They my screen looks inconsistent on the screen , it happened last night when i left it on for charging.
And today I found the screen looks different .
Hullo! Welcome to the forums!
I found that this happened with my unit that I leave on for days, compiling code with the screen on. Iâd get patches that are dull and washed out.
It would be to do with heat, and general use. Eg, if I accidentally leave it on while in a storage use, and it heats up, its generally quite affected.
I found that leaving it off for a day or so usually solves it.
That said, an LCD is essentially a consumable item, even for a computer or laptop.
If it can be helped, I guess try not to a) leave it ok unnecessarily and b) avoid extended periods of heat.
Hereâs some more info:
Thank you so much. Itâs such a beautiful explanation. I learnt a lot about LCD.
Does it mean the screen will be damaged irreversibly if you keep it very long? I am basically planning a screen replacement.
Also, would a heat sink work if the heat is playing. major role here?
Sorry for my english.
Itâs nearly impossible to install a heat sink without shell modification. The best solution right now is to open your gameshell outer shell and make sure itâs well ventilated.
does the screen issue also happen to you? I am wondering if it is a common issue because of heat.
Itâs an extreme case of being left on for longer than the battery can last. It happens on phones that have been left on for too long, doing power intensive activities. My PS vita has it so bad, it accidentally burnt in the image of whatever I had running. This is known as image persistence. See here.
Back in the old days, screen savers existed to avoid this phenomenon on CRT displays, although thatâs a slightly different case. Another thing you can do is change the power profile to one that isnât performance. This will allow the screen to dim and turn off when idle; then eventually turn off.
Just basically donât leave it on unnecessarily long and youâll be fine. And like I said, just leave it off for a day or so to allow your LCD to return to normal.
Usually for PC monitors you could unstuck them with this https://www.jscreenfix.com/
I wonder if something similar for cpi would do the job.
