main board has an external USB, an internal USB wired for keyboard then a USB port wired to the EXT expansion port (where the optional phone plugs in) I’ve downloaded the DevTerm printer/usb board schematics if the Motherboard for the uConsole is the same as the DevTerm then it is possible to design a board with a UART chip and two more USB ports to install where the phone modem goes… I wish they had offered the two more USB ports as an option
Can’t tell anything about the port/pins/connectors until the new revision of the main board is published. Making assumptions based just on the renderings or prototypes might be a bad idea as we don’t know their final design decisions.
Mainboard is more or less the same. For maximum core compatibility, only one USB host port is routed to the core.
The USB host port is then multiplexed into 4 downstream device ports with a GL850G usb hub chip.
These four ports are then routed to:
The cpi keyboard (pogo pins connected)
A type-A port along the mainboard edge
and 4 to the mPCIE connector
the 4G dongle most probably takes one of that
The question is whether they leave pads/pins for the last usb port on the 4G expansion board.
These are really good assumptions. I think you meant to say 2 to the mPCIe. It would make more sense to place the holes/pins/pads of at least one of the two additional internal USBs on the main board, rather than on the 4g module like you just mentioned, since not everyone will be having a 4g module purchased.
Thats the thing, @Sword wanted to access one of the internal USB ports. We can’t say anything precisely without the schematics/other design files
Thats a good reference for the ext module development. However, like I was saying, we need more clarity on the pinouts and other details of the clockworkPi v3.14 main board revision 5 before making modules for uConsole. At this point I couldn’t find any published design resources for uConsole. Please do share if you got some dependable sources.
Many of us are looking for just additional USB ports. If the team got pins/pads/holes for the internal USBs on the main board itself, we could get access to those ports even without an ext.module.
