How to install other linux distri
alternatively use this diff
(put text block into whatever.patch & patch patch/kernel/archive/rockchip64-5.15/rk3328-add-dmc-driver.patch whatever.patch)
14d13
<  drivers/devfreq/event/rockchip-dfi.c          | 554 ++++++++++-
637,1291d635
< diff --git a/drivers/devfreq/event/rockchip-dfi.c b/drivers/devfreq/event/rockchip-dfi.c
< index 9a88faaf8..c034df869 100644
< --- a/drivers/devfreq/event/rockchip-dfi.c
< +++ b/drivers/devfreq/event/rockchip-dfi.c
< @@ -18,25 +18,66 @@
<  #include <linux/list.h>
<  #include <linux/of.h>
< -#include <soc/rockchip/rk3399_grf.h>
< -#define RK3399_DMC_NUM_CH	2
< +#define PX30_PMUGRF_OS_REG2		0x208
< +#define RK3128_GRF_SOC_CON0		0x140
< +#define RK3128_GRF_OS_REG1		0x1cc
< +#define RK3128_GRF_DFI_WRNUM		0x220
< +#define RK3128_GRF_DFI_RDNUM		0x224
< +#define RK3128_GRF_DFI_TIMERVAL		0x22c
< +#define RK3128_DDR_MONITOR_EN		((1 << (16 + 6)) + (1 << 6))
< +#define RK3128_DDR_MONITOR_DISB		((1 << (16 + 6)) + (0 << 6))
< +#define RK3288_PMU_SYS_REG2		0x9c
< +#define RK3288_GRF_SOC_CON4		0x254
< +#define RK3288_GRF_SOC_STATUS(n)	(0x280 + (n) * 4)
< +#define RK3288_DFI_EN			(0x30003 << 14)
< +#define RK3288_DFI_DIS			(0x30000 << 14)
< +#define RK3288_LPDDR_SEL		(0x10001 << 13)
< +#define RK3288_DDR3_SEL			(0x10000 << 13)
< +#define RK3328_GRF_OS_REG2		0x5d0
< +#define RK3368_GRF_DDRC0_CON0		0x600
< +#define RK3368_GRF_SOC_STATUS5		0x494
< +#define RK3368_GRF_SOC_STATUS6		0x498
< +#define RK3368_GRF_SOC_STATUS8		0x4a0
< +#define RK3368_GRF_SOC_STATUS9		0x4a4
< +#define RK3368_GRF_SOC_STATUS10		0x4a8
< +#define RK3368_DFI_EN			(0x30003 << 5)
< +#define RK3368_DFI_DIS			(0x30000 << 5)
< +#define MAX_DMC_NUM_CH			2
< +#define READ_DRAMTYPE_INFO(n)		(((n) >> 13) & 0x7)
< +#define READ_CH_INFO(n)			(((n) >> 28) & 0x3)
<  /* DDRMON_CTRL */
< -#define DDRMON_CTRL	0x04
< -#define CLR_DDRMON_CTRL	(0x1f0000 << 0)
< -#define LPDDR4_EN	(0x10001 << 4)
< -#define HARDWARE_EN	(0x10001 << 3)
< -#define LPDDR3_EN	(0x10001 << 2)
< -#define SOFTWARE_EN	(0x10001 << 1)
< -#define SOFTWARE_DIS	(0x10000 << 1)
< -#define TIME_CNT_EN	(0x10001 << 0)
< +#define DDRMON_CTRL			0x04
< +#define CLR_DDRMON_CTRL			(0x3f0000 << 0)
< +#define DDR4_EN				(0x10001 << 5)
< +#define LPDDR4_EN			(0x10001 << 4)
< +#define HARDWARE_EN			(0x10001 << 3)
< +#define LPDDR2_3_EN			(0x10001 << 2)
< +#define SOFTWARE_EN			(0x10001 << 1)
< +#define SOFTWARE_DIS			(0x10000 << 1)
< +#define TIME_CNT_EN			(0x10001 << 0)
<  #define DDRMON_CH0_COUNT_NUM		0x28
<  #define DDRMON_CH0_DFI_ACCESS_NUM	0x2c
<  #define DDRMON_CH1_COUNT_NUM		0x3c
<  #define DDRMON_CH1_DFI_ACCESS_NUM	0x40
< +/* pmu grf */
< +#define PMUGRF_OS_REG2			0x308
