEXT
  CheckBlockCollision = 0
END FUNCTION
' ---- Init ----
pw% = W% \ 6 : IF pw% < 30 THEN pw% = 30  ' (no MAX(); clamp via IF)
ph% = 6
px! = (W% - pw%) / 2
py! = H% - (ph% + 6)
pvx! = 0
br% = BRADIUS
bx! = W% \ 2 : by! = H% \ 2
score% = 0 : lives% = 3
oldScore% = 0 : oldLives% = 3
ballLaunched% = 0
hitTimeout% = 0
lastHitRow% = -1
lastHitCol% = -1
screenshotNum% = 0
frames% = 0 : t0% = TIMER
fps$ = ""
InitBlocks
' ---- Setup Framebuffers ----
FRAMEBUFFER CREATE           ' Create framebuffer F
FRAMEBUFFER LAYER RGB(BLACK) ' Create layer L with black as transparent
' Draw static background to F
FRAMEBUFFER WRITE F
CLS COL_BG%
DrawBlocks
' Draw initial sprites to layer L
FRAMEBUFFER WRITE L
CLS RGB(BLACK)  ' Clear layer with transparent color
DrawPaddleAt INT(px!), INT(py!)
DrawBallAt INT(bx!), INT(by!)
' Draw HUD to framebuffer F
FRAMEBUFFER WRITE F
DrawHUD
' Start timed continuous merge (updates at TICK_MS rate)
FRAMEBUFFER MERGE RGB(BLACK), R, TICK_MS
BeepServe
' ---- Main loop ----
DO
  ' INPUT (Left=130, Right=131, ESC=27, Space=32, P/p=80/112; 1..8 tones)
  k$ = INKEY$
  IF k$ <> "" THEN
    SELECT CASE ASC(k$)
      CASE 130: pvx! = pvx! - PAD_ACCEL
      CASE 131: pvx! = pvx! + PAD_ACCEL
      CASE  32: IF ballLaunched% = 0 THEN ballLaunched% = 1 : BeepServe
      CASE  27: EXIT DO
      CASE 80, 112: ' P or p key - screenshot
        ' Pause rendering and capture full scene
        FRAMEBUFFER MERGE RGB(BLACK), A  ' Abort continuous merge
        PAUSE 50
        FRAMEBUFFER WRITE N
        CLS COL_BG%
        DrawBlocks
        DrawHUD
          TEXT W%\2, H%\2, "Hit SPACE to start", "CT", , , COL_TXT%, RGB(BLACK)
        END IF
        PAUSE 50
        screenshotNum% = screenshotNum% + 1
        SAVE IMAGE "screen" + STR$(screenshotNum%) + ".bmp"
        PAUSE 50
        FRAMEBUFFER WRITE L
        FRAMEBUFFER MERGE RGB(BLACK), R, TICK_MS  ' Resume continuous merge
        PLAY TONE 1200,1200 : PAUSE 30 : PLAY STOP  ' Confirmation beep
      CASE  49 TO 56
        PLAY TONE 220 * (2 ^ ((ASC(k$)-48)/12.0)), 0 : PAUSE 60 : PLAY STOP
    END SELECT
  ENDIF
  ' ---- Paddle physics ----
  pvx! = pvx! * PAD_DECAY
  IF pvx! >  PAD_MAX THEN pvx! =  PAD_MAX
  IF pvx! < -PAD_MAX THEN pvx! = -PAD_MAX
  px! = px! + pvx!
  IF px! < 0 THEN px! = 0 : IF pvx! < 0 THEN pvx! = 0
  IF px! > (W% - pw%) THEN px! = W% - pw% : IF pvx! > 0 THEN pvx! = 0
  ' ---- Ball physics ----
    ' Ball follows paddle until launched
  ELSE
    ' Gradually increase speed over time (once per second)
    IF TIMER - lastAccelTime% >= 1000 THEN
      IF vy! > 0 THEN
        vy! = vy! + BALL_SPEED_ACCEL_PER_SEC
      ELSE
        vy! = vy! - BALL_SPEED_ACCEL_PER_SEC
      END IF
      lastAccelTime% = lastAccelTime% + 1000
    END IF
    bx! = bx! + vx!
    by! = by! + vy!
