… that’s true, unfortunately. But there are a few small tweaks and modifications you can try to bring the temperature down (when the CM5 is under heavy load).
My Uconsole (CM5) is currently running at around 40–50 °C … I think that’s fine. (I’m still using the ‘standard cooling pad’, but I’m planning to modify it so that I can use an active fan.)
