Say no to CM5 overheating in your uConsole: a practical, low-cost fix
Greetings from Brazil.
This is my first post on the forum, arriving after what felt like an epic campaign to get a uConsole with a CM5 to boot from an SD card—only to be defeated by a stubborn “failed to open device ‘sdcard’.” I lost, decisively. And with that, I also lost one of the CM4 platform’s quiet pleasures: swapping operating systems as easily as swapping cards. For context, I’m not using the Lite—this is the 4/32 variant. After too many shutdowns, too many card swaps, and too many attempts to outsmart the thing, I gave up. It’s the kind of problem that breeds a low-grade anxiety (call it comic, if you like). In the end, I flashed DragonOS to the eMMC. Life is short, and my interest is SDR. Sometimes the better outcome isn’t being right—it’s being done.
When the CM5—or the HG board (AIO V2) —eventually behaves like the CM4 in this regard, I’ll happily try again. For now, this is where things stand.
That prelude aside, I live in a hot country, and I wanted to share a simple, inexpensive, and practical way to keep the CM5’s temperature in check. I’ve had excellent results using a clip-on “gaming phone” cooler— The cooler is magnetic—you attach a metal sticker to your device, and you can easily place or remove the cooler whenever you want - there are plenty of versions out there.
It works surprisingly well because it leverages the aluminum body to dissipate heat across the entire console. Yes, it draws power; that’s the trade-off. But the balance is reasonable. In my case, it drops temperatures by as much as 23 °C ≈ 73.4 °F in short order, which keeps thermal throttling at bay. And, if I may offer a suggestion to the folks at ClockworkPi: please, for the love of God—or any higher power you prefer—consider a proper accessory based on semiconductor cooling, a Peltier module. It sounds like black magic, but it isn’t, and low-power options do exist.
In the end, that’s it. It simply works—efficient, effective, and, most importantly, enough to get on with the radio.
The compute module by design is wired to either use the internal Embedded MultiMediaCard (eMMC), or a Secure Digital (SD) card, which is the successor medium to the MultiMediaCard and is similar at a signal level. This isn’t a limitation of the uConsole but a side effect of the way the compute module is designed. The same is true if the CM5 is placed in any other carrier board; only Lite SKUs can use the SD card slot.
Peltier modules are semiconductors that, when powered, move thermal energy from one side to another, making one side cool and the other side hot, but when the hot side reaches its heat capacity it will overheat and melt internal components, effectively self-destructing. A Peltier module used in this fashion will have a significantly shortened life span.
The cooling module you have may well be a Peltier module, but it also has a good amount of active heat dissipation in the form of a fan so the module doesn’t overheat. Using the fan alone would be significantly more efficient than using it alongside a Peltier module because the electrical energy used to power the semiconductor to apply the Peltier effect would be dissipated from the circuitry in the form of heat energy, making the system as a whole hotter.
Let’s be realistic: sometimes there’s a huge gap between theory and practice. I partially agree when you say that using it internally would be a disaster — but not because of Peltier module degradation (that comment was greatly exaggerated), for the following reasons:
1 - The uConsole has very limited internal space. A great upgrade would be to redesign the rear cover, increasing the available space and adding some kind of vent grille with a filter (to prevent objects from entering) in order to improve airflow and heat exchange. The uConsole is essentially a closed environment, and with so many heat-related problems, the rear cover design clearly needs improvement to allow better thermal dissipation. A heatsink alone is not enough — proper airflow requires a redesign. That is simply the reality.
2 - What actually makes installing a Peltier module inside the uConsole impractical today — and this is the part I agree with — is the lack of space, the lack of airflow, and, most critically, condensation. Water and electronics do not work well together unless the circuits are fully sealed and waterproofed. In that scenario, yes, it could become destructive, because condensation would eventually cause corrosion, shorts, connector oxidation, and gradual damage over time.
3 - I strongly disagree with the statement that Peltier modules degrade easily over time. I was talking about creating a simple external accessory — something that already exists in thousands of products out there. With all due respect, saying that this would not work is simply not true. In practice, this external solution works — and works very well. The major advantage is that I do not need to cut the case, solder a fan, or permanently modify the device in any way. Especially because there is very little internal space for an ideal heatsink solution anyway — which is exactly why the rear cover needs a redesign in the future. That is the truth: the current thermal solution is neither efficient nor effective enough.
4 - Regarding the degradation of Peltier modules, that was actually the point that bothered me the most. Modern electrical substations often need to dissipate extremely high temperatures, and one of the most effective methods used is precisely Peltier-based cooling. In conclusion, external Peltier modules do work externally, and they work very well. In this case, condensation is not really a problem because the heat exchange is efficient enough that condensation becomes practically nonexistent.
In the end, people will do what works best for them. From my own experience, this external module helped solve my biggest problem: heat. Personally, I think this solution is far better than cutting my case, soldering in a fan, or modifying the product in a permanent way. It was the simplest solution I found — and most importantly, it works.
Note: it works so well that, regarding your claim that Peltier modules “destroy themselves easily” — which is simply not true — even if that were the case, I could very easily replace the Peltier module itself. As I said, it is external, magnetic, and I could simply swap one module for another without even opening the device. And honestly, I am very happy with this solution.