  END IF
  ' Elastic wall bounces
  IF INT(bx!) < 0 THEN
    bx! = 0
    vx! = -vx!
    hitTimeout% = 0
    BeepWall
  END IF
  IF INT(bx!) > W% - 2*br% THEN
    bx! = W% - 2*br%
    vx! = -vx!
    hitTimeout% = 0
    BeepWall
  END IF
  IF INT(by!) < HUDH% + 1 THEN
    by! = HUDH% + 1
    vy! = -vy!
    hitTimeout% = 0
    BeepWall
  END IF
  ' ---- Block collision (elastic) ----
  IF ballLaunched% = 1 AND CheckBlockCollision(INT(bx!), INT(by!), br%) = 1 THEN
    vy! = -vy!
    BeepBlock
  END IF
  ' ---- Paddle collision (angle variation based on hit position) ----
  IF ballLaunched% = 1 AND INT(by!) + 2*br% >= INT(py!) AND INT(by!) <= INT(py!) + ph% AND INT(bx!) + 2*br% >= INT(px!) AND INT(bx!) <= INT(px!) + pw% THEN
    by! = INT(py!) - 2*br%
    vy! = -vy!
    hitTimeout% = 0
    ' Calculate where on paddle ball hit (0=left edge, 1=right edge, 0.5=center)
    hitPos! = (bx! + br% - px!) / pw%
    IF hitPos! < 0 THEN hitPos! = 0
    IF hitPos! > 1 THEN hitPos! = 1
    ' Adjust horizontal velocity based on hit position
    ' Center hits = straighter, edge hits = sharper angle
    angle! = (hitPos! - 0.5) * 5.0  ' Range: -2.5 to +2.5
    vx! = vx! + angle! + pvx! * PADDLE_KICK
    score% = score% + 1
    BeepPaddle
  ENDIF
  ' ---- Miss (lose a life) ----
  IF ballLaunched% = 1 AND INT(by!) > H% - 2*br% THEN
    lives% = lives% - 1
    BeepMiss
    IF lives% > 0 THEN
      ' Reset ball to paddle (not launched)
      ResetBall
      BeepServe
    ELSE
      ' Game over
      FRAMEBUFFER CLOSE
      FRAMEBUFFER WRITE N
      CLS COL_BG%
      PRINT "GAME OVER!  Score="; score%
      END
    END IF
  ENDIF
  ' ---- Level complete / Win condition ----
  IF blocksLeft% = 0 THEN
    IF currentLevel% < LEVELS% THEN
      ' Advance to next level
      currentLevel% = currentLevel% + 1
      ResetBall
      ' Redraw static background with new level
      FRAMEBUFFER WRITE F
      CLS COL_BG%
      InitBlocks
      DrawBlocks
      DrawHUD
      oldScore% = score%  ' Force HUD update on next frame
      oldLives% = lives%
      BeepServe
    ELSE
      ' All levels complete!
      FRAMEBUFFER CLOSE
      FRAMEBUFFER WRITE N
      CLS COL_BG%
      PRINT "YOU WIN ALL LEVELS!  Score="; score%; "  Lives: "; lives%
      END
    END IF
  END IF
  ' ---- Redraw layer with new sprite positions ----
  FRAMEBUFFER SYNC
  FRAMEBUFFER WRITE L
  DrawExplosion     ' Draw explosion animation if active
  ' Show start message when ball not launched
  END IF
  ' ---- Update HUD only on score/lives change ----
  IF score% <> oldScore% OR lives% <> oldLives% THEN
    oldScore% = score%
    oldLives% = lives%
    FRAMEBUFFER WRITE F
    DrawHUD
  END IF
  ' ---- Update FPS display ----
  frames% = frames% + 1
  IF TIMER - t0% >= 1000 THEN
    fps$ = STR$(frames%) + " FPS"
    frames% = 0
    t0% = TIMER
    FRAMEBUFFER WRITE F
    DrawHUD
  END IF
  ' No PAUSE needed - continuous merge handles timing
LOOP
' ---- Cleanup ----
FRAMEBUFFER CLOSE
FRAMEBUFFER WRITE N  ' Back to normal screen
CLS COL_BG%
PRINT "Thanks for playing!  Final Score: "; score%
END
OPTION CONTINUATION LINES ON
I pushed a version that has OPTION CONTINUATION LINES ON, I think this was just set locally on my build by other programs. Sorry about that.
