Omarchy (Hyprland) on the DevTerm A06 – notes, and why console=ttyS2 can freeze your A06
I got Omarchy 4.5 (DHH’s Arch + Hyprland setup, which supports aarch64 since 4.5) running on my DevTerm A06. Notes for anyone trying Hyprland/Wayland on the A06:
Base: Arch Linux ARM, kernel 7.2.10 from prokrypt/devterm-a06-kernel (+ Landlock for pacman 7), U-Boot 2022.04 with the rkbin chain (DDR v1.27, miniloader v1.26, BL31 v1.35) like yatli’s package, extlinux on a FAT32 partition from 16 MiB.
1. Don’t leave console=ttyS2,1500000 on the kernel command line without a cable. The UART picks up noise (ttyS2: 117 input overrun(s)), the kernel reads it as BREAK + SysRq keys, and you get endless sysrq: HELP … lines – and random valid ones (terminate/kill all tasks, crash). For me that meant hangs at boot and shutdown. Remove it unless the CH340 cable is plugged in.
2. Hyprland runs fine on Panfrost (Mali-T860). Hyprland 0.56 falls back to GLES 3.0. Panel: DSI-1, transform 3. Monitor scale must be set by hand (1.25 works well): the panel reports 0×0 mm, so “auto” picks 2. glmark2-es2-wayland: 218–1584 fps per scene; blur costs ~15 %, rotation nothing measurable. Ghostty doesn’t work (needs GL 4.3), foot does.
3. DMC simple_ondemand is stable with the rkbin blobs (3 rounds GPU load/idle, 27 transitions, no gpu sched timeout) and saves ~0.7–1 W at idle versus pinning it to performance. An earlier hang I blamed on DMC was actually point 1.
4. Audio on 7.x: Armbian’s ES8388 UCM boot sequence aborts because the kernel no longer has Left/Right Mixer Playback Switch. Use Left Mixer Right Playback Switch / Right Mixer Left Playback Switch instead (cross paths only – left/right may be swapped on headphones, not verified yet).
5. Power draw (2 × 12.6 Wh 18650, on battery, Omarchy idle): 4.6 W at brightness 9/9, 4.1 W at 5/9, 3.6 W at 2/9, 3.2 W at 0/9; GPU load 7.8–9 W, all-core CPU load 10.5 W (72 °C, A72s throttle to 1608 MHz). Omarchy’s animated screensaver adds ~2 W.
Small things: brightness keys only have 9 levels, so 5 % steps do nothing (raised with Omarchy); with Tailscale --accept-routes on Linux, add an ip rule … lookup main for directly connected networks or the home LAN goes through the tunnel; scrolling = hold middle mouse button and roll the trackball.
Happy to answer questions.