Note 2: Regarding the CM5, the SD card issue exists because it shares circuitry with the eMMC, and in my opinion, this is another design flaw. The Lite series does not have this “problem,” but when designing a chip, you have to think about safeguards and future flexibility. Maybe Raspberry Pi will eventually solve this through firmware updates — otherwise, consumers will end up very frustrated, just like I was. For now, whenever I want to use my SD cards (I have around 10 cards with different operating systems), I simply downgrade from the CM5 back to the CM4.
Tkz
If you’re having that much trouble, another device might be a better option for you.
My life is solving problems. For me, solving problems is real happiness. I truly love this device, and that’s exactly why I bought it — and why I try to cooperate by identifying simple solutions that can help the community and improve the product. As a consumer, that matters too, because I want to see it evolve. The idea behind it is brilliant, and if everyone contributes, we’ll end up with something even better.
Simple as that: I like this product so much that I chose to spend my own time trying to help. In the end, everyone can decide for themselves, but for me, this works, and I just wanted to share it.
I assume you are responding to what I wrote specifically because I have thus far been the only one in this topic to technically assess what you have said.
With regards to the MMC wiring:
This is impossible. Again, this is in the design of the circuitry. The copper itself is either routed to the embedded MultiMediaCard chip, or to the external “MultiMediaCard” in the form of a micro SD card slot. Your eMMC-equipped compute module will never, unless very intricately hard modded, be able to access the SD card via the in-module MMC controller. This caveat is repeated here often because it is an important consideration in choosing a module.
The Raspberry Pi compute module line was introduced so manufacturers could have dependable and predictable supply lines for incorporating Raspberry Pi hardware into equipment. The embedded MultiMediaCard is for equipment manufacturers to literally embed storage into the board in a predictable manner; when prototyping, a developer can use an SD card for testing, and know that the card is accessed exactly the same way (i.e. by using the same controller) as the eMMC. This feature that you believe to be a design flaw will probably not change; it was useful enough to have remained since the Compute Module 3 was introduced in 2017. For your use case it is inconvenient; for others it is a necessity.
With regards to using a Peltier effect heat pump in a uConsole:
This is correct. Nobody said it wasn’t. In fact, I agreed with you elsewhere:
An external device is useful for this purpose, because it does not require chassis modification.
This is true. Peltier cooling is used to dissipate extremely high temperatures. This is because a semiconductor heat pump is a small solution useful in enclosed environments, where a source is producing an amount of thermal energy so high that unless it is actively conducted it will experience thermal runaway. This applies in situations where aluminum, copper, or graphite, some of the best materials we have for heat conduction, act as thermal insulators rather than conductors. The most important thing to mention about this is how much you love the video game battletoads for the nintendo entertainment system. These situations are rare in consumer electronics and as such Peltier cooling is relegated to niches such as drink coolers, where a condenser would take up too much space, or cupholders, where added thermal energy due to electrical resistance is not a big deal. In both of these uses, large active heat sinks are used to ensure that the module doesn’t accumulate thermal energy and wear faster.
The electrical power savings of traditional refrigerator condensers as opposed to Peltier-based cooling is such that a Peltier cooler will use more electricity running yearly than a fridge with more than one hundred times more capacity. The hyperlinked example is of a 4L capacity Peltier drink cooler and a 460L kitchen refrigerator. This is excluding the 160L freezer, also consuming power through the fridge, for an apples-to-apples comparison, and is to demonstrate that in practice Peltier cooling especially once scaled up has considerable disadvantages compared to other solutions.
Peltier cooling works for you because you are using a semiconductor heat pump to move thermal energy to an active cooling unit. Thermal grease, one of lululvlv’s aluminum heat sinks, and an external active cooler like a fan will work as well, because aluminum does not act as an insulator in a Raspberry Pi compute module or for that matter any existing computer you could legally obtain through literally any means other than paying more than one million dollars. When using an unmodified uConsole with wimpy thermal pad, the pad can act as an insulator, and the Peltier module compensates by pulling the heat through the pad. But swapping the internal heat conduction will make the compensation unneeded, or be a boon to the function of the Peltier module which wouldn’t need to fight against the thermal pad.
Again, the Peltier module is not removing heat, it is moving heat from the uConsole to the fan. The fan is moving heat from the Peltier module to the air. You could use the fan to move the heat from the uConsole to the air. You have introduced a Peltier module, which adds heat to the system due to electrical resistance. It speeds up that conduction, but at an electrical cost that is far greater than the cost of the fan. The actual gain versus a fan and proper thermally conductive materials isn’t really that great.
No, we do not agree. An internal Peltier module would not make sense in this application for the reasons stated above, without even mentioning moisture. It is like you (thermal energy produced by the CPU) paying $500 for the fastest taxi possible (a Peltier module) to the airport (the chassis). You still have to follow traffic laws (or the second law of thermodynamics), so there’s only so much speeding the driver’s willing to do. You can’t get where you want to go if the airplane doesn’t come (if heat isn’t dispersed into the air). And while hitchhiking (using the in-box thermal pad) is a worse way to get there, this journey isn’t usually worth $500.
