Updated launcher from git, EPIC FAIL
Few days with no update in the launcher, i connected to ssh and updated through git:
git pull
many updates in the files, but the launcher is not working, the screen is freezed in “loading…” There is some IMAGE that I can download to flash the SD card?
I try launching the “run.py” script but there is an error:
cpi@clockworkpi:~/apps/launcher$ python2 sys.py/run.py
Traceback (most recent call last):
File “sys.py/run.py”, line 40, in
from UI.title_bar import TitleBar
File “/home/cpi/apps/launcher/sys.py/UI/title_bar.py”, line 16, in
from fonts import fonts
File “/home/cpi/apps/launcher/sys.py/UI/fonts.py”, line 24, in
fonts[“varela10”] = pygame.font.Font(fonts_path[“varela”],10)
IOError: unable to read font filename
some help? :relieved:
I checked the launcher last stable version here: CPI/launcher_ver.json at master · clockworkpi/CPI · GitHub
Well, I get the code with this:
cd /home/cpi/apps
mv launcher launcher.bak
git clone https://github.com/clockworkpi/launcher.git
git reset --hard 4ad8806
git pull
su
reboot
still the same result, I think that is a gnu/linux problem :S
you need to move launcher to /home/cpi
checkout this:
Well, I tried the instructios of these post, and now It freezes in “loading…” screen and I can’t conect to ssh ._____.
Well, where I can find an image to flash the sd card and start from 0? Thank you
I dont know your level of knowledge on flashing or this process, so I kinda am going to shotgun you with forum posts. Sorry if you already know some of this.
:floppy_disk: Image
This would be a good start here to download the image file needed for GameShell.
:high_voltage: Flashing
For help with reflashing the SD Card, refer to this forum post here:
TL;DR - “Use something like https://etcher.io to flash your sd card”
:red_question_mark: Troubleshooting: SD cards bigger than 8gb
I also found this forum post with issues on a 64gb SD-Card,
I usually flash it with “dd”, thank you very much :*
I guess you did not install bluez
days ago ,some one had the same problem
I had installed bluez, but don’t worry :_D
I flashed SD with the image, I put it into the clockworkpi and there is no power, well i suppose that it has no power, checking with the tester the battery gives 4V, I plug the microUsb connector to charge it, and probe it pushing the power button, nothing happends. I have the clockworkpi charging for a long time, and the pcb is hot, but is not powering on. I unmount all the things and mount again, but I’m not lucky. WTF happens with this??? I’m snooty??? Some help??
Problems with SD card, i tried flashing the bz2 :man_facepalming: now is working MOTHERFUCKERS YEEEAHHH