I wrote a demo to display a Ulam spiral, a representation of the prime numbers in the format of a square spiral where pixels that are set represent prime numbers, in which the distribution of prime numbers seems oddly ordered, as they often seem to line up in diagonal lines.
Here is a screenshot of the demo (the little block in the upper left is the cursor, not part of the spiral):
The source code, which can be gotten from zeptoforth/test/rp_common/picocalc_ulam.fs at master · tabemann/zeptoforth · GitHub
is reproduced here as:
\ Copyright (c) 2025 Travis Bemann
\ SOFTWARE.
begin-module ulam
  pixmap8 import
  : sieve-size ( u -- bytes ) 1- 2 / 8 align 8 / ;
  : sieve-set? { u sieve -- flag }
    u 2 < if false exit then
    u 2 = if true exit then
    u 1- 1 rshift dup 7 and bit swap 3 rshift sieve + cbit@
  : clear-sieve { u sieve -- }
    u 1 and 0= if exit then
    u 1- 1 rshift dup 7 and bit swap 3 rshift sieve + cbic!
  : sieve { u sieve -- }
    sieve u sieve-size $FF fill
    u 3 < if exit then
    u 3 ?do
      i sieve sieve-set? if
        i dup + u <= if
          u 1+ i dup + ?do
            i sieve clear-sieve
          j +loop
        then
      then
    2 +loop
  : sieve. { u sieve -- }
    2 .
    u 3 < if exit then
    u 1+ 3 ?do
      i sieve sieve-set? if i . then
    2 +loop
  : spiral-coord { n -- x y }
    n s>f sqrt 1,0 d- 2,0 f/ ceil { k }
    k 1 lshift 1+ { j }
    j j * { m }
    j 1- { j }
    n m j - >= if k m n - - k negate exit then
    j negate +to m
    n m j - >= if k negate dup m n - + exit then
    j negate +to m
    n m j - >= if k negate m n - + k exit then
    k dup negate m n - j - +
  : spiral-coord' { n -- x y }
    n spiral-coord { x y }
    term-pixels-dim@ { width height }
    width 1 rshift x + height 1 rshift y -
  0 255 0 rgb8 constant spiral-color
  : draw-spiral ( -- )
    term-pixels-dim@ * 1+ dup sieve-size [: { u my-sieve }
      u my-sieve sieve
      page
      [: { display }
      u my-sieve [: { u my-sieve display }
        spiral-color 2 spiral-coord' display draw-pixel-const
        u 3 >= if
          u 1+ 3 ?do
            i my-sieve sieve-set? if
              spiral-color i spiral-coord'
            then
          2 +loop
        then
      begin key? until
      key drop
    ;] with-allot
end-module
This is nothing too impressive, and other people on here have done similar things, but I created a simple clock program for zeptoforth on the PicoCalc. As it requires hardware floating point it requires the RP2350, but you have an RP2350 in your PicoCalc, right?
Note that I have uploaded a new version which displays a textual time in addition to the clock hands and clock face, and which also allows for adjusting the time zone with picocalc-clock::tz! ( hours minutes – ); this comment has been updated accordingly.
It can also be combined with NTP using the NTP clients bundled with zeptoforth.
You can get it from zeptoforth/test/rp2350/picocalc_clock.fs at master · tabemann/zeptoforth · GitHub.
Here is the source code in full:
\ Copyright (c) 2026 Travis Bemann
\ SOFTWARE.
begin-module picocalc-clock
  pixmap8 import
  pixmap8-utils import
  font import
  float32 import
  rtc import
  0 value tz-hour
  0 value tz-minute
  120e0 constant rim-radius
  110e0 constant mark-radius
  105e0 constant seconds-len
  100e0 constant minutes-len
  66e0 constant hours-len
  0.5e0 constant time-x
  0.75e0 constant time-y
  255 0 0 rgb8 constant rim-color
  0 0 255 rgb8 constant mark-color
  0 255 0 rgb8 constant seconds-color
  255 255 255 rgb8 constant minutes-color
  255 255 0 rgb8 constant hours-color
  0 255 255 rgb8 constant time-color
  : clock-hand { color len fract display -- }
    width 2 / height 2 / { width2/ height2/ }
    vpi 2e0 v/ vpi 2e0 v* fract v* v- { angle }
    width2/ angle vcos len v* v>n + { x }
    height2/ angle vsin len v* v>n - { y }
    color width2/ height2/ x y display draw-pixel-line
  : mark { fract display -- }
    angle vcos angle vsin { cos sin }
    width2/ cos rim-radius v* v>n + { x }
    height2/ sin rim-radius v* v>n - { y }
    width2/ cos mark-radius v* v>n + { x' }
    height2/ sin mark-radius v* v>n - { y' }
    mark-color x y x' y' display draw-pixel-line
  : marks { display -- }
    12 0 do i n>v 12e0 v/ display mark loop
  : rim { display -- }
    rim-color width2/ height2/ rim-radius v>n
    display draw-pixel-circle
  : text { color buf bytes x y display -- }
    term-font@ { font }
    width n>v x v* v>n font char-cols @ bytes * 2 / - { x' }
    height n>v y v* v>n font char-rows @ 2 / - { y' }
    color buf bytes x' y' display font draw-string-to-pixmap8
  : adjust-tz { date-time -- }
    date-time date-time-minute c@ { minute }
    minute tz-minute + { minute' }
    minute' 60 mod begin dup 0< while 60 + repeat
    date-time date-time-minute c!
    date-time date-time-hour c@ { hour }
    hour tz-hour + { hour' }
    minute' 0< if
      minute' 60 / 1- +to hour'
    else
      minute' 60 / +to hour'
    then
    hour' 24 mod begin dup 0< while 24 + repeat
    date-time date-time-hour c!
  : time ( -- hours minutes seconds )
    date-time-size [: { date-time }
      date-time date-time@
      date-time adjust-tz
      date-time date-time-hour c@ n>v { hour }
      date-time date-time-minute c@ n>v { minute }
      date-time date-time-second c@ n>v { second }
      date-time date-time-msec h@ n>v { msec }
      hour minute 60e0 v/ v+ second 3600e0 v/ v+
      msec 3600000e0 v/ v+
      minute second 60e0 v/ v+ msec 60000e0 v/ v+
      second msec 1000e0 v/ v+
    ;] with-aligned-allot
  : format-time ( buf -- )
    date-time-size [: { buf date-time }
      date-time adjust-tz
      s" 00:00:00" buf swap move
      date-time date-time-hour c@ s>d <# # # #>
      buf 0 + swap move
      date-time date-time-minute c@ s>d <# # # #>
      buf 3 + swap move
      date-time date-time-second c@ s>d <# # # #>
      buf 6 + swap move
  : display-time ( display -- )
    8 [: { display buf -- }
      buf format-time
      time-color buf 8 time-x time-y display text
  : tz! ( hours minutes -- ) to tz-minute to tz-hour ;
  : run-clock ( -- )
    page
    begin key? not while
      [: { display }
        time { hours minutes seconds }
        display rim
        display marks
        display display-time
        hours-color hours-len hours 12e0 v/ display clock-hand
        minutes-color minutes-len minutes 60e0 v/
        display clock-hand
         seconds-color seconds-len seconds 60e0 v/
         display clock-hand
    repeat
    key drop
end-module
Here is a demo for zeptoforth on the PicoCalc with the RP2350 of a quadrilateral whose corners bounce off the edges of the screen, while leaving a trail of images behind which eventually disappear. The source code is at zeptoforth/test/rp2350/picocalc_bounce_quad.fs at master · tabemann/zeptoforth · GitHub.
