maybe you can wait v0.4
The updater is for the launcher. Rule of thumb is that you’re recommended to keep your launcher up to date.
Good to know. I didn’t wanna update my old launcher with newer stuff and have it screw up lol to much work into getting it to run this smooth. Thnx!
I can always count on you, guu thanks!
Updated and am now stuck at the loading screen.
@guu - help me with a downgrade to 1.24 lol
first ssh into gs
then cat /tmp/x.log ,paste the results to here
it will show the errors
We got any word on the next version this radio silence is very disheartening
When will version 0.4 be released?
As soon as possible, it’s under test
I am interested in supporting opengl, if that is great.
Linux clockworkpi 4.14.2-clockworkpi-cpi3-g638f2a7 #1 SMP Mon Dec 10 07:46:56 UTC 2018 armv7l
__/////_/////____////_
//_________//_//_//_
//_/////_//_
//_//_//_
__/////_//__________////_
Welcome to clockworkPi
For more information please visit:
https://forum.clockworkpi.com
HAPPY HACKING
Last login: Tue Jun 18 14:33:39 2019
cpi@clockworkpi:~$ cat /tmp/x.log
X.Org X Server 1.19.2
Release Date: 2017-03-02
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.9.0-8-armmp-lpae armv7l Debian
Current Operating System: Linux clockworkpi 4.14.2-clockworkpi-cpi3-g638f2a7 #1 SMP Mon Dec 10 07:46:56 UTC 2018 armv7l
Kernel command line: console=ttyS0,115200n8 earlyprintk no_console_suspend root=/dev/mmcblk0p2 rootfstype=ext4 rootwait init=/sbin/init noinitrd panic=10
Build Date: 03 November 2018 05:53:43AM
xorg-server 2:1.19.2-1+deb9u5 (https://www.debian.org/support)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (–) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/home/cpi/.local/share/xorg/Xorg.0.log”, Time: Tue Jun 18 14:33:41 2019
(==) Using config file: “/etc/xorg.conf”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
modprobe: ERROR: …/libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file ‘/lib/modules/4.14.2-clockworkpi-cpi3-g638f2a7/modules.dep.bin’
modprobe: FATAL: Module g2d_23 not found in directory /lib/modules/4.14.2-clockworkpi-cpi3-g638f2a7
/home/cpi/launcher/sys.py/gsnotify
1280
4
24
x11info: 8388615
fork/exec ./01_Welcome.sh: permission denied
fork/exec ./99_TEST.sh: permission denied
…/skin/default/truetype/VarelaRound-Regular.ttf
Charging 1
(‘CheckBluetooth:no bluetooth’, (0, ‘’))
wifi is connected
51
state
dbus.UInt32(1L)
Trash:
[‘wireless’, ‘Jones’]
BleAgent /gameshell/bleagent registered
510128
state
dbus.UInt32(1L)
Trash:
Traceback (most recent call last):
File “run.py”, line 611, in
big_loop()
File “run.py”, line 544, in big_loop
main_screen.ReadTheDirIntoPages("…/Menu",0,None)
File “/home/cpi/launcher/sys.py/UI/main_screen.py”, line 463, in ReadTheDirIntoPages
self.ReadTheDirIntoPages(_dir+"/"+i, pglevel+1 ,self._Pages[ len(self._Pages) -1])
File “/home/cpi/launcher/sys.py/UI/main_screen.py”, line 494, in ReadTheDirIntoPages
iconitem._CmdPath.Init(self)
File “…/Menu/GameShell/21_Settings/init.py”, line 20, in Init
pages.InitListPage(main_screen)
File “…/Menu/GameShell/21_Settings/pages.py”, line 13, in InitListPage
myvars.ListPage.Init()
File “…/Menu/GameShell/21_Settings/list_page.py”, line 97, in Init
li._LinkObj.Init(self._Screen)
File “/home/cpi/launcher/Menu/GameShell/10_Settings/Bluetooth/init.py”, line 811, in Init
OBJ.Init(main_screen)
File “/home/cpi/launcher/Menu/GameShell/10_Settings/Bluetooth/init.py”, line 801, in Init
self.RegisterMyAgent()
File “/home/cpi/launcher/Menu/GameShell/10_Settings/Bluetooth/init.py”, line 762, in RegisterMyAgent
self._MyAgent = BleAgent(bus, AGENT_PATH)
File “/usr/lib/python2.7/dist-packages/dbus/service.py”, line 485, in init
self.add_to_connection(conn, object_path)
File “/usr/lib/python2.7/dist-packages/dbus/service.py”, line 576, in add_to_connection
self._fallback)
KeyError: “Can’t register the object-path handler for ‘/gameshell/bleagent’: there is already a handler”
cpi@clockworkpi:~$
for bluetooth error you may try install bluez
sudo apt-get update && sudo apt-get install bluez
Did that. Here I am now.
//_/////_//_
//_//_//_
HAPPY HACKING
Last login: Tue Jun 18 16:24:32 2019
(==) Log file: “/home/cpi/.local/share/xorg/Xorg.0.log”, Time: Tue Jun 18 16:24:34 2019
1280
4
24
x11info: 8388615
Charging 8
state
dbus.UInt32(1L)
Trash:
510128
state
dbus.UInt32(1L)
Trash:
big_loop()
self._fallback)
cpi@clockworkpi:~$
I’m waiting for my ROMs to finish backing up so I can reinstall 0.21. sigh
After a restore, I found that the error would only persist if I used the new updated “Settings” app. The only addition is the “skins” portion so it may be that
My old settings app is freezing when I open it.
The new one just hangs at the loading screen.
interesting
never see this before
so first
what is 01_Welcome.sh: 99_TEST.sh, where those files are
I spent my night restoring and putting everything back. I’m not on 0.21. Launcher updated. Settings works.
A few of my games don’t work but I think they just got damaged in the process. My Retroarch is 1.7.7
