New uConsole will not turn on
Finally got mine.
Assembled per instructions, will not boot.
CM4 without wifi.
Re-inserted battery tray, no joy.
Removed 4G board, no joy.
Removed batteries ( left battery board in ), no joy.
Removed CM4 and carrier board, no joy.
Any other suggestions?
Thanks!
post a picture of the inside of the back of the device.
what os image are you using?
have you tried seeing the output of the hdmi?
I also, tried without the flash card in as removing battery board completely, while plugged into USB-C for power.
Still won’t boot.
It works with HDMI. :man_shrugging:
I’ll re-flash the TF card with the Clockwork image.
flash with this one: Trixie 6.12.y for the uConsole and DevTerm
hope you know what you are doing!
which cm4 did you get exactly? emmc?
Got it figured out.
Thanks!
Crappy flash card, so I flashed the eMMC using a 52Pi router board as a carrier.
CM4 8GB ram 32GB eMMC no WiFi.
if you have an eMMC board – you can’t use the flash drive. works only either of them.
