My DevTerm Keyboard stopped responding after it fell off the table (the power cord hooked on my foot). My Bluetooth mouse still works
I have:
- pulled batteries and done a full restart
- disassembled and reassembled the unit to reseat the pogo pins.
I have:
Does the trackball work, (suspect not) Does an external USB keyboard work? Still suspect something isn’t setting quite right with those 4 pogo pins.
If the external works, bring up a terminal and try
lsusb -t
You should see all devices connected to the USB system.
Trackball does not work.
External Keyboard won’t respond (the num lock and caps lock keys also don’t light)
I have also tried a fresh image to make sure it’s not a software problem.
1,Don’t charge your devterm with PD charger, It will cause kerboard frozen.
2, You can connect a usb keyboard or SSH login, Try to update trackpoint firmware again, Then will solve this issue.( Maybe this make keyboard exit bootloader mode)
3, Or buy a ST Link cable following this thread to solve it permanently.
if you haven’t fixed it yet, try removing & reseating the CPU module.
keyboard on my A-06 comes and goes…reboot fixes it but sometimes it boots and keyboard mouse don’t respond… external USB keyboard and mouse work fine…
