My uConsole has no HDMI output
Has anyone else encountered this issue?
I’m using an official uConsole with a CM5 lite module and Rex’s Trixie-7.1.4 image.
When I plug in a micro-HDMI cable, the uConsole’s screen flickers, but the external display remains blank.
I have updated the EEPROM.
have you tried a different cable?
(post deleted by author)
I’m so glad to receive your reply! Thank you for creating the Trixie image!
I currently only have one cable, so I can’t rule out the cable being the problem.
There’s something a bit strange: with the same cable, when I switched it to the other HDMI port on the monitor (not the one that supports HDMI/ARC), the screen was no longer black; instead, I could see the image—the wallpaper was displayed in full screen—but I couldn’t see the mouse cursor or the taskbar :joy:
it was displaying as a second monitor. if you go to the monitor/display settings you can change it to mirror.
move cursor to some of the sides/corners. you can change virtual relative display position somewhere in settings
