I have received the gameshell console,but I found that it only can play gba and nes , so how can i play snes game on gameshell console,thanks
maybe u can try download RetroArch snes9x core and copy snes game and run
The forum rules for talking about emulators are a bit grey, but we have a community forum for figuring out stuff like this:
thanks,but it did not work
I got it,thank you very much
What folder do I put the snes games in?
You can create a snes catalog and put a configure file in that catalog ; Using the ssh to connect the gameshell and you will know how to do if you know some linux knowledge;
Sorry I figured it out. Now stuck on removing cores i have added to retro arch.
SSH intro it, then navigate to home/CPI/.config/retroarch and I believe /cores with command: rm corename you can then delete
I have been stuck on expanding the active partition after upgrading to larger memory card. Parted and gdisk hasn’t worked
you can download the core from http://buildbot.libretro.com/nightly/linux/armhf/latest/ ,Or edit the config file like gba config file
Have you tried a livecd version of gparted ? Worked for me…