< +enum {
< +	DDR4 = 0,
< +	DDR3 = 3,
< +	LPDDR2 = 5,
< +	LPDDR3 = 6,
< +	LPDDR4 = 7,
< +	UNUSED = 0xFF
<  struct dmc_usage {
<  	u32 access;
<  	u32 total;
< @@ -50,33 +91,261 @@ struct dmc_usage {
<  struct rockchip_dfi {
<  	struct devfreq_event_dev *edev;
<  	struct devfreq_event_desc *desc;
< -	struct dmc_usage ch_usage[RK3399_DMC_NUM_CH];
< +	struct dmc_usage ch_usage[MAX_DMC_NUM_CH];
<  	struct device *dev;
<  	void __iomem *regs;
<  	struct regmap *regmap_pmu;
< +	struct regmap *regmap_grf;
< +	struct regmap *regmap_pmugrf;
<  	struct clk *clk;
< +	u32 dram_type;
< +	 * available mask, 1: available, 0: not available
< +	 * each bit represent a channel
< +	u32 ch_msk;
< +static void rk3128_dfi_start_hardware_counter(struct devfreq_event_dev *edev)
< +	struct rockchip_dfi *info = devfreq_event_get_drvdata(edev);
< +	regmap_write(info->regmap_grf,
< +		     RK3128_GRF_SOC_CON0,
< +		     RK3128_DDR_MONITOR_EN);
< +static void rk3128_dfi_stop_hardware_counter(struct devfreq_event_dev *edev)
< +		     RK3128_DDR_MONITOR_DISB);
< +static int rk3128_dfi_disable(struct devfreq_event_dev *edev)
< +	rk3128_dfi_stop_hardware_counter(edev);
< +	return 0;
< +static int rk3128_dfi_enable(struct devfreq_event_dev *edev)
< +	rk3128_dfi_start_hardware_counter(edev);
< +	return 0;
< +static int rk3128_dfi_set_event(struct devfreq_event_dev *edev)
< +	return 0;
< +static int rk3128_dfi_get_event(struct devfreq_event_dev *edev,
< +				struct devfreq_event_data *edata)
< +	unsigned long flags;
< +	u32 dfi_wr, dfi_rd, dfi_timer;
< +	local_irq_save(flags);
< +	regmap_read(info->regmap_grf, RK3128_GRF_DFI_WRNUM, &dfi_wr);
< +	regmap_read(info->regmap_grf, RK3128_GRF_DFI_RDNUM, &dfi_rd);
< +	regmap_read(info->regmap_grf, RK3128_GRF_DFI_TIMERVAL, &dfi_timer);
< +	edata->load_count = (dfi_wr + dfi_rd) * 4;
< +	edata->total_count = dfi_timer;
< +	local_irq_restore(flags);
< +	return 0;
< +static const struct devfreq_event_ops rk3128_dfi_ops = {
< +	.disable = rk3128_dfi_disable,
< +	.enable = rk3128_dfi_enable,
< +	.get_event = rk3128_dfi_get_event,
< +	.set_event = rk3128_dfi_set_event,
< +static void rk3288_dfi_start_hardware_counter(struct devfreq_event_dev *edev)
< +	regmap_write(info->regmap_grf, RK3288_GRF_SOC_CON4, RK3288_DFI_EN);
< +static void rk3288_dfi_stop_hardware_counter(struct devfreq_event_dev *edev)
< +	regmap_write(info->regmap_grf, RK3288_GRF_SOC_CON4, RK3288_DFI_DIS);
< +static int rk3288_dfi_disable(struct devfreq_event_dev *edev)
< +	rk3288_dfi_stop_hardware_counter(edev);
< +	return 0;
< +static int rk3288_dfi_enable(struct devfreq_event_dev *edev)
< +	rk3288_dfi_start_hardware_counter(edev);
< +	return 0;
