Hi guys i have made it simple once you get you sdr lora expanshion kits simply copy the config.txt to the system boot folder and replace depending on which cm you have cm4 or cm5. I highly recommend Rex Dragon ubuntu build for this.
Great work!!, i was wondering where did you get the GPS antenna from?
It is a prototype sample i am setting up for review. Antenna was of AliExpress
I just found this on AliExpress:
£29.05 | L1/L2 Dual Band Quadrifilar Helix RTK Antenna HA-301A for High-precision GNSS GPS/BD/GLONASS/GALILEO Satellite Navigation Signal
https://a.aliexpress.com/_EJNu0I2
Very Neat, What options are available if one should need 5 Gigabit USB?
Seems like you need usb 3.0 for it, uconsole doesn’t provide it now even on CM5
Common USB standards include: USB 2.0 –A widely used standard that offers a maximum transfer speed of 480 Mbps . USB 3.0/3.1/3.2 –Offer transfer speeds of up to 5 Gbps (USB 3.0),
but there is a 100MBit expansion card: uEther - extension module
What is the limiting factor? the CM4/CM5 module or the supporting board?
CM4 has no usb3 so CM4
for CM5 – connection board as it officially supports only CM4.
OK, what would be a reasonable time frame for an updated connection board for 5 Gigabit USB?
never? you can ask at help@clockworkpi.com
you can also check this thread: uConsole CM5 mainboard
Rex Dragon Ubuntu? Finding Dragon for Intel processors, not seeing Arm.
