Retroarch Update URL
Just got back to trying to use my Gameshell. Having an issue with using the online updater for RetroArch to update config, cores etc… I just keep getting Task failed for every update I attempt. Surprisingly I’m not seeing that anyone else that has the same issue.
RetroArch version 1.8.8.
Update URL’s in retroarch.cfg
core_updater_buildbot_url = “http://buildbot.libretro.com/nightly/linux/armhf/latest/”
core_updater_buildbot_assets_url = “http://buildbot.libretro.com/assets/”
Anything any of you has seen before?
Thanks in advance!!
It appears the web server is down.
They just got hacked lol
I’m also getting this error. Is there a way to fix the issue. Thanks
The webserver is online now. However I am still getting the same error. Thanks
I was able to update using these URL’s in the retroarch.cfg file.
As a side, it might be worth updating the URL to
“http://buildbot.libretro.com/nightly/linux/armv7-neon-hf/latest/”
The CPI supports NEON instructions, so potentially you could get some cores built with compatible optimisations.
Great, thanks for the update!