< +static int rk3288_dfi_set_event(struct devfreq_event_dev *edev)
< +	return 0;
< +static int rk3288_dfi_get_busier_ch(struct devfreq_event_dev *edev)
< +	u32 tmp, max = 0;
< +	u32 i, busier_ch = 0;
< +	u32 rd_count, wr_count, total_count;
< +	/* Find out which channel is busier */
< +	for (i = 0; i < MAX_DMC_NUM_CH; i++) {
< +		if (!(info->ch_msk & BIT(i)))
< +			continue;
< +			    RK3288_GRF_SOC_STATUS(11 + i * 4), &wr_count);
< +			    RK3288_GRF_SOC_STATUS(12 + i * 4), &rd_count);
< +			    RK3288_GRF_SOC_STATUS(14 + i * 4), &total_count);
< +		info->ch_usage[i].access = (wr_count + rd_count) * 4;
< +		info->ch_usage[i].total = total_count;
< +		tmp = info->ch_usage[i].access;
< +		if (tmp > max) {
< +			busier_ch = i;
< +			max = tmp;
< +	return busier_ch;
< +static int rk3288_dfi_get_event(struct devfreq_event_dev *edev,
< +	int busier_ch;
< +	busier_ch = rk3288_dfi_get_busier_ch(edev);
< +	edata->load_count = info->ch_usage[busier_ch].access;
< +	edata->total_count = info->ch_usage[busier_ch].total;
< +	return 0;
< +static const struct devfreq_event_ops rk3288_dfi_ops = {
< +	.disable = rk3288_dfi_disable,
< +	.enable = rk3288_dfi_enable,
< +	.get_event = rk3288_dfi_get_event,
< +	.set_event = rk3288_dfi_set_event,
< +static void rk3368_dfi_start_hardware_counter(struct devfreq_event_dev *edev)
< +	regmap_write(info->regmap_grf, RK3368_GRF_DDRC0_CON0, RK3368_DFI_EN);
< +static void rk3368_dfi_stop_hardware_counter(struct devfreq_event_dev *edev)
< +	regmap_write(info->regmap_grf, RK3368_GRF_DDRC0_CON0, RK3368_DFI_DIS);
< +static int rk3368_dfi_disable(struct devfreq_event_dev *edev)
< +	rk3368_dfi_stop_hardware_counter(edev);
< +	return 0;
< +static int rk3368_dfi_enable(struct devfreq_event_dev *edev)
< +	rk3368_dfi_start_hardware_counter(edev);
< +	return 0;
< +static int rk3368_dfi_set_event(struct devfreq_event_dev *edev)
< +	return 0;
< +static int rk3368_dfi_get_event(struct devfreq_event_dev *edev,
< +	u32 dfi0_wr, dfi0_rd, dfi1_wr, dfi1_rd, dfi_timer;
< +	regmap_read(info->regmap_grf, RK3368_GRF_SOC_STATUS5, &dfi0_wr);
< +	regmap_read(info->regmap_grf, RK3368_GRF_SOC_STATUS6, &dfi0_rd);
< +	regmap_read(info->regmap_grf, RK3368_GRF_SOC_STATUS9, &dfi1_wr);
< +	regmap_read(info->regmap_grf, RK3368_GRF_SOC_STATUS10, &dfi1_rd);
< +	regmap_read(info->regmap_grf, RK3368_GRF_SOC_STATUS8, &dfi_timer);
< +	edata->load_count = (dfi0_wr + dfi0_rd + dfi1_wr + dfi1_rd) * 2;
< +	return 0;
< +static const struct devfreq_event_ops rk3368_dfi_ops = {
< +	.disable = rk3368_dfi_disable,
< +	.enable = rk3368_dfi_enable,
< +	.get_event = rk3368_dfi_get_event,
< +	.set_event = rk3368_dfi_set_event,
<  static void rockchip_dfi_start_hardware_counter(struct devfreq_event_dev *edev)
