I ordered one more uconsole and the CM5(to be used in the new uconsole from another shop), but the cm5 arrived first.
So I took out the CM4 in using uconsole and set CM5 in there, but it didn’t power up.
If I change to cm5 while using cm4. Should I reinstall os on my sd card ?
depends on the image you used. with my images you can change between the cm3, 4, and 5 with the same install. the stock clockwork image only works with the cm4.
I also ordered the AIO module after reading about the aio package written by rex.
(I haven’t received it yet)
If I set the SDcard again, would it be better to set it as bookwarm OS or Ubuntu OS?
I need your teaching.
