Power off is OK, but reboot is useful too
Personally, I adjusted the PowerOFF script.
https://drive.google.com/file/d/1PhsYHMxgo6JwIEM7W_Cydg_6-9gL5TSh/view?usp=sharing
Don’t forget that an update will overwrite your changes if you change one of the launcher file
Yes me too, in the power off script i put sudo reboot instead of sudo halt
yes, any tips to keep our custom script after upgrade ?
just saw your script, we do the same thing
Nice!
Uh, we can ask them to change it (merge it? I’ve never used Github as a creator) on github? Then our tweak will be everyone’s tweak!
Mild Maniacal laughter
good idea, i will put a request on gameshell github
Could you guys please, make any nOOb guide for users like me that don´t know any about code? Thanks!
For now, you can download the _init _.py script from the link I provided, SCP into the gameshell and replace the file at /home/apps/launcher/menu/gameshell/poweroff with the one provided.
Since it will be deleted when the system updates, we are hoping to have it merged with a future update.
Or created a reboot directory (at same level as poweroff) and put the init.py file into it
With that, you keep the poweroff option
My script has both…
A for shutdown
Y for reboot
Or,
B for shutdown
X for reboot
If you are using xbox button placement
ohh, yes, it’s a good idea ! no need to get one program per action
I use your idea now
i have to change the confirmation message depends of the option
Thanks for the script this really cleans things up, I just changed my menu item to Power instead of PowerOFF and changed the prompt to “Awaiting Selection”.
During the init , we can only set up one page ?
It’s works for me! Thank you very much to both
Im just do the icon for thanks your help, hope you like it!
That makes way more sense!
I couldn’t think of a proper prompt
Again with the excellent icons!
I will be changing mine to this
for info i open an “issue” on the github requesting the change of the poweroff script to give the choice of a reboot action
and i copy /paste modified line of the script