<  	struct rockchip_dfi *info = devfreq_event_get_drvdata(edev);
<  	void __iomem *dfi_regs = info->regs;
< -	u32 val;
< -	u32 ddr_type;
< -	/* get ddr type */
< -	regmap_read(info->regmap_pmu, RK3399_PMUGRF_OS_REG2, &val);
< -	ddr_type = (val >> RK3399_PMUGRF_DDRTYPE_SHIFT) &
< -		    RK3399_PMUGRF_DDRTYPE_MASK;
<  	/* clear DDRMON_CTRL setting */
<  	writel_relaxed(CLR_DDRMON_CTRL, dfi_regs + DDRMON_CTRL);
<  	/* set ddr type to dfi */
< -	if (ddr_type == RK3399_PMUGRF_DDRTYPE_LPDDR3)
< -		writel_relaxed(LPDDR3_EN, dfi_regs + DDRMON_CTRL);
< -	else if (ddr_type == RK3399_PMUGRF_DDRTYPE_LPDDR4)
< +	if (info->dram_type == LPDDR3 || info->dram_type == LPDDR2)
< +		writel_relaxed(LPDDR2_3_EN, dfi_regs + DDRMON_CTRL);
< +	else if (info->dram_type == LPDDR4)
<  		writel_relaxed(LPDDR4_EN, dfi_regs + DDRMON_CTRL);
< +	else if (info->dram_type == DDR4)
< +		writel_relaxed(DDR4_EN, dfi_regs + DDRMON_CTRL);
<  	/* enable count, use software mode */
<  	writel_relaxed(SOFTWARE_EN, dfi_regs + DDRMON_CTRL);
< @@ -100,12 +369,22 @@ static int rockchip_dfi_get_busier_ch(struct devfreq_event_dev *edev)
<  	rockchip_dfi_stop_hardware_counter(edev);
<  	/* Find out which channel is busier */
< -	for (i = 0; i < RK3399_DMC_NUM_CH; i++) {
< -		info->ch_usage[i].access = readl_relaxed(dfi_regs +
< -				DDRMON_CH0_DFI_ACCESS_NUM + i * 20) * 4;
< +			continue;
<  		info->ch_usage[i].total = readl_relaxed(dfi_regs +
<  				DDRMON_CH0_COUNT_NUM + i * 20);
< -		tmp = info->ch_usage[i].access;
< +		/* LPDDR4 BL = 16,other DDR type BL = 8 */
< +		tmp = readl_relaxed(dfi_regs +
< +				DDRMON_CH0_DFI_ACCESS_NUM + i * 20);
< +		if (info->dram_type == LPDDR4)
< +			tmp *= 8;
< +		else
< +			tmp *= 4;
< +		info->ch_usage[i].access = tmp;
<  		if (tmp > max) {
<  			busier_ch = i;
<  			max = tmp;
< @@ -121,7 +400,8 @@ static int rockchip_dfi_disable(struct devfreq_event_dev *edev)
< -	clk_disable_unprepare(info->clk);
< +	if (info->clk)
< +		clk_disable_unprepare(info->clk);
<  	return 0;
< @@ -131,10 +411,13 @@ static int rockchip_dfi_enable(struct devfreq_event_dev *edev)
<  	int ret;
< -	ret = clk_prepare_enable(info->clk);
< -	if (ret) {
< -		dev_err(&edev->dev, "failed to enable dfi clk: %d\n", ret);
< -		return ret;
< +	if (info->clk) {
< +		ret = clk_prepare_enable(info->clk);
< +		if (ret) {
< +			dev_err(&edev->dev, "failed to enable dfi clk: %d\n",
< +				ret);
< +			return ret;
<  	rockchip_dfi_start_hardware_counter(edev);
< @@ -151,8 +434,11 @@ static int rockchip_dfi_get_event(struct devfreq_event_dev *edev,
<  	int busier_ch;
<  	busier_ch = rockchip_dfi_get_busier_ch(edev);
<  	edata->load_count = info->ch_usage[busier_ch].access;
