How to start with the Gameshell
Hi newcomers to the forum or long time peeps.
So if you are a kickstarter/indigogo backer then your shell SHOULD of arrived by now. Once you have built it and put the provided sd card in, do the first boot blah blah blah. Once onto the main screen go to the far left of the screen and press on options. Once in options/settings do the following.
.Find the wifi tab and connect the shell to wifi
.Set your time zone
.check for any updates for the os
Then start doing what you want to to with the shell.
If you want to load roms onto it then click here
How to install roms (the easy way) to see my guide for installing roms
Seya
I hoped this helped you start with the Gameshell