Now, speaking of the second law of thermodynamics, which says energy cannot be created or destroyed within a system, I should explain how the lifespan of an uncooled Peltier module will degrade. If you do not cool the hot side of the Peltier module, for example, with a fan, like your existing solution does, the Peltier module will be unable to cool down, because it moves thermal energy faster than it disperses into the air. This thermal energy, which cannot disperse into the air, is not “canceled out” by the power you supply to it, but collects within the module itself. Peltier modules as semiconductors have a temperature rating outside of which their manufacturer does not guarantee function. Exceeding that rating will at best cause thermal stress and at worst cause melting, not in the module exterior but in the interior where solder joints may decouple.
This isn’t easy degradation. This is killing a part by operating it far outside the context in which it is intended. Peltier modules can and do last a long time when heat is removed from them. Your consumer Peltier cooling solution has a fan attached for this reason and will last a long time. An internal Peltier module without a fan will fail within months. You could say this is a design flaw in the nature of physics itself.
I personally like my uConsole exactly the way it is because it can fit in my purse. Using aluminum heat sinking and Insignia (Best Buy’s generic-brand) thermal paste, my uConsole is 45 degrees Celsius, 20 degrees above room temperature. This is on a CM5 without tweaks. This is a rugged handheld which is designed to survive abuse. Making it larger, adding a vent grill and active cooling, and other unexplored possibilities like a Betamax VCR or integrated coffee maker would make it suit a different use case.
At the end of the day, your uConsole is yours with which to do what you wish. I encourage you to try whatever you want to try and I wish you good luck and happy modding.
Every environment creates its own engineering.
I read your technical explanation carefully and, honestly, it is solid. There is something rare in technical discussions when someone manages to separate personal preference from basic physics — and your text does exactly that. Your point that a Peltier module does not “remove” heat, but rather moves thermal energy, is correct. Thermodynamics remains intact. It always will.
But there is one detail that completely changes the conversation: environmental context.
Today, in Rio de Janeiro, we are talking about roughly 34°C — around 93.2°F — with high humidity, close to the Equator, inside a tropical environment where ambient temperature and moisture saturation completely change the thermal profile of compact devices. In places like this, dissipating heat simply by “spreading” thermal energy into the air is not always enough, because the air itself is already hot. In hot and humid environments, temperature regulation often requires active cooling. Not for aesthetics. For physics.
And this is exactly where Peltier cooling starts making sense for certain specific scenarios.
In my case, the goal was never to challenge the laws of thermodynamics. Quite the opposite: I am fully respecting them. The Peltier module simply accelerates thermal transfer toward an external active cooling solution. I am currently testing smaller modules — the latest one is only 2 cm tall — and it can simply be removed during colder days. Although, honestly, “cold days” in Rio de Janeiro are almost mythical events.
The real discussion may be less about “Peltier versus fan” and more about operational profile.
Someone using a uConsole indoors, in mild weather, with light workloads, will experience a completely different thermal reality compared to someone running SDR, LoRa, GPS, and radio analysis in the field, under tropical heat, with sustained CM5 load. Every thermal profile changes according to location, humidity, altitude, airflow, and workload.
That is why I still believe a redesigned rear cover with improved airflow would be extremely welcome. Not necessarily to transform the uConsole into a heavily ventilated gaming handheld, but to provide more efficient thermal pathways for extreme operational scenarios.
In the end, interestingly enough, I did not lose mobility. What I lost was roughly one hour of battery life. In exchange, I can now reliably operate SDRs, radio analysis, GPS, satellite, and LoRa systems in the field. For me, that trade-off made sense.
Regarding the CM5, I still believe that any evolution that removes practical and valuable functionality should be reconsidered carefully. That is simply my point of view — and I fully respect different opinions. In the end, everyone ends up shaping solutions around their own operational needs. In chips, sometimes not adding a new trace means saving millions on the production line. And in the end, I do not know whether it is truly impossible to remap another pin, another path in the circuit, or reroute things purely through software, or even through an external board that intercepts and reroutes signals. I know solutions like that exist for ESP32 platforms… but I am only inferring here. I do not actually know if it would work.
To be certain that it is truly impossible, I would need to study the entire schematic carefully, but I honestly do not have the time for that. And, as I said before, my real interest is radio.
Maybe one day I will get excited enough to think about something in the future and build a “gambiarra” — by soldering a few IO pins. Which is how we call these improvised adaptations in Brazil.
And perhaps that is the best part about projects like the uConsole: nobody uses them exactly the same way.
Good luck with your experiments, and happy modding. And honestly: if you ever have the chance, try an external Peltier cooler someday. Even if only for the technical curiosity.
Just sharing. Attached is a simple monitoring script designed to track the system’s cooling and thermal behavior, including:
  • Temperature levels and thermal criticality;
  • Fan operation and performance;
  • Thermal efficiency and cooling effectiveness;
  • Energy efficiency and power behavior.
#!/usr/bin/env bash
# Copyright (C) 2026 Wander Menezes
# Licensed under the GNU General Public License v3.0 or later.
INTERVAL=2
WIDTH=16
GREEN="\033[32m"
YELLOW="\033[33m"
RED="\033[31m"
BLUE="\033[36m"
BOLD="\033[1m"
RESET="\033[0m"
START_TS=$(date +%s)
LAST_TS=""
LAST_TEMP=""
FAN_ON_SEC=0
FAN_TOTAL_SEC=0
ok() { echo -e "${GREEN}$1${RESET}"; }
warn() { echo -e "${YELLOW}$1${RESET}"; }
bad() { echo -e "${RED}$1${RESET}"; }
info() { echo -e "${BLUE}$1${RESET}"; }
paint_status() {
  case "$1" in
    OK*) echo -e "${GREEN}$1${RESET}" ;;
    NOTICE*|ATTENTION*|WARNING*|ALERT*) echo -e "${YELLOW}$1${RESET}" ;;
    BAD*|VERY\ BAD*|CRITICAL*) echo -e "${RED}$1${RESET}" ;;
    N/A*) echo -e "${YELLOW}$1${RESET}" ;;
    *) echo -e "${BLUE}$1${RESET}" ;;
  esac
clamp_pct() {
  local pct="${1%.*}"
  [[ -z "$pct" || "$pct" == "N/A" ]] && pct=0
  (( pct < 0 )) && pct=0
  (( pct > 100 )) && pct=100
  echo "$pct"
bar_draw() {
  local pct color filled empty
  pct=$(clamp_pct "$1")
  color="$2"
  filled=$((pct * WIDTH / 100))
  empty=$((WIDTH - filled))
  echo -ne "$color"
  if (( filled > 0 )); then
    printf "%0.s█" $(seq 1 "$filled")
  fi
  echo -ne "$RESET"
  if (( empty > 0 )); then
    printf "%0.s░" $(seq 1 "$empty")
  fi
# Use this when HIGHER is BETTER.
# Example: battery state of charge, battery health/capacity.
bar_high_good() {
  local pct color
  if (( pct >= 60 )); then color="$GREEN"
  elif (( pct >= 30 )); then color="$YELLOW"
  else color="$RED"
  fi
  bar_draw "$pct" "$color"
# Use this when HIGHER means MORE STRESS / MORE RISK.
# Example: thermal load, CPU load, fan effort.
bar_high_bad() {
  local pct color
  if (( pct < 60 )); then color="$GREEN"
  elif (( pct < 85 )); then color="$YELLOW"
  else color="$RED"
  fi
# Use this for informational gauges where the value itself is not a fault.
bar_neutral() {
  local pct
  bar_draw "$pct" "$BLUE"
read_sys() {
  [[ -r "$1" ]] && cat "$1" 2>/dev/null || echo ""
fmt_time() {
  awk -v h="$1" '
  BEGIN {
    if (h < 0) h = 0;
    total = int(h * 60 + 0.5);
    hh = int(total / 60);
    mm = total % 60;
    printf "%dh%02dmin", hh, mm;
fmt_seconds() {
  local s="$1"
  local h=$((s / 3600))
  local m=$(((s % 3600) / 60))
  printf "%dh%02dmin" "$h" "$m"
find_battery() {
  for p in /sys/class/power_supply/*; do
    [[ -d "$p" ]] || continue
    [[ "$(read_sys "$p/type")" == "Battery" ]] && echo "$p" && return
  done
ac_online() {
    type=$(read_sys "$p/type")
    online=$(read_sys "$p/online")
    case "$type" in
      Mains|USB|USB_C|USB_PD|AC)
        [[ "$online" == "1" ]] && echo "1" && return
    esac
  done
  echo "0"
temp_cpu() {
  local max=""
  for z in /sys/class/thermal/thermal_zone*/temp; do
    [[ -r "$z" ]] || continue
    v=$(cat "$z")
    [[ "$v" =~ ^[0-9]+$ ]] || continue
    (( v > 1000 )) || continue
    c=$(awk "BEGIN {printf \"%.1f\", $v/1000}")
    if [[ -z "$max" ]] || awk "BEGIN {exit !($c > $max)}"; then
      max="$c"
    fi
  done
  echo "${max:-N/A}"
cpu_freq() {
  local f="/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq"
  [[ -r "$f" ]] && awk '{printf "%d", $1/1000}' "$f" || echo "N/A"
status_temp() {
  local t="$1"
  [[ "$t" == "N/A" ]] && echo "N/A" && return
  awk -v t="$t" '
  BEGIN {
    if (t < 40) print "OK: cool/normal";
    else if (t < 50) print "OK: warm";
    else if (t < 60) print "ATTENTION: warmer than ideal";
    else if (t < 70) print "BAD: thermal stress / possible throttling";
    else print "CRITICAL: reduce load/usage";
temp_trend() {
  local temp="$1"
  local now="$2"
  [[ "$temp" == "N/A" ]] && echo "TREND N/A" && return
  if [[ -z "$LAST_TEMP" || -z "$LAST_TS" ]]; then
    echo "TREND collecting thermal baseline"
    LAST_TEMP="$temp"
    LAST_TS="$now"
    return
  fi
  local dt=$((now - LAST_TS))
  [[ "$dt" -le 0 ]] && dt=1
  awk -v cur="$temp" -v last="$LAST_TEMP" -v dt="$dt" '
  BEGIN {
    rate = ((cur - last) / dt) * 60;
    if (rate > 0.3) {
      if (cur < 60) {
        eta = (60 - cur) / rate;
        printf "TREND +%.1f°C/min | 60°C in %.0fmin", rate, eta;
      } else {
        printf "TREND +%.1f°C/min | already in hot zone", rate;
    } else if (rate < -0.3) {
      printf "TREND %.1f°C/min | cooling down", rate;
    } else {
      printf "TREND stable";
  LAST_TEMP="$temp"
  LAST_TS="$now"
status_voltage() {
  local v="$1"
  [[ -z "$v" || "$v" == "N/A" ]] && echo "N/A" && return
  awk -v v="$v" '
  BEGIN {
    if (v >= 4.15) print "OK: nearly full";
    else if (v >= 3.90) print "OK: healthy range";
    else if (v >= 3.70) print "OK: medium charge";
    else if (v >= 3.50) print "ATTENTION: low battery voltage";
    else if (v >= 3.30) print "BAD: low voltage";
    else print "CRITICAL: shutdown risk";
status_soc() {
  local c="$1"
  [[ -z "$c" || "$c" == "N/A" ]] && echo "N/A" && return
  if (( c >= 80 )); then echo "OK: high charge"
  elif (( c >= 40 )); then echo "OK: normal use"
  elif (( c >= 20 )); then echo "ATTENTION: plan charging"
  elif (( c >= 10 )); then echo "BAD: low battery"
  else echo "CRITICAL: save work"
  fi
health_from_energy() {
  local full="$1"
  local design="$2"
  [[ -z "$full" ]] && echo "N/A" && return
  if [[ -n "$design" && "$design" -gt 0 ]]; then
    awk -v f="$full" -v d="$design" '
    BEGIN {
      h=(f/d)*100;
      if (h > 100) h=100;
      if (h >= 90) printf "OK: health %.0f%%", h;
      else if (h >= 80) printf "OK: light wear %.0f%%", h;
      else if (h >= 70) printf "ATTENTION: visible wear %.0f%%", h;
      else printf "BAD: degraded battery %.0f%%", h;
  else
    awk -v f="$full" '
    BEGIN {
      wh=f/1000000;
      if (wh >= 23) printf "OK: high capacity %.2fWh", wh;
      else if (wh >= 20) printf "OK: acceptable capacity %.2fWh", wh;
      else if (wh >= 17) printf "ATTENTION: capacity loss %.2fWh", wh;
      else printf "BAD: low capacity %.2fWh", wh;
  fi
efficiency_status() {
  local stat="$1"
  local temp="$2"
  local curr="$3"
  local online="$4"
  local cap="$5"
  [[ "$temp" == "N/A" || -z "$curr" || "$curr" == "N/A" ]] && echo "N/A" && return
  [[ -z "$cap" || "$cap" == "N/A" ]] && cap=0
  awk -v s="$stat" -v t="$temp" -v a="$curr" -v online="$online" -v cap="$cap" '
  BEGIN {
    # Near-full charging state:
    # At high SoC, battery current becomes a poor proxy for total system power.
    # The PMIC may be in float/trickle mode and the system may be powered mostly
    # from USB-C while the battery receives only a very small maintenance current.
    if (online == 1 && s == "Charging" && cap >= 95 && a >= 0 && a < 0.15) {
      print "OK: float/trickle charging state";
      exit;
    if (online == 1 && s == "Full") {
      print "OK: external power / battery full";
      exit;
    score = 100;
    # Thermal penalty
    if (t >= 75) score -= 60;
    else if (t >= 65) score -= 40;
    else if (t >= 55) score -= 25;
    else if (t >= 45) score -= 10;
    # Charging efficiency heuristic.
    # Low charge current is only suspicious when battery is not near full.
    if (online == 1 && s == "Charging" && cap < 90) {
      if (a >= 0 && a < 0.20) score -= 30;
      else if (a >= 0 && a < 0.50) score -= 15;
    # Battery discharge heuristic.
    # Negative current means power is leaving the battery.
    # This is not automatically bad; it only becomes bad with heat.
    if (online == 0) {
      if (a < -3.0 && t >= 55) score -= 20;
      else if (a < -2.5 && t >= 50) score -= 10;
    if (score < 0) score = 0;
    if (score >= 90) printf "OK: highly efficient (%d%%)", score;
    else if (score >= 75) printf "OK: efficient (%d%%)", score;
    else if (score >= 55) printf "ATTENTION: acceptable efficiency (%d%%)", score;
    else if (score >= 35) printf "BAD: low efficiency (%d%%)", score;
    else printf "BAD: poor efficiency (%d%%)", score;
predict_runtime() {
  local online="$1"
  local stat="$2"
  local cap="$3"
  local enow="$4"
  local efull="$5"
  local pwr="$6"
  local temp="$7"
  [[ -z "$enow" || -z "$efull" || "$pwr" == "N/A" ]] && echo "PRED  N/A" && return
  result=$(awk -v online="$online" -v s="$stat" -v cap="$cap" -v now="$enow" -v full="$efull" -v p="$pwr" -v t="$temp" '
  BEGIN {
    nowwh = now / 1000000;
    fullwh = full / 1000000;
    remain = fullwh - nowwh;
    temp_factor = 1.0;
    if (t >= 70) temp_factor = 1.45;
    else if (t >= 60) temp_factor = 1.30;
    else if (t >= 50) temp_factor = 1.18;
    else if (t >= 40) temp_factor = 1.08;
    low_draw  = 3.0 * temp_factor;
    med_draw  = 5.0 * temp_factor;
    high_draw = 8.0 * temp_factor;
      print "PRED  plugged in: battery full | runtime not applicable";
      exit;
    if (online == 1 && s == "Charging") {
      if (cap >= 95 && p < 0.30) {
        print "PRED  plugged in: battery will not drain | float/trickle charging";
        exit;
      taper = 1.0;
      if (cap >= 95) taper = 3.0;
      else if (cap >= 90) taper = 2.3;
      else if (cap >= 85) taper = 1.8;
      else if (cap >= 80) taper = 1.5;
      if (p <= 0) {
        print "PRED  plugged in: charge time not reliable";
        exit;
      charge_time = (remain / p) * taper;
      if (charge_time < 0) charge_time = 0;
      printf "CHARGE %.4f", charge_time;
      exit;
    if (online == 1) {
      print "PRED  plugged in: battery should not drain | not charging";
      exit;
    printf "RUNTIME %.4f %.4f %.4f", nowwh/low_draw, nowwh/med_draw, nowwh/high_draw;
  if [[ "$result" == CHARGE* ]]; then
    h=$(echo "$result" | awk '{print $2}')
    echo "PRED  plugged in: battery will not drain | full in $(fmt_time "$h")"
  elif [[ "$result" == RUNTIME* ]]; then
    low=$(echo "$result" | awk '{print $2}')
    med=$(echo "$result" | awk '{print $3}')
    high=$(echo "$result" | awk '{print $4}')
    echo "PRED  battery: low $(fmt_time "$low") | medium $(fmt_time "$med") | high $(fmt_time "$high")"
  else
    echo "$result"
  fi
fan_block() {
  local dev type cur max pct delta duty
  for dev in /sys/class/thermal/cooling_device*; do
    [[ -d "$dev" ]] || continue
    type=$(read_sys "$dev/type")
    [[ "$type" == "pwm-fan" ]] || continue
    cur=$(read_sys "$dev/cur_state")
    max=$(read_sys "$dev/max_state")
    [[ -z "$cur" ]] && cur="0"
    [[ -z "$max" || "$max" == "0" ]] && max="255"
    pct=$(awk "BEGIN {printf \"%.0f\", ($cur/$max)*100}")
    delta=$INTERVAL
    FAN_TOTAL_SEC=$((FAN_TOTAL_SEC + delta))
    if (( cur > 0 )); then
      FAN_ON_SEC=$((FAN_ON_SEC + delta))
    fi
    duty=$(awk "BEGIN {printf \"%.0f\", ($FAN_ON_SEC/$FAN_TOTAL_SEC)*100}")
    echo -e "FAN   [$(bar_high_bad "$pct")] ${BOLD}${pct}%${RESET}"
    echo -e "DEV   ${BLUE}$(basename "$dev") / $type${RESET}"
    echo -e "PWM   ${BOLD}${cur}/${max}${RESET}"
      ok "STAT  on"
    else
      ok "STAT  off"
    fi
    if (( cur == 0 )); then
      ok "DIAG  fan stopped or temperature below trigger"
    elif (( pct >= 90 )); then
      ok "DIAG  fan at maximum speed"
    elif (( pct >= 40 )); then
      ok "DIAG  fan at partial speed"
    else
      warn "DIAG  fan at low speed"
    fi
    echo -e "TIME  on $(fmt_seconds "$FAN_ON_SEC") | duty ${BOLD}${duty}%${RESET}"
    return
  done
  warn "FAN   not detected"
  warn "DIAG  no cooling_device type=pwm-fan"
battery_block() {
  local BAT NAME CAP STAT VOLT_RAW CURR_RAW PWR_RAW
  local ENOW EFULL EDESIGN
  local VOLT_A CURR_A PWR_W ONLINE
  BAT=$(find_battery)
  ONLINE=$(ac_online)
  if [[ -z "$BAT" ]]; then
    bad "BAT   not detected"
    warn "DIAG  no device type=Battery"
    return
  fi
  NAME=$(basename "$BAT")
  CAP=$(read_sys "$BAT/capacity")
  STAT=$(read_sys "$BAT/status")
  VOLT_RAW=$(read_sys "$BAT/voltage_now")
  CURR_RAW=$(read_sys "$BAT/current_now")
  PWR_RAW=$(read_sys "$BAT/power_now")
  ENOW=$(read_sys "$BAT/energy_now")
  EFULL=$(read_sys "$BAT/energy_full")
  EDESIGN=$(read_sys "$BAT/energy_full_design")
  [[ -z "$ENOW" ]] && ENOW=$(read_sys "$BAT/charge_now")
  [[ -z "$EFULL" ]] && EFULL=$(read_sys "$BAT/charge_full")
  [[ -z "$EDESIGN" ]] && EDESIGN=$(read_sys "$BAT/charge_full_design")
  [[ -z "$CAP" ]] && CAP="N/A"
  [[ -z "$STAT" ]] && STAT="Unknown"
  [[ -n "$VOLT_RAW" ]] && VOLT_A=$(awk "BEGIN {printf \"%.2f\", $VOLT_RAW/1000000}")
  [[ -n "$CURR_RAW" ]] && CURR_A=$(awk "BEGIN {printf \"%.2f\", $CURR_RAW/1000000}")
  if [[ -n "$PWR_RAW" && "$PWR_RAW" =~ ^[0-9]+$ && "$PWR_RAW" -gt 0 ]]; then
    PWR_W=$(awk "BEGIN {printf \"%.2f\", $PWR_RAW/1000000}")
  elif [[ -n "$VOLT_A" && -n "$CURR_A" ]]; then
    PWR_W=$(awk "BEGIN {printf \"%.2f\", $VOLT_A*$CURR_A}")
  else
    PWR_W="N/A"
  fi
  echo -e "BAT   [$(bar_high_good "$CAP")] ${BOLD}${CAP}%${RESET}"
  echo "      $(paint_status "$(status_soc "$CAP")")"
  echo -e "DEV   ${BLUE}${NAME}${RESET}"
  if [[ "$ONLINE" == "1" ]]; then
    echo -e "SRC   ${GREEN}plugged in / USB-C detected${RESET}"
  else
    echo -e "SRC   ${BLUE}battery${RESET}"
  fi
  echo -e "STAT  ${BLUE}${STAT}${RESET}"
  echo -e "VOLT  ${BOLD}${VOLT_A:-N/A} V${RESET}"
  echo "      $(paint_status "$(status_voltage "$VOLT_A")")"
  echo -e "CURR  ${BOLD}${CURR_A:-N/A} A${RESET}"
  if [[ "$ONLINE" == "1" && "$STAT" == "Charging" ]]; then
    ok "      current entering the battery"
  elif [[ "$ONLINE" == "0" ]]; then
    info "      estimated battery discharge current"
  else
    info "      observed current"
  fi
  echo -e "PWR   ${BOLD}${PWR_W} W${RESET}"
  info "      calculated as voltage x current"
  if [[ -n "$ENOW" && -n "$EFULL" ]]; then
    awk "BEGIN {printf \"ENG   %.2f / %.2f Wh\n\", $ENOW/1000000, $EFULL/1000000}"
    echo "      $(paint_status "$(health_from_energy "$EFULL" "$EDESIGN")")"
    info "$(predict_runtime "$ONLINE" "$STAT" "$CAP" "$ENOW" "$EFULL" "$PWR_W" "$TEMP")"
  else
    warn "ENG   N/A"
  fi
  echo "EFF   $(paint_status "$(efficiency_status "$STAT" "$TEMP" "$CURR_A" "$ONLINE" "$CAP")")"
while true; do
  clear
  NOW_TS=$(date +%s)
  TEMP=$(temp_cpu)
  FREQ=$(cpu_freq)
  LOAD=$(cut -d' ' -f1-3 /proc/loadavg)
  CORES=$(nproc)
  LOAD1=$(echo "$LOAD" | awk '{print $1}')
  LOADP=$(awk "BEGIN {printf \"%.0f\", ($LOAD1/$CORES)*100}")
  echo -e "${BOLD}${BLUE}uConsole Battery / Thermal / Fan Diagnostic${RESET}"
  date "+%Y-%m-%d %H:%M:%S"
  echo "────────────────────────────────────────"
  echo -e "LOAD  [$(bar_high_bad "$LOADP")] ${BOLD}${LOADP}%${RESET}  $LOAD"
  info "      system load vs CPU cores"
  echo -e "FREQ  ${BOLD}${FREQ} MHz${RESET}"
  if [[ "$TEMP" != "N/A" ]]; then
    echo -e "TEMP  [$(bar_high_bad "${TEMP%.*}")] ${BOLD}${TEMP} °C${RESET}"
    echo "      $(paint_status "$(status_temp "$TEMP")")"
    echo "      $(paint_status "$(temp_trend "$TEMP" "$NOW_TS")")"
  else
    warn "TEMP  N/A"
  fi
  battery_block
  fan_block
  echo -e "${BLUE}CTRL+C to exit | ${INTERVAL}s${RESET}"
  sleep "$INTERVAL"
done
Note: Created on: Linux clockworkpi 6.12.93-v8-16k+ #4 SMP PREEMPT Thu Jun 11 20:31:33 EDT 2026 aarch64 GNU/Linux — Debian Trixie
Hello everyone,
Sharing this again. I lost one battle and won another. I finally achieved my target operating temperatures: between 95°F and 107.6°F (35°C to 42°C). So yes, I won the thermal battle without committing any crimes against the laws of thermodynamics. :blush:
Here’s how I did it and the components I used.
I built this solution to solve what is, for me, the main challenge of running a CM5 inside a uConsole here in Rio de Janeiro, Brazil: removing heat efficiently without draining the uConsole’s own battery.
Heat leaves the CM5 components through an ARCTIC TP-3. Although it is often mistaken for thermal paste, it is actually a highly conformable thermal pad that molds itself to the components, eliminating gaps and compensating for height differences. Next, a 1 mm copper plate spreads the heat over a much larger area, reducing hotspots.
After that, I use two different thermal pads. The Cooler Master Purple Pad primarily serves as a mechanical compliance layer and thermal interface between the copper plate and the upper layers. The Gelid GP-Extreme was chosen for its high thermal conductivity, helping transfer as much heat as possible to the uConsole’s aluminum back cover.
The aluminum cover then becomes a large heat spreader. Finally, a ZZ TH10 active Peltier cooler, magnetically attached to the cover, extracts heat from the system without consuming power from the uConsole itself, thanks to its own 5000 mAh battery, which provides approximately two hours of runtime.
In short, every layer has a specific purpose: the ARCTIC TP-3 provides contact, the copper spreads the heat, the Purple Pad accommodates and transfers it, the Gelid maximizes conduction to the aluminum cover, and the TH10 actively removes the heat from the system.
The result is a hybrid passive/active cooling solution optimized for heavy workloads such as SDR, DSD-FME, LoRa, Wi-Fi monitoring, and continuous processing on the CM5.
I won the thermal battle. And yes, I solved my problem. It took some work, but I’m really happy with the results. I didn’t modify ANYTHING in the original design, because I genuinely love the original cyberdeck concept.
As for the cooler, whenever someone asks me what it is, I usually tell them it’s a miniature nuclear generator. :grinning_face_with_smiling_eyes:
Jokes aside, it actually complements the uConsole’s retro-futuristic aesthetic quite well, and I think it ended up looking pretty cool. :smiling_face_with_three_hearts:
Thermal Solution Components:
  1. ARCTIC TP-3 Thermal Pad
  1. 1 mm Pure Copper Plate (Heat Spreader)
  1. Cooler Master Thermal Pad Purple 1 mm
  1. Gelid GP-Extreme Thermal Pad 1 mm
  1. ZZ TH10 Magnetic Peltier Cooler (5000mAh Battery)
https://www.aliexpress.com/wholesale?SearchText=TH10+Peltier+Cooler
https://www.alibaba.com/product-detail/SMONAMA-TH10-Best-Portable-Semiconductor-5000mAh_1601462744189.html
Are you being serious, or is this a belated April Fool’s joke?
May I ask how does “magnetic attachment to aluminium cover” work? Very interesting concept!
magnetic personality?
Sorry, I used the infographic because it was easier to understand, but I didn’t include an actual photo of the uConsole.
I understand your question, but it’s actually quite simple: aluminum is not magnetic, so it doesn’t attract magnets. Any of these phone cooling systems comes with an adhesive metal plate that is both magnetic and thermally conductive. You simply stick that plate to the back cover, and then you can attach the cooler to the uConsole.
If you’re sitting at your desk, you can connect the battery to a USB cable. To make things easier, I use magnetic USB cables. I’m trying to find a dual one so I can charge both the cooler’s battery and the uConsole at the same time.
Nah, I’m just a little antisocial sometimes, but not all the time. :grin:
I didn’t quite get what you meant. Were you just joking around?
  • Are you using lululvlv’s heat spreader?
  • I really would rather see your LLM prompts than their output.
  • 5Ah * 3.7V (a typical rechargeable battery nominal voltage) = 18.5Wh; 18.5Wh / 2h = 9.5W power usage, which sounds like a lot of energy being used just on the cooling system. My CM5 (Lite 16GB), screen, AIOv1, and keyboard backlight use about 7W all together.
  • On your thermal energy pipeline chart, you didn’t include the adhesive nor the magnet attaching the cooler to the chassis. As serial thermal resistance is summed I’d be curious as to how much they add.
Why two thermal pads instead of a thicker piece of copper, surely the copper is a better heat conductor than the pads and you want to minimize the number of transitions
The cooling is achieved by the active peltier cooler. The many different layers are more of a barrier than a beneficial feature.
Thickness matters. Thermal interfaces matter. Air pockets matter. Gaps between components matter. Power consumption matters. Current capacity is essential when you’re using SDR and radio applications. Reducing thermal gaps between elements matters.
In short, all of this has been documented throughout my testing.
If someone has a better idea, that’s great—please document it, build it, test it, and share the results. I genuinely welcome improvements.
At this point, I think I’ll only do one final update with the new block. I’ve already achieved my original goal. I’m using the uConsole for SDR and radio research, and I’m not going to cut or permanently modify my uConsole.
The objective was reached. If I can reduce temperatures even further with Lulu’s heat spreader, great. If not, I’ll keep using the current stack because it works for my use case, delivers the temperatures I need, and allows me to preserve battery life by keeping the cooling system external.
Respectfully, the issue isn’t the layers. The real reason it works is that the Peltier cooler is being used properly and in the right way.