Below is a screenshot of it in action:
And here is the source code:
\ SOFTWARE.
begin-module bounce-quad
  pixmap8 import
  tinymt32 import
  float32 import
  systick import
  4 constant corner-count
  120 constant poly-count
  10e0 constant delta-mag
  250 constant interval
  0 255 0 rgb8 constant edge-color
  begin-structure coord-size
    field: coord-x
    field: coord-y
  end-structure
  begin-structure delta-size
    field: delta-x
    field: delta-y
  end-structure
  begin-structure corner-coords-size
    coord-size corner-count * +field corner-coords
  end-structure
  begin-structure corner-deltas-size
    delta-size corner-count * +field corner-deltas
  end-structure
  begin-structure polys-size
    corner-coords-size poly-count 1+ * +field poly-corners
    field: first-index
    field: last-index
  end-structure
  begin-structure state-size
    tinymt32-size +field prng
    field: last-tick
    polys-size +field polys
    corner-deltas-size +field deltas
  end-structure
  : rnd ( state -- v )
    prng tinymt32-generate-uint32 0 f64>v
  : init-prng { state -- }
    rng::random state prng tinymt32-init
    state prng tinymt32-prepare-example
  : init-coord { coord state -- }
    width n>v state rnd v* coord coord-x !
    height n>v state rnd v* coord coord-y !
  : init-poly-corners { poly state -- }
    corner-count 0 do
      poly i coord-size * + state init-coord
    loop
  : init-polys { polys state -- }
    polys poly-corners state init-poly-corners
    0 polys first-index !
    1 polys last-index !
  : init-delta { delta state -- }
    state rnd vpi 2e0 v* v* { angle }
    angle vcos delta-mag v* delta delta-x !
    angle vsin delta-mag v* delta delta-y !
  : init-deltas { state -- }
    corner-count 0 do
      state deltas i delta-size * + state init-delta
    loop
  : init-state { state -- }
    state init-prng
    state polys state init-polys
    state deltas state init-deltas
    systick-counter state last-tick !
  : last-poly { polys -- poly }
    polys last-index @ 1- dup 0< if drop poly-count then
    corner-coords-size * polys poly-corners +
  : new-corner { delta coord' coord -- }
    coord' coord-x @ delta delta-x @ v+ v0< if
      delta delta-x @ vabs delta delta-x !
    else
      coord' coord-x @ delta delta-x @ v+ width 1- n>v v> if
        delta delta-x @ vabs vnegate delta delta-x !
      then
    then
    coord' coord-y @ delta delta-y @ v+ v0< if
      delta delta-y @ vabs delta delta-y !
    else
      coord' coord-y @ delta delta-y @ v+ height 1- n>v v> if
        delta delta-y @ vabs vnegate delta delta-y !
      then
    then
    coord' coord-x @ delta delta-x @ v+ coord coord-x !
    coord' coord-y @ delta delta-y @ v+ coord coord-y !
  : new-poly { deltas poly' poly -- }
    corner-count 0 do
      deltas corner-deltas delta-size i * +
      poly' corner-coords coord-size i * +
      poly corner-coords coord-size i * +
      new-corner
    loop
  : add-poly { deltas polys -- }
    polys last-poly { poly' }
    polys last-index @ { index }
    polys poly-corners corner-coords-size index * + { poly }
    index 1+ poly-count 1+ umod { index' }
    index' polys last-index !
    polys first-index @ { old-index }
    old-index index' = if
      old-index 1+ poly-count 1+ umod polys first-index !
    then
    deltas poly' poly new-poly
  : draw-poly { poly display -- }
    poly corner-coords coord-size corner-count 1- * +
    { last-corner }
    corner-count 0 do
      poly corner-coords coord-size i * + { corner }
      edge-color corner coord-x @ v>n corner coord-y @ v>n
      last-corner coord-x @ v>n last-corner coord-y @ v>n
      corner to last-corner
    loop
  : draw-polys { polys display -- }
    polys first-index @ { index }
    begin index polys last-index @ <> while
      display draw-poly
      index 1+ poly-count 1+ umod to index
    repeat
  : run-demo ( -- )
    state-size [: { state }
      page
      state init-state
        state polys [: { polys display }
          polys display draw-polys
        begin
          systick-counter state last-tick @ - interval >=
        while
          state deltas state polys add-poly
          interval state last-tick +!
        repeat
        state last-tick @ systick-counter - 10 / 0 max ms
      repeat
      key drop
end-module
I tried to learn fourth when I was 22. It breaks my mind. It is not logical to me. Yes I know it is logical but it is that RPN thing it does and everything else about it. I could just never wrap my head around it. 40 some years later I still cant even read it to make sense of it. B-)
I’ve never worked with Forth before. But since I love HP calculators and RPN, maybe I should give Forth a try… :joy:
One way to think about Forth is that it is a very low-level backwards Lisp minus all the parentheses. Also, while Forth is notorious for stack juggling, many modern Forths such as zeptoforth do provide local variables (what you see in { … }), which when used judiciously really eliminate the stack juggling.
I would recommend trying out Forth ─ there is more to it than just RPN, as it provides a unique combination of low-level programming and flexibility and immediate responsiveness you really won’t see anywhere else. Like C you can get at the bare metal easily, but like Lisp you have a REPL and the ability to readily carry out metaprogramming. You can avoid the program-compile-flash-debug loop and do everything on-line at your fingertips.
Thanks, I’ll definitely give it a try. My PicoCalc was delivered last week and I have a week’s vacation ahead of me. A perfect combination of circumstances! :grin:
Lucky you! Now, if you haven’t assembled your PicoCalc yet, just don’t break your screen!
Thanks, the screen survived, as clockwork added a sheet with four ready cut pieces of tape for taping the screen down.
But my Luckfox Lyra died, when I soldered the cables of the Wi-Fi module directly to the board and didn’t take care when bending the cables. The delicate SMD solder pads detached from the board. :confused:
However, now I use a Pico 2 W. Is there a zeptoforth.uf2 available or do I have to build it myself?
I did not know that Clockwork now provides tape for taping down the screen when assembling the PicoCalc!
I would highly recommend reading zeptoforth/USING_THE_PICOCALC.md at master · tabemann/zeptoforth · GitHub in detail before you begin installing zeptoforth on the PicoCalc, and zeptoforth comes with extensive documentation and a wiki on GitHub that I would also recommend you read.
There are premade UF2 files for zeptoforth, but the recommended approach for use with the PicoCalc is to just use the relevant kernel UF2 file (so you will not need the arm-none-eabi toolchain unless you for some reason plan on rebuilding the kernel from source) and build the remainder of zeptoforth from source on top of it (the main dependencies there are that Python 3 and pip are needed); there are no premade UF2 files incorporating the whole of zeptoforth’s support for the PicoCalc as there are too many configuration choices for it to be practical to provide UF2 files for all of them. There is a convenient build script that can be used with Linux, macOS, xBSD, or, with a bit of work, WSL2 on Windows, but there are also directions for building zeptoforth on the PicoCalc manually if that is not an option (e.g. you are a Windows user and can’t bring yourself to use WSL2).
By the way, unless 5x8 fonts are too small for your eyes I would highly recommend choosing the 5x8_v2 font for zeptoforth on the PicoCalc as it provides 64 characters wide on the screen while being quite legible (there is an older 5x8 font but it honestly is quite ugly). If that is too small for your eyes I would then recommend the 7x8 font, which is bigger (but, of course, at the cost of characters on the screen).
As you have chosen a Pico 2W I would just use the graphical PicoCalc terminal emulator and not bother with the text-only one unless you plan on doing something that requires extensive amounts of SRAM; the text-only terminal emulator is really just meant for people who are using the Pico 1 due to its limited SRAM.
