Installing a BNC?
I’ve got some time before my uConsole ships, so I’m currently in planning mode. I plan on adding SDR to my unit and I got to wondering if anyone has tried installing a BNC connector? They tend to be better for antennas (at least for me). Here’s a pic of what I’m thinking of installing:
I doubt there will be enough room or maybe not even thickness for a chassis mount bnc. If you can print a case extension then you might have a better time.
Sma connectors barely fit… If you are going larger, they’ll have to go on the back panel above the thermal pad for the CPU.
Alright, so I may have to settle for an SMA to BNC adapter instead. Good to know. They’re pretty cheap and easy to come by. I have one on my Yaesu HT so I can switch antennas fast. This adapter should fit easily:
That or I could build a small antenna switcher as an outboard box.
For the BNC adapter i use one that’s a bit more solid. I got a handful for my most used radios and my hackrf.
Here’s the link. They’re pretty damn good and they look a bit better. :pinched_fingers:t5: Good luck and happy hacking. :call_me_hand:t5:
Amazon.com: 5 Packs Antenna Adapter SMA Male to BNC Female RF Coaxial Connector Adaptor for Ham Handheld Two Way Radio Antenna SMA-M/BNC-F : Electronics
Thanks for the link. Can’t wait for the uConsole to ship. I plan on really digging into if I can get a case mount usb to work. Glad to hear someone is using an adapter at least.
Oh man. I’m waiting on mine too. I’m literally chomping at the bit. I have a 3d printer and a game plan. I hope those adapters work well for you. I have them on everything I swap antennas on since SMA connectors have a limited amount of times you can connect and disconnect them. I look forward to seeing what you do with yours too. Good luck, bud. :call_me_hand:t5:
Exactly why I want to install BNC
This might be interesting to you!
Now I’m getting some fun ideas.
Finally got my uConsole. Might just have to go with an adapter. This case is surprisingly thin.
A high density BNC (HD-BNC) might fit, but still going to require adapters to get to an antenna.
Think I’m gonna wait for the SDR board before i consider what i might do to accommodate a BNC.
