uConsole CM5 mainboard
Hello,
I`m working on a mainboard for CM5.
Included for now:
-PCIe header(like on PI5)
-typeC USB3.0 port.
-Usb 2 port upgraded to USB3.0
-Added support for RADXA eMMC modules
-internal typeC usb3.0
-Posibility to program your cm5 via Charging port
I can`t find the:
-power heather(for battery board)
-specific minipci port for expansion cards
I was wondering if is needed by the community?
It’s cool, but some cm5 development boards do not have Wi-Fi, so we may need an external Wi-Fi network adapter interface, if the board has extra interfaces, or can be connected by FPC flat cable.
That was the idea, to implement PCIe for expansion cards(wifi, bluetooth, etc)
If I will have some space, I can add wifi module.
you may want to find a PMIC that can handle CM5’s power need and also charge the battery; in the same time you may better replace the original battery to make it larger and can handle more discharge power…
PI5 recommended psu is 5V 5A (consumption in normal usage is 4,7W and max out around 11W)
CM5 already has a PMIC for all the necessary voltages, I have to supply a constant 5V (I will try 5Amps)
For now we need 5V(cm5 and accessories), 3V3(memory and accessories), and 1V8(memory).
Is needed PD/QC implementation for charging?
Amazing job!
If I can make some suggestions (I don’t know how feasible they are),
-I would remove the micro HDMI and either put a full sized one or USB-C DP. MicroHDMI sucks.
-SSD native support or if you don’t have physical space put it on the mb a PCI-e for the disk and other PCI-e for expansion boards (wifi, bluetooth, etc)
-RJ45, or at least the capability to add it via PCI-e module, would be an amazing addition to the uConsole as the main target of this product are IT people. Something like this
-Capability to use microSD as extra storage
-Make expansion board ports more generic, I believe it’s shaped as PCI-E but the connectors dont match pci-e layout?
Yes I know, micro HDMI is bad, But I`m trying to reuse many parts from uConsole(case, display, expansion cards, etc), for Full-size HDMI I have to remove the headphone JACK…
It has PCIe-FFC connector, like PI5, you can connect any PCIe device compatible with PI5.
I don`t know if Ethernet is a good idea, the connector is bulky, but if needed I can add a FFC connector for it, and make later an addon board for Ethernet.
well… you may can use a mutil cell battery to avoid power losses in step-up, though you may need find a battery fit in uconsole (and possibly not touching the metal case in case of heat from pi get dissipated to battery.)
Yes I understand what you mean. But is the headphone jack used that much? I mean having bluetooth headphones or usb-c to 3.5mm adapter is the same and, at least myself, rather have an hdmi.
Regarding ethernet I know is bulky, but it would be really good to have it as an option, addon board seems nice :slight_smile:
I’d prefer a small internal SSD instead of the eMMC module because that would offer bigger and faster storage options. But that’s just me and everything else sounds great!
You can use the same method like on PI5, I included the same header for PCIe.
Or you can use the other internal USB3(typeC) port for USB boot(Pi5/cm5 support USB boot).
Yes of course. But than there’s the issue of mounting it in the small available space. Having room for a (short) SSD, just like on the Raspberry Pi CM5 Devkit would be awesome. But as I said, that’s just my opinion and since you’re designing the board, it is of course your decision alone.
For one, this is great. I wish you success as this is something we all want. I agree that a full size hdmi would be nice, but should not lose headphone port. I could also see going to 2 usb-c ports to save room and keep all functionality. or keep micro HDMI and tell people to use adapter like they do now. The PCIe expansion, USB 3 etc will be awesome!
I was thinking of adding USB PD support with qb25792 and multicell battery support.
Is it posible to make external usb3.2 for dock station like baseus unionjoy?
这是值得佩服和鼓励的工作,如果clockwork团队不更新主板,这将是最好的性能释放方案。
我在3月初刚订购了一台银色uConsole,希望夏天能拿到。
CM5 has just usb3.0 support. sorry.
Update:
PD charging and selectable 1s 2s 3s batterypack. I`m working to figure out how to get everything on that tiny board.
Can this add support for Radxa CM5 wifi&Bluetooth with sound support. As these are the issues at the moment with Radxa CM5.
A CM5 board would be amazing.
Just having the connectors down on the mainboard would create plenty of space to add a large copper block on the inside of the back casing to add some thermal mass and keep the CM5 in check.
And when it comes to the different ports and connectors on the board i’d say go for the same setup as the uconsole has today.
Add connectors on the board for internal PCI-E and USB3 and the community will figure stuff out by adding stuff after the fact, no need to reinvent the wheel here.
People will custom the stuff they want.