<  	edata->total_count = info->ch_usage[busier_ch].total;
< @@ -167,22 +453,116 @@ static const struct devfreq_event_ops rockchip_dfi_ops = {
<  	.set_event = rockchip_dfi_set_event,
< -static const struct of_device_id rockchip_dfi_id_match[] = {
< -	{ .compatible = "rockchip,rk3399-dfi" },
< -MODULE_DEVICE_TABLE(of, rockchip_dfi_id_match);
< +static __init int px30_dfi_init(struct platform_device *pdev,
< +				  struct rockchip_dfi *data,
< +				  struct devfreq_event_desc *desc)
< +	struct device_node *np = pdev->dev.of_node, *node;
< +	struct resource *res;
< +	u32 val;
< -static int rockchip_dfi_probe(struct platform_device *pdev)
< +	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
< +	data->regs = devm_ioremap_resource(&pdev->dev, res);
< +	if (IS_ERR(data->regs))
< +		return PTR_ERR(data->regs);
< +	node = of_parse_phandle(np, "rockchip,pmugrf", 0);
< +	if (node) {
< +		data->regmap_pmugrf = syscon_node_to_regmap(node);
< +		if (IS_ERR(data->regmap_pmugrf))
< +			return PTR_ERR(data->regmap_pmugrf);
< +	regmap_read(data->regmap_pmugrf, PX30_PMUGRF_OS_REG2, &val);
< +	data->dram_type = READ_DRAMTYPE_INFO(val);
< +	data->ch_msk = 1;
< +	data->clk = NULL;
< +	desc->ops = &rockchip_dfi_ops;
< +	return 0;
< +static __init int rk3128_dfi_init(struct platform_device *pdev,
< -	struct device *dev = &pdev->dev;
< -	struct rockchip_dfi *data;
< -	struct devfreq_event_desc *desc;
<  	struct device_node *np = pdev->dev.of_node, *node;
< -	data = devm_kzalloc(dev, sizeof(struct rockchip_dfi), GFP_KERNEL);
< -	if (!data)
< -		return -ENOMEM;
< +	node = of_parse_phandle(np, "rockchip,grf", 0);
< +	if (node) {
< +		data->regmap_grf = syscon_node_to_regmap(node);
< +		if (IS_ERR(data->regmap_grf))
< +			return PTR_ERR(data->regmap_grf);
< +	desc->ops = &rk3128_dfi_ops;
< +	return 0;
< +static __init int rk3288_dfi_init(struct platform_device *pdev,
< +	u32 val;
< +	node = of_parse_phandle(np, "rockchip,pmu", 0);
< +	if (node) {
< +		data->regmap_pmu = syscon_node_to_regmap(node);
< +		if (IS_ERR(data->regmap_pmu))
< +			return PTR_ERR(data->regmap_pmu);
< +	if (node) {
< +	regmap_read(data->regmap_pmu, RK3288_PMU_SYS_REG2, &val);
< +	data->ch_msk = READ_CH_INFO(val);
< +	if (data->dram_type == DDR3)
< +		regmap_write(data->regmap_grf, RK3288_GRF_SOC_CON4,
< +			     RK3288_DDR3_SEL);
< +	else
< +			     RK3288_LPDDR_SEL);
< +	desc->ops = &rk3288_dfi_ops;
< +	return 0;
< +static __init int rk3368_dfi_init(struct platform_device *pdev,
< +	struct device *dev = &pdev->dev;
< +	if (!dev->parent || !dev->parent->of_node)
< +		return -EINVAL;
< +	data->regmap_grf = syscon_node_to_regmap(dev->parent->of_node);
< +	desc->ops = &rk3368_dfi_ops;
< +	return 0;
< +static __init int rockchip_dfi_init(struct platform_device *pdev,
< +	u32 val;
<  	data->regs = devm_platform_ioremap_resource(pdev, 0);
<  	if (IS_ERR(data->regs))
< @@ -202,21 +582,97 @@ static int rockchip_dfi_probe(struct platform_device *pdev)
<  		if (IS_ERR(data->regmap_pmu))
<  			return PTR_ERR(data->regmap_pmu);
< -	data->dev = dev;
< +	regmap_read(data->regmap_pmu, PMUGRF_OS_REG2, &val);
< +	return 0;
< +static __init int rk3328_dfi_init(struct platform_device *pdev,
< +	u32 val;
< +	if (node) {
< +	regmap_read(data->regmap_grf, RK3328_GRF_OS_REG2, &val);
< +	return 0;
< +static const struct of_device_id rockchip_dfi_id_match[] = {
< +	{ .compatible = "rockchip,px30-dfi", .data = px30_dfi_init },
< +	{ .compatible = "rockchip,rk1808-dfi", .data = px30_dfi_init },
< +	{ .compatible = "rockchip,rk3128-dfi", .data = rk3128_dfi_init },
< +	{ .compatible = "rockchip,rk3288-dfi", .data = rk3288_dfi_init },
< +	{ .compatible = "rockchip,rk3328-dfi", .data = rk3328_dfi_init },
< +	{ .compatible = "rockchip,rk3368-dfi", .data = rk3368_dfi_init },
< +	{ .compatible = "rockchip,rk3399-dfi", .data = rockchip_dfi_init },
< +MODULE_DEVICE_TABLE(of, rockchip_dfi_id_match);
< +static int rockchip_dfi_probe(struct platform_device *pdev)
< +	struct rockchip_dfi *data;
< +	struct devfreq_event_desc *desc;
< +	struct device_node *np = pdev->dev.of_node;
< +	const struct of_device_id *match;
< +	int (*init)(struct platform_device *pdev, struct rockchip_dfi *data,
< +		    struct devfreq_event_desc *desc);
< +	data = devm_kzalloc(dev, sizeof(struct rockchip_dfi), GFP_KERNEL);
< +	if (!data)
< +		return -ENOMEM;
<  	desc = devm_kzalloc(dev, sizeof(*desc), GFP_KERNEL);
<  	if (!desc)
<  		return -ENOMEM;
< -	desc->ops = &rockchip_dfi_ops;
< +	match = of_match_node(rockchip_dfi_id_match, pdev->dev.of_node);
< +	if (match) {
< +		init = match->data;
< +		if (init) {
< +			if (init(pdev, data, desc))
< +				return -EINVAL;
< +		} else {
< +			return 0;
< +	} else {
< +		return 0;
<  	desc->driver_data = data;
<  	desc->name = np->name;
<  	data->desc = desc;
< +	data->dev = dev;
< -	data->edev = devm_devfreq_event_add_edev(&pdev->dev, desc);
< +	data->edev = devm_devfreq_event_add_edev(dev, desc);
<  	if (IS_ERR(data->edev)) {
< -		dev_err(&pdev->dev,
< -			"failed to add devfreq-event device\n");
< +		dev_err(dev, "failed to add devfreq-event device\n");
<  		return PTR_ERR(data->edev);
Everyone confirm that the way to patch is too make a kali linux /other raspi suite running on a raspi 5 /4 then patch and after plug the sd card in A06 ?
if you made a claud code Skill + Agents with this knowledge …the world would be a better place :grinning_face:
