Thats the terminal, the launcher should boot afterwards, if not you can load the launcher files again
I’ve rebooted it many times, it’s stuck on that screen. I’ve even let it sit for a while and still wouldn’t move on.
Something is messed up and the launcher is not fired up after this screen. I would suggest to reflash your sd card and try again.
No need to reflash if he can get SSH running. He can git pull the launcher repository
True but maybe just a reflash will save him precious time if our fellow is a newcomer.
If you decide to reflash, you can save yourself some trouble and flash this image, which has some standalone emulators installed. ![]()
Thanks! I’ll try this and see how it goes.
