Rubber feet for the PicoCalc
Do you have any solution to prevent the device from sliding around on smooth surfaces?
Hi!
I cut a few small rubber cylinders — I used the little anti-slip pads I salvaged from the base of an old monitor as raw material.
Now my PicoCalc no longer slides around all the time. It turned out to be a good, simple, and inexpensive solution :slight_smile:
This is a solution that I also had in mind.
Do they press fit or did you have to glue them?
The rubber pads I used already had their own adhesive backing.
But I suppose you could also glue them with a liquid adhesive, or just cut them slightly larger than the holes in the case so they stay firmly in place.
Here double taped transparent feet and hole pliers….
Has anyone just tried putting a tiny dab of rubber cement glue on the feet of the case? I tried, but my rubber cement jar contained just a big glob of “rubber”.:face_with_diagonal_mouth: I’ll be picking up some rubber cement tomorrow, or so, to give it a try.
Well, the rubber cement did not work. It was a bit tacky for a while, but then after I put it back in its case, the rubber cement wore off, and it left a tiny bit of (non-sticky) residue. My PicoCalc just slides around on my desk, like new.
Thanks for sharing. It was a good idea and worth a try.
Just standard sticky feet for now…
