New PicoCalc not booting
I just recieved my PicoCalc and assembled it. However, when I turn it on, it doesn’t seem to be booting.
  • I see the screen get a little lighter–but the screen is otherwise blank.
  • I can adjust both the keyboard lighting and the screen brightness using the keyboard, but nothing else seems to respond.
Any ideas on getting it up and running?
Try to flash a firmware for checking
Assuming you are using PICO 1
  • download the uf2
  • press BOOTSEL on Pico and plug the Micro-usb cable into Pico too
  • copy the uf2 into PICO,on windows there will be a new disk ,on linux there will be like /media/$USER/RPI-XXX
  • once copying done, pico will reset automaticly, unplug the Micro-USB cable
  • Plug USB type C cable into PicoCalc TYPE C port
  • Press Power ON
Normally picocalc will boot up and you will see PicoMite prompt interface
if Not , double check the assembling carefully
If still nothing happend
it’s time to send email to help@clockworkpi.com
Thanks. The Pico disk wasn’t showing on my computer when I did the BOOTSEL + microusb connection, so I took a closer look at the Pico and noticed it wan’t seated properly. After fixing that, everything’s working as expected.
