@Rex you got a different command? I ran
sudo systemctl disable meshtasticd
and it came back with that it doesn’t exist…
Is meshtastic working on your device right now?
Actually, no. I didn’t finish setup on it. Remembered that. But… in other news, the adapter seems to be much more consistent. It seems to hate reboots and is fine with more power off and back on types. Question coming on another thread! Thank you!
@Rex
It’s working :slight_smile: with A06 computing Module
The LoRa Interface config for the A06 under meshtasticd is:
Lora:
Module: serial
SerialPath: /dev/ttyACM0
BaudRate: 115200
GPS:
SERIAL:
Enabled: true
Mode: NMEA
sudo systemctl edit meshtasticd
[Service]
ExecStart=
ExecStart=/usr/bin/meshtasticd --config /etc/meshtasticd/config.yaml
sudo systemctl stop meshtasticd
sudo systemctl daemon-reexec
sudo systemctl restart meshtasticd
journalctl -u meshtasticd -f
The RTC is not needed on the AIO board because, as I can see, the uConsole has one and it’s working well.
Enable GPS as time source (NMEA)
Create config:
sudo nano /etc/chrony/conf.d/gps.conf
refclock SHM 0 offset 0.5 delay 0.2 refid GPS
makestep 1.0 3
Restart:
sudo systemctl restart chrony
GPSD config:
sudo nano /etc/default/gpsd
DEVICES=“/dev/ttyACM0”
GPSD_OPTIONS=“-n”
sudo systemctl restart gpsd
cgps
Recommended SDR tuning for RK3399 (A06)
Reduce USB contention
echo ‘options dvb_usb_rtl28xxu disable_rc_polling=1’ | sudo tee /etc/modprobe.d/rtl2832.conf
Increase USB buffer size:
sudo sysctl -w net.core.rmem_max=8388608
sudo sysctl -w net.core.wmem_max=8388608
Fix SDR Driver Conflict:
sudo nano /etc/modprobe.d/rtl-sdr.conf
blacklist dvb_usb_rtl28xxu
blacklist rtl2832
have fun guys :slight_smile:
As I have a working Kali linux for the A06 I will let you know
Some updates and fine tuning for the GPS receiver for multiple process accessibility:
1. Stop Conflicts
Before starting, please make sure nothing is locked /dev/ttyACM0.
To check which process using the GPS receiver at the moment:
lsof /dev/ttyACM0
ls -l /dev/serial/by-id/
In my case:
  • Stop gpsd if it is currently using the serial port directly:
    sudo systemctl stop gpsd
    sudo systemctl stop gpsd.socket
    Ensure meshtasticd is not trying to open /dev/ttyACM0 in its config.yaml.
    sudo systemctl status meshtasticd.service
Check baud rate (optional but recommended):
stty -F /dev/ttyACM0
Common GPS baud rates:
  • 9600
2. Configure gpsd (critical)
Edit gpsd defaults:
Set exactly:
START_DAEMON="true"
GPSD_OPTIONS="-n"
DEVICES="/dev/ttyACM0"
USBAUTO="false"
Explanation:
  • -n forces gpsd to read immediately (important for headless systems)
  • USBAUTO=false prevents gpsd from grabbing the device twice
Enable and start gpsd:
sudo systemctl enable gpsd
3. Verify gpsd is working
Run:
cgps -s
You should see:
  • Satellites
  • Fix status
  • Latitude / longitude
4. Configure Meshtastic (NO serial port)
Edit Meshtastic config:
sudo nano /etc/meshtasticd/config.yaml
Use gpsd, not a serial device:
GPS:
  Enabled: true
  Gpsd:
    Enabled: true
    Host: localhost
    Port: 2947
:warning: Important:
  • Remove or comment out SerialPath
  • Meshtastic must NOT touch /dev/ttyACM0
Restart Meshtastic:
Verify:
meshtastic --info
You should see GPS data populated.
5. Configure Kismet (if you have it)
Kismet supports gpsd natively.
Edit (or create):
sudo nano /etc/kismet/kismet.conf
Add or ensure:
gps=gpsd:host=localhost,port=2947
Restart Kismet:
sudo systemctl restart kismet
Check Kismet UI → GPS active
6. Configure tar1090 / dump1090
tar1090 and dump1090 already support gpsd.
Check config file (location varies):
Common paths:
  • /etc/default/dump1090-fa
  • /etc/default/readsb
Ensure gpsd is enabled:
GPSD_HOST="localhost"
GPSD_PORT="2947"
Restart:
sudo systemctl restart dump1090-fa || sudo systemctl restart readsb
Verify aircraft map shows receiver location.
7. Final conflict check (important)
Ensure nothing else opens the serial device:
sudo lsof /dev/ttyACM0
Expected output:
gpsd    PID   gpsd   ... /dev/ttyACM0
If you see anything else → misconfiguration.
OPTIONAL — Debugging tools
Watch raw NMEA from gpsd
gpspipe -r
Watch JSON stream
gpspipe -w
Check gpsd socket
ss -lnpt | grep 2947
I hope it’s helps :smile:
Other option:
GPS:
  Enabled: true
  Gpsd:
    Enabled: true
Just let meshtasticd handle the GPS
since when does meshtastic support GPSd? last time I looked into this they did weird stuff with the GPS that required full serial access and they only had stale feature requests and workarounds to share the GPS between multiple services
Thanks for the information. I try to share GPS data only with other processes like Kismet and tar1090.
Under meshtasticd config.yaml I use this:
GPS:
  Enabled: true
i also tried to do the same. but i cannot get GPS to start with GPSD. running meshtasticd with debug turned out has a line that says “Run without GPS”.
@Sh4d0wCr0w does your debug log say that GPS is on?
Thanks
I am so sorry for this noob question but trying to read here and find out what is the best image for clockwork pi cm4 with hacker gadgets v2 aio board? Got the uconsole in today used from ebay and aio will be in later this week and was trying to get a sd card flashed and ready to go. I downloaded dragonos-6.12.48 and flashed with balena but screen comes up blank. Thanks again and 73
Can you send me what you see and where?
At my end, the GPS is sending the information to meshtastic.
With this command, you can see how many processes are trying to use GPS:
If you see two or more, this means there is a conflict with resources because at once, only one process can interact with the GPS to receive information. This is why a “proxy” for the GPS information is needed to share it with multiple processes.
At the moment I share the GPS data with meshtastic, kismet, tar1090
Just trying to confirm something. The SDR on here should show up under usb correct?
yes the SDR is a usb device
weird, mine stopped showing up.
Need help in deciding on a purchase.
I have the V1 AIO board.
The V2 AIO board is more or less the same but for the following improvements:
  • USB-A on the side will be replaced by an RJ45 Gigabit Ethernet
  • GPIOs will control the power of the GPS/LoRa/RTL-SDR/Internal USB ports
  • USB-C ports will be USB 3.0 when using CM5
I am more confused with this one, though: https://hackergadgets.com/products/uconsole-upgrade-kit?variant=47045223415982
This mainly adds NVMe support?
If I want NVMe, do I need to purchase the adapter board as well as the NVMe battery board, correct?
And what are the 2 expansion boards? The one which does not have AIO V2 doesn’t have LORA, SDR, GPS?
Sorry if there are too many questions, it’s just a bit confusing.
I mainly want to get the NVMe support.
Yes you need both the adapter and NVME for NVME to work.
The AIO V2 has lora/sdr/etc.
The other board “only” has USB and ethernet.
Hi Rex.I use CM5,but why my pygpsclient cannt work?
which AIO board are you using?
have you tried all of the listed serial ports?
this include AIO V2
bored99 <notifications@clockworkpi.discoursemail.com>于2026年1月10日 周六下午7:15写道:
